Page 3 of 5
Re: HMG-IDE 3.0.0 (Forum test VI)
Posted: Sun Oct 18, 2009 5:19 pm
by Roberto Lopez
Vanguarda wrote:@echo off
rem ***************************************************************************
rem HMG 3.0 Build batch
rem Roberto Lopez (2009.10.16)
rem Syntax:
Hello Master,
Well, i replace the build.bat for this code and it work fine.
The process of compilation is very fast. I had compile a project with 14 files.PRG (with approximately 800 lines each) and 18 files.FMG and the IDE compile it in 8 Seconds.
I´ve a CELERON with 3.06Ghz, with 1 GB memory RAM, with 1 MB of CACHE. It not DUAL CORE.
My resource file is empty because this new version of the HMG-IDE change the mode of using resource file. In old version the resource file called MAIN.RC, in this the resource file called <projectname>.RC, or i´m wrong?
I´ve a little doubt, i have that recompile the libs created with the old version of harbour+MinGW, for that this work on this new version of HMG?
Sorry my poor english.
With best Regards,
You are right.
Now, exe basename is the same as project and resource basenames.
I'll write a little document about that when the work be finished.
Build process is notably faster.
If someone can do benchmarks about program execution, will be greatly appreciated.
Finally: yes, the libraries should be recompiled
Roberto.
Posted: Sun Oct 18, 2009 5:28 pm
by Roberto Lopez
mol wrote:Any changes
replace the HBMK2 lines with:
rem invoke HBMK2
redir -eo hbmk2 -nohbc -o%~n1.exe %GT% %DEBUG% -head=real %BUILDTYPE% %REBUILDALL% -incpath=%HmgPath%\include -incpath=%CD% -L%HmgPath%\lib -lminigui -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage.a -lhbpgsql -lpq -lhbtip -lhbct -prgflag=/q %1 %2 %3 %4 %5 %6 %7 %8 %9 %Resources% >hbmk.log
goto end
I've only added:
Maybe something more should be changed yet.
Roberto.
Posted: Sun Oct 18, 2009 5:29 pm
rathinagiri wrote:
Diwali is a famous Indian festival. 'Light' is given more importance for this festival.
Hi Rathi
I don't know how I can celebrate your festival.
But I know "light" is common high value in almost all culture.
So I wish hearty brighter days for whole world, in real peace and happiness.
Posted: Sun Oct 18, 2009 5:40 pm
by Roberto Lopez
And I've catched this too:
W32_REGREAD
W32_REGWRITE
was renamed to:
WIN_REGREAD
WIN_REGWRITE
So, i_pseudofunc.ch should be changed to:
MINIGUI - Harbour Win32 GUI library source code
Copyright 2002-2009 Roberto Lopez <harbourminigui@gmail.com>
http://harbourminigui.googlepages.com/
This program is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License as published by the Free Software
Foundation; either version 2 of the License, or (at your option) any later
version.
This program is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with
this software; see the file COPYING. If not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA (or
visit the web site http://www.gnu.org/).
As a special exception, you have permission for additional uses of the text
contained in this release of Harbour Minigui.
The exception is that, if you link the Harbour Minigui library with other
files to produce an executable, this does not by itself cause the resulting
executable to be covered by the GNU General Public License.
Your use of that executable is in no way restricted on account of linking the
Harbour-Minigui library code into it.
Parts of this project are based upon:
"Harbour GUI framework for Win32"
Copyright 2001 Alexander S.Kresin <alex@belacy.belgorod.su>
Copyright 2001 Antonio Linares <alinares@fivetech.com>
www - http://www.harbour-project.org
"Harbour Project"
Copyright 1999-2003, http://www.harbour-project.org/
"WHAT32"
Copyright 2002 AJ Wos <andrwos@aust1.net>
"HWGUI"
Copyright 2001-2007 Alexander S.Kresin <alex@belacy.belgorod.su>
#translate IsControlDefined ( <ControlName> , <FormName> ) ;
_IsControlDefined ( <"ControlName"> , <"FormName"> )
#translate IsWIndowActive ( <FormName> ) ;
_IsWIndowActive ( <"FormName"> )
#translate IsWindowDefined ( <FormName> ) ;
_IsWindowDefined ( <"FormName"> )
#translate RegistryRead ( <arg> ) ;
win_regread ( <arg> )
#translate RegistryWrite ( <arg1> , <arg2> ) ;
win_regwrite ( <arg1> , <arg2> )
I hope that this fix all undefined references.
Roberto.
Posted: Sun Oct 18, 2009 5:43 pm
by mol
A little better, but I function is still missing:
REGWRITE
Below, report from compilation
[b]hbmk2: debuginc: Calling Harbour compiler to detect dependencies of
c:/projekty/akord/akord.prg[/b]
c:/projekty/akord/certyfikaty.prg
c:/projekty/akord/eksport.prg
c:/projekty/akord/funkcje.prg
c:/projekty/akord/obsluga.prg
c:/projekty/akord/raporty.prg
c:/projekty/akord/tabele.prg
hbmk2: Linking... Akord.exe
.hbmk\win\mingw\akord.o:akord.c:(.data+0x338): undefined reference to `HB_FUN_W32_REGWRITE'
gcc.exe .hbmk\win\mingw\akord.o .hbmk\win\mingw\certyfikaty.o .hbmk\win\mingw\eksport.o .hbmk\win\mingw\funkcje.o .hbmk\win\mingw\obsluga.o .hbmk\win\mingw\raporty.o .hbmk\win\mingw\tabele.o .hbmk\win\mingw\_hbmkaut.o _temp.o -mwindows -Wl,--start-group -lminigui -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage -lhbpgsql -lpq -lhbtip -lhbct -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oAkord.exe -Lc:/hmg/harbour/lib -Lc:/hmg/lib
Bolded lines, I think, are caused by altd() function, which exists in my source code.
Posted: Sun Oct 18, 2009 5:50 pm
by Roberto Lopez
mol wrote:A little better, but I function is still missing:
REGWRITE
It still happen with new i_pseudofunc.ch?
Roberto.
Posted: Sun Oct 18, 2009 5:57 pm
by Roberto Lopez
rathinagiri wrote:
Hi Roberto,
As you have searched and found out, Diwali (aka Deepavali in some places) is a famous Indian festival. 'Light' is given more importance for this festival. This day (Oct-Nov. new moon day) is celebrated for the remembrance of Lord Krishna having killed Naragasura (a Demon).
Diwali is more important for me, since we manufacture fireworks here mostly for the consumption in this festival days for the whole of India.
Since you asked some of our pictures enjoying Diwali (sorry for the quality - captured using mobile hastily)
This is my elder daughter's hand lighting a sparkler.
Wow!... Nice!
Here (in Aregentina) we use such fireworks in christmas and new year too.
Sadly, here, some people prefers some 'noise devices' (I don't know the exact translation) that are designed only to make noise (big explosions) without any lightning effect.
Thanks for sharing this!
Roberto.
Posted: Sun Oct 18, 2009 6:09 pm
by mol
First, I've missed changes in i_pseudofunc.ch
Now, after changes, I still get errors:
Posted: Sun Oct 18, 2009 6:14 pm
by Roberto Lopez
mol wrote:First, I've missed changes in i_pseudofunc.ch
Appears to be a copy/paste problem.
I've attached the file to this message.
Roberto.
Posted: Sun Oct 18, 2009 6:18 pm
by mol
There was missed /* and */ signs of begin and end of comment.
