HMG 3.0.0 + IDE + HFCL (Forum Test VIII)
Re: HMG 3.0.0 + IDE + HFCL (Forum Test VIII)
mol wrote:I found a bug in IDE 3 test 8
It doesn't recompile changed forms! Only changing prg files causes recompilation of project!!!
Is working fine here!!!!! :)
I've tested with 'multiwin' sample. Changing any thing in any of the forms, recompiles and updates ok.
Please, check your installation and if the problem persist, please, send me a complete sample project.
And... if someone can test too, we could confirm that the problem exists and in wich circumstances it arises.
Mario Mansilla
Post by Mario Mansilla »
Hola Roberto :
Instalo la nueva version (Test 8) y compruebo que no realiza el build cuando modifico alguna propiedad del form .
Te envio un ejemplo simple .
Mario Mansilla
Hola Roberto:
Install the new version (Test 8) and see that does not perform the build when I change some property of the form.
I sent a simple example.
Greetings
Mario Mansilla
Hmg3.rar
(608 KiB) Downloaded 373 times
Hi All
The IDE build a temp DIR under working DIR named .hbmk with read-only and hidden properties.
Under some circumstance this DIR can't removed after compilation and remain intact. Because it's hidden, we can't see it under normal conditions. And when we attempt rebuild the project, since this DIR and its content is exist, some modules, especially forms remain non-compiled.
Our Maestro will resolve this problem certainly. Until that, we could continue working by removing this temp DIR.
If you can't see it please use DOS command such as DIR /AD or simply change "hidden files and folders" option in "view" tab of "Folder Options" of "Tools" of Windows Explorer.
esgici wrote:Hi All
It is quite strange. It works for me with the samples at \hmg\ide\samples.
IDE just calls BUILD.BAT now with adequate parameters, so, the problem (if exists) is in build.bat.
I'll do some tests. Any ideas are welcome.
I think, problem exists in buld.bat.
Do you remember first release of hmg 3.0 - that was the same - update forms under IDE doesn't cause recompiling all project
Mario Mansilla wrote:Hola Roberto :
Mario Mansilla
Hola Roberto:
Greetings
Mario Mansilla
Ii've verified.
I'll work on it.
Roberto Lopez wrote: Ii've verified.
I'll work on it.
Maybe you (MOL, Esgici) could help in this.
I've tested many many times, \hmg\ide\samples\multiwin sample in test VIII.
Anytime that I change something in a form, the calling programs are recompiled ok.
When I try the sample posted by Mario Mansilla, the project is not recompiled when form was changed.
What is the difference?
I can't find the reason...
I'll work on it.
In fact, if you go to \hmg\ide\samples\multiwin and create (if not exist already) multiwin.hbp file containing project prg names and do:
build /i multiwin.hbp
App, will be created.
If you modify main.fmg file and call the command again:
main.prg only will be recompiled and the project updated.
Why Mario's project do not work?
I'll still experimenting, but any ideas are truly welcome...
TIA.
Roberto Lopez wrote: I can't find the reason...
I've modified build.bat to create and show the 'build.log' file showing the build details when there is no error.
It could help us to determine what's happening.
@echo off
cls
rem ***************************************************************************
rem HMG 3.0 Build batch
rem Roberto Lopez (2009.10.22)
rem Set variables
Set HmgPath=%~dp0
Set Path=%HmgPath%\util;%HmgPath%\mingw\bin;%HmgPath%\harbour\bin;
Set Resources=%HmgPath%\resources\minigui.o
set GT=-gtgui
set DEBUG=""
set BUILDTYPE=""
set REBUILDALL=""
set RUN=.T.
set MT=
rem
rem Syntax:
rem
rem	Build [/i|/r|/d|/cs|/ci/cr] <PrgFile> | <filelist.hbp> [config.hbc]
rem
rem	[/i] : incremental build
rem	[/r] : incremental build (rebuild all)
rem
rem	[/cs] : Console/mixed mode (std build)
rem	[/ci] : Console/mixed mode (incremental build)
rem	[/cr] : Console/mixed mode (incremental rebuild all)
rem
rem	[/d] : Debug mode (gui and console)
rem
rem
rem	<filelist.hbm> : A text file with .hbp extension containing a source list
rem	<configfile.hbc>: A text file with configuration parameters as additional
rem	libs, include paths and lib paths.
rem
rem		<configfile.hbc> Syntax:
rem
rem		incpaths = incpath1 incpath2 ... incpathn
rem
rem		libpaths = libpath1 libpath2 ... libpathn
rem
rem		libs = lib1 lib2 ... libn
rem
rem	- library names must not include 'lib' prefix nor '.a' extension.
rem
rem	- build.bat will create an 'error.log' file in the app folder when build
rem	process ends with an error condition.
rem
rem
cls
echo building...
if exist hbmk.log del hbmk.log
if exist windres.log del windres.log
if exist error.log del error.log
if exist _hmg_resconfig.h del _hmg_resconfig.h
rem ---------------------------------------------------------------------------
rem Parameters Processing
rem NO PARAMETERS OR HELP REQUESTED
if "%1"=="" goto syntax
if "%1"=="/?" goto syntax
if "%1"=="-?" goto syntax
if "%1"=="/h" goto syntax
if "%1"=="/H" goto syntax
if "%1"=="-h" goto syntax
if "%1"=="-H" goto syntax
if "%1"=="-help" goto syntax
if "%1"=="-HELP" goto syntax
rem No run after build
if "%1"=="/n" goto norun
if "%1"=="/N" goto norun
:continue0
rem Multi Thread
if "%1"=="/mt" goto multithread
if "%1"=="/MT" goto multithread
:continue1
rem Console Incremental Rebuild
if "%1"=="/cr" goto consoleincrebuild
if "%1"=="/CR" goto consoleincrebuild
if "%1"=="/ci" goto consoleincremental
if "%1"=="/CI" goto consoleincremental
rem GUI Incremental Rebuild
if "%1"=="/r" goto increbuild
if "%1"=="/R" goto increbuild
rem Console Standard Build
if "%1"=="/cs" goto console
if "%1"=="/CS" goto console
rem If debug mode specified, use GTWIN and pass -b parameter
if "%1"=="/d" goto debug
if "%1"=="/D" goto debug
rem If /i parameter rceived set BUILDTYPE to incremental
if "%1"=="/i" goto incremental
if "%1"=="/I" goto incremental
:continue
if exist %~n1.exe del %~n1.exe
if exist %~n1.exe goto error
rem If a resource with the same base name as the first parameter exist compile it
if exist %~n1.rc  echo #define HMGRPATH %HmgPath%\RESOURCES > _hmg_resconfig.h
if exist %~n1.rc copy /b %HmgPath%\resources\minigui.rc+%~n1.rc+%HmgPath%\resources\filler _temp.rc >NUL
if exist %~n1.rc redir -e windres.log windres -i _temp.rc -o _temp.o
if exist %~n1.rc Set Resources=_temp.o
rem invoke HBMK2
redir -eo  hbmk2 -o%~n1.exe %GT% %DEBUG% %MT% %BUILDTYPE% %REBUILDALL% -incpath=%HmgPath%\include -incpath=%CD% -L%HmgPath%\lib -lminigui -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage.a -lhbpgsql -lpq -lhbtip -lhbct -lhbmisc -lhbnetio -prgflag=/q %1 %2 %3 %4 %5 %6 %7 %8 %9 %Resources%  >hbmk.log
goto end
rem Procedure increbuild
:increbuild
set BUILDTYPE=-inc
set REBUILDALL=-rebuild
shift
goto continue
rem Procedure Console
:console
set GT=-gtwin
shift
goto continue
rem Procedure Debug
:debug
set GT=-gtwin
set DEBUG=-b
echo Options NoRunAtStartup > Init.cld
shift
goto continue
rem Procedure Incremental
:Incremental
set BUILDTYPE=-inc -head=real
shift
goto continue
rem Procedure IncConsole
:consoleincremental
set BUILDTYPE=-inc
set GT=-gtwin
shift
goto continue
:consoleincrebuild
set BUILDTYPE=-inc
set GT=-gtwin
shift
goto continue
rem Procedure NoRun
:norun
set RUN=.F.
shift
goto continue0
rem Procedure Multithread
:multithread
set MT=-mt
shift
goto continue1
rem Procedure Error
:error
echo Can't delete previous %~n1.exe version (still running?) > error.log
goto showlog
rem Procedure Syntax
:syntax
cls
echo :: Syntax:
echo ::
echo :: "Build [/i|/r|/d|/cs|/ci/cr] <PrgFile> | <filelist.hbp> [config.hbc]"
echo ::
echo :: [/i] : incremental build
echo :: [/r] : incremental build (rebuild all)
echo :: [/cs] : Console/mixed mode (std build)
echo :: [/ci] : Console/mixed mode (incremental build)
echo :: [/cr] : Console/mixed mode (incremental rebuild all)
echo :: [/d] : Debug mode (gui and console)
echo :: filelist.hbm : A text file with .hbp extension containing a source list
echo :: configfile.hbc: A text file with configuration parameters as additional
echo :: libs, include paths and lib paths.
echo ::
echo :: configfile.hbc Syntax:
echo ::
echo :: incpaths = incpath1 incpath2 ... incpathn
echo :: libpaths = libpath1 libpath2 ... libpathn
echo :: libs = lib1 lib2 ... libn
echo ::
echo :: library names must not include 'lib' prefix nor '.a' extension.
echo :: build.bat will create an 'error.log' file in the app folder when build
echo :: process ends with an error condition.
echo ::
pause
goto stop
:end
rem Cleanup
rem If build error, create 'error.log' ----------------------------------------
if errorlevel 1 if exist windres.log copy /b windres.log+hbmk.log error.log >nul
if errorlevel 1 if not exist windres.log copy /b hbmk.log error.log >nul
rem If no build error, create 'build.log' ----------------------------------------
if errorlevel 0 if exist windres.log copy /b windres.log+hbmk.log build.log >nul
if errorlevel 0 if not exist windres.log copy /b hbmk.log build.log >nul
rem If no error run the exe ---------------------------------------------------
if "%RUN%"==".T." if not errorlevel 1 if exist %~n1.exe %~n1.exe
rem Delete temporary files ----------------------------------------------------
if exist _temp.rc del _temp.rc
if exist _temp.o  del _temp.o
:showlog
if exist error.log type error.log
if exist build.log type build.log
:stop
