My First SQLite Project
Re: My First SQLite Project
rathinagiri wrote:Oh! Nice. It is a treasure to dig in. :)
I've done for simplicity and speed and I've used in a couple of projects.
It uses direct C calls to access MySql API (not TMySql).
When I left the code, a couple of things should be added yet.
1. Field type detection for automatic conversion (in result recordset).
2. Create a local temporary table to store the recordset, so, it could be accessed as a normal table.
Hello Master Roberto,
The main thing for which I liked VFP for it's embedded SQL. Thank you so much. You made it available to harbour.
Now, if we can add those 2 points. It will be even better. For long time I was looking for temporary table with HMG (as I used it in VFP Cursor). Temporary table creation is already available with Harbour, but I can't create it with HMG Official. So, I am very happy to read your post.
Thank you again.
sudip wrote:Temporary table creation is already available with Harbour, but I can't create it with HMG Official.
Why not?
I've was thinking in a temporary 'disk-file' standard table.
What do you was thinking?
Roberto Lopez wrote: It uses direct C calls to access MySql API (not TMySql).
:o
Is it? Fine.
Why not?
I was thinking about to use
hb_dbcreatetemp("curItem", adbf)
I hope this will create a temporary table in memory (like cursor in VFP).
Hello Rathi,
:o
Is it? Fine.
Now we should port it to SQLite and PostGreSQL also :)
I feel one of my dreams about HMG is coming true :)
Hi Sudip!
Fine project. I've never wrote any application with SQL, but, I think that will be future.
What about refreshing table after changing/adding new record?
Whether it is necessary to call GET_DATA function after every change?
What about refreshing in multiuser environment?
Recurring data downloads after defined period?
mol wrote:Hi Sudip!
Yes, they are omitted :( I must say that those points are very essential. I shall add them later. I am now studying Roberto's code for SQL Layer (in my free time :) ).
Thank you for your comments.
I noticed that your picture has been changed (without sunglass :) )
:o
Is it? Fine.
Yes.
I've looked at TMySql code and I've found that it has two layers.
The 'class' layer is only a wrapper to access true MySql functions, so I've skipped that layer, since class was not needed to make a simple command based SQL interface.
The idea of use direct SQL commands in the programs come to me from VFP. As Sudip points in VFP the result recordset goes to a 'cursor' (a local temporary table).
I don't knew that function.
I'll try to research a little...
