Page 3 of 8
Re: Payment terminal TIMAPI.DLL
Posted: Thu Aug 10, 2023 10:17 pm
by Georg_BA
Hello Serge
I don't know how to incorporate it into HMG.
I am open to any solution.
I was thinking about whether to solve it by switching to MiniGUI, I assume that it uses libraries of the "lib" type.
The source code in C language is available and I thought it would not be a problem to create a library of type "a".
The post has over 900 views, but I don't see any interest except for you, Edward, Daniel, Jimmy (AUGE_OHR). I've gotten used to n-questions within HMG going unanswered. I know there are many smart people here who have devoted a lot of their time to HMG, I'm just afraid they have left this forum.
Question for Grigory (Filatov), is it possible to use the supplied libraries in MiniGUI
Thanks everyone for your help.
Best regards, Georg
Posted: Thu Aug 10, 2023 10:33 pm
by edk
Unfortunately, I have not received any documentation from WorldLine so far. But:
- I was able to reverse engineer the algorithm to calculate the correct SIXml protocol magic number.
- listening to TCP packets I was able to extract some syntaxes of SIXml.
- I can establish a connection with a payment terminal (simulator)
- Get status feature
- login to the terminal
- read information about the application
- read information about the card inserted into the payment terminal.
I have prepared sources for communication regarding the above features.
nTimeOut := 300
ipadres := '127.0.0.1'
ipport := 7784
nSequenceNumber := 0
DEFINE WINDOW main AT 0 , 0 WIDTH 800 HEIGHT 500 TITLE "ECR/POS - EFT" MAIN
    DEFINE MAIN MENU
        DEFINE POPUP "Test"
            MENUITEM "Run test" ACTION test()
        END POPUP
    END MENU
    DEFINE RICHEDITBOX log_
        ROW    10
        COL    10
        WIDTH  500
        HEIGHT 420
        VALUE ""
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .T.
    END RICHEDITBOX
    DEFINE RICHEDITBOX EFTDisplay_
        ROW    10
        COL    520
        WIDTH  250
        HEIGHT 200
        VALUE ""
        TOOLTIP ""
        FONTNAME "Courier"
        FONTSIZE 14
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .T.
    END RICHEDITBOX
    DEFINE RICHEDITBOX EFTPrinter_
        ROW    230
        COL    520
        WIDTH  250
        HEIGHT 200
        VALUE ""
        TOOLTIP ""
        FONTNAME "Courier"
        FONTSIZE 14
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .T.
    END RICHEDITBOX
CENTER WINDOW main
ACTIVATE WINDOW main
Procedure test
addlog ( ">> Initialization" )
socket := TIM_init ( ipadres, ipport, nTimeOut )
IF !hb_InetIsSocket ( socket )
    addlog ( "Connection failed" )
addlog ( ">> Get Feature Request" )
IF !TIM_Send ( socket, TIM_GetFeatureRequest ( nSequenceNumber ) )
    addlog ("Failed to send Feature Request request")
    return
cResp := TIM_Recv ( socket, 10 /* nTimeOut */ )
strfile ( cResp, "resp1.xml" )
oXMLFile := objXML ( cResp )
DisplayEFTMessage ( oXMLFile )
hStatus := GetStatusInfo ( oXMLFile )
LogStatusInfo ( hStatus )
IF hStatus [ "CardReaderStatus" ] == "CardInserted"
    //show info about card
    LogCardInfo ( oXMLFile )
cTerminalID := hStatus [ "TerminalID" ]
msginfo ( "Next step" )
addlog ( ">> Login" )
cPosId := "POS1234"
nSequenceNumber++
IF !TIM_Send ( socket, TIM_Login ( nSequenceNumber, cPosId ) )
    addlog ("Failed to send login request")
    return
cResp := TIM_Recv ( socket, 3 /* nTimeOut */ )
strfile ( cResp, "resp2.xml" )
oXMLFile := objXMLLoad ( oXMLFile, cResp )
addlog ( "Result Code: " + oXMLFile:documentElement:selectNodes( "//sixml:Response" ):item(0):getAttribute( "ResultCode" ) )
addlog ( ">> Get Application Information" )
nSequenceNumber++
IF !TIM_Send ( socket, TIM_GetApplicationInformation ( nSequenceNumber ) )
    addlog ("Failed to send Application Information request")
    return
strfile ( cResp, "resp3.xml" )
addlog ( ">> Close" )
TIM_Close ( socket )
Function TIM_init ( cIPadres, nIPport, nTimeOut )
Local socket, nTCPIPErr
Local nTry := 1, nMaxTry := 10
IF ! hb_inetInit()
    addlog ( "Inet could not be initialized!" )
    RETURN Nil
socket := hb_inetCreate()
hb_inetTimeout( socket, nTimeOut )
DO WHILE nTry <= nMaxTry
    nTry ++
    hb_inetConnect( cIPadres, nIPport, socket )
    nTCPIPErr := hb_inetErrorCode( socket )
    IF nTCPIPErr = 0
        EXIT
    Inkey(.05)
ENDDO
IF nTCPIPErr # 0
    addlog ( "Connection error. Error number:" + hb_valToStr ( nTCPIPErr ) + " " + hb_valToStr( hb_inetErrorDesc( socket ) ) )
    hb_inetClose( socket )
    RETURN Nil
RETURN socket
FUNCTION TIM_GetFeatureRequest ( nSequenceNumber )
Local cSIXml := '<?xml version="1.0" encoding="UTF-8"?>' + ;
                '<sixml:Request xmlns:sixml="http://www.worldline.com/" ' + ;
                'FunctionGroup="Status" ' + ;
                'Function="FeatureRequest" ' + ;
                'SequenceNumber="' + AllTrim( Str( nSequenceNumber ) ) + '"/>'
RETURN cSIXml
FUNCTION TIM_GetApplicationInformation ( nSequenceNumber )
                'Function="ApplicationInformation" ' + ;
RETURN cSIXml
FUNCTION TIM_Login ( nSequenceNumber, cPosID )
                'FunctionGroup="Admin" ' + ;
                'Function="Login" ' + ;
                'SequenceNumber="'  + AllTrim( Str( nSequenceNumber ) ) + '">' + ;
                '<sixml:PosId>' + cPosID + '</sixml:PosId>' + ;
                '<sixml:IntegratorId>0</sixml:IntegratorId>' +;
                '<sixml:ProtocolOptionList>' +;
                '<sixml:ProtocolOption OptionType="sixml:ProtocolLevel">3</sixml:ProtocolOption>' +;
                '<sixml:ProtocolOption OptionType="sixml:Guides">1</sixml:ProtocolOption>' +;
                '<sixml:ProtocolOption OptionType="sixml:AutoCommit">0</sixml:ProtocolOption>' +;
                '</sixml:ProtocolOptionList>' + ;
                '<sixml:PrintOptionList>'+ ;
                '<sixml:PrintOptions Recipient="Merchant" PrintFormat="Normal" PrintWidth="40" PrintFlags="0"/>' +;
                '<sixml:PrintOptions Recipient="Cardholder" PrintFormat="Normal" PrintWidth="40" PrintFlags="0"/>' +;
                '</sixml:PrintOptionList><sixml:ManufacturerFlags>0</sixml:ManufacturerFlags></sixml:Request>'
RETURN cSIXml
FUNCTION TIM_Send ( socket, cPakiet )
Local nTry := 1, nMaxTry := 3, xSIXml
    addlog ( "Invalid socket" )
    Return .F.
cPakiet := TIM_Magic_numer ( cPakiet ) + cPakiet
strfile ( cPakiet, "pakiet.txt" )
    hb_inetFD( socket )
    IF hb_inetSendAll( socket, cPakiet ) == Len ( cPakiet )
        RETURN .T.
    //podejmij kolejna próbę
    nTry ++
ENDDO
RETURN .F.
FUNCTION TIM_Recv ( socket, nTimeOut )
Local cBuf, nBuf, nStartClock := Seconds(), cResponse := ""
Default nTimeOut := 10
    Return ""
DO While .T.
    nLength := TIM_isRespSIXml ( socket )
    cBuf := SPACE ( nLength )
    nBuf := hb_inetRecvAll( socket, @cBuf, Len( cBuf ) )
    cResponse += Left ( cBuf, nBuf )
    IF !Empty( cResponse )
        RETURN cResponse
    IF Seconds() - nStartClock >= nTimeOut .And. nBuf == -1     //osiągnięto TimeOut
        addlog ( "Timeout has been reached waiting for a response." )
        RETURN cResponse
ENDDO
FUNCTION TIM_Close ( socket  )
hb_inetCleanup()
FUNCTION TIM_isRespSIXml ( socket, nTimeOut )
Local nSIXmlMagicLen := 9
Local cPrefix := "SIXml"
Local nTransportLayerVersion := 0x02
Local nReceiveChannel := 0x01
Local nRemainder, nInteger, nDivider := 256
Local nLength := 1024
Default nTimeOut := 3
DO While .T.
    cBuf := " "     //SPACE ( Len ( nSIXmlMagicLen ) )
    IF Len ( cResponse ) == nSIXmlMagicLen
        IF Left ( cResponse, Len ( cPrefix ) ) == cPrefix .And. ;
           SubStr ( cResponse, Len ( cPrefix ) + 1, 1 ) == Chr ( nTransportLayerVersion ) .And. ;
           Right ( cResponse, 1 ) == Chr ( nReceiveChannel )       //jest odpowiedz SIXmlMagicHeader
            nInteger := Asc ( SubStr ( cResponse, Len ( cPrefix ) + 2, 1 ) )
            nRemainder := Asc ( SubStr ( cResponse, Len ( cPrefix ) + 3, 1 ) )
            nLength := (( nInteger * nDivider ) + nRemainder ) - 1
            Return nLength
    IF Seconds() - nStartClock >= nTimeOut    //osiągnięto TimeOut
        RETURN nLength
ENDDO
RETURN nLength
FUNCTION TIM_Magic_numer ( cPakiet )
Local nLength := Len ( cPakiet ) + 1
nInteger   := INT ( nLength / nDivider )
nRemainder := ( nLength % nDivider )
RETURN cPrefix + Chr ( nTransportLayerVersion ) + Chr ( nInteger ) + Chr ( nRemainder ) + Chr ( nReceiveChannel )
Static Function objXML ( cXMLString )
Local oMyErr, oXMLFile := Win_OleCreateObject( "Msxml2.DOMDocument.3.0" )
oXMLFile:async := .F.
oXMLFile:setProperty("SelectionLanguage", "XSLPattern")      // https://www.codemag.com/article/0102051/XSL-Patterns
Return objXMLLoad ( oXMLFile, cXMLString )
Static Function objXMLLoad ( oXMLFile, cXMLString )
Local oMyErr
oXMLFile:loadXML ( cXMLString )
IF oXMLFile:parseError:errorCode != 0
    oMyErr := oXMLFile:parseError
    addlog ("You have error " + oMyErr:reason)
    RETURN Nil
RETURN oXMLFile
Function DisplayEFTMessage ( oXMLFile )
Local oNodeList := oXMLFile:documentElement:selectNodes( "//sixml:DisplayLine" )
Local oOneElement
IF oNodeList:length > 0     //Show the received message
    Main.EFTDisplay_.Value :=  ""
    FOR EACH oOneElement IN oNodeList
        main.EFTDisplay_.AddText ( LEN( main.EFTDisplay_.Value) ) := oOneElement:text + CRLF
Procedure LogStatusInfo ( hStatus )
addlog ( "Card Reader Status: " + hStatus [ "CardReaderStatus" ] )
addlog ( "Transaction Status: " + hStatus [ "TransactionStatus" ] )
addlog ( "Connection Status: " + hStatus [ "ConnectionStatus" ] )
addlog ( "Management Status: " + hStatus [ "ManagementStatus" ] )
addlog ( "Receipt Information: " + hStatus [ "ReceiptInformation" ] )
addlog ( "Terminal ID: " + hStatus [ "TerminalID" ] )
RETURN Nil
Function GetStatusInfo ( oXMLFile )
Local hStatus := { "CardReaderStatus" => oXMLFile:documentElement:selectNodes( "//sixml:CardReaderStatus" ):item(0):text, ;
                   "TransactionStatus" => oXMLFile:documentElement:selectNodes( "//sixml:TransactionStatus" ):item(0):text, ;
                   "ConnectionStatus" => oXMLFile:documentElement:selectNodes( "//sixml:ConnectionStatus" ):item(0):text, ;
                   "ManagementStatus" => oXMLFile:documentElement:selectNodes( "//sixml:ManagementStatus" ):item(0):text, ;
                   "ReceiptInformation" => oXMLFile:documentElement:selectNodes( "//sixml:ReceiptInformation" ):item(0):text, ;
                   "TerminalID" => oXMLFile:documentElement:selectNodes( "//sixml:TerminalId" ):item(0):text }
RETURN hStatus
Procedure LogCardInfo ( oXMLFile )
Local oCardData := oXMLFile:documentElement:selectNodes( "//sixml:CardData" ):item(0):attributes
Local oOneAttribute := nil
IF oCardData:length > 0
    addlog ( Space ( 5 ) + "Information about of inserted card:" )
    FOR EACH oOneAttribute IN oCardData
        addlog ( Space ( 10 ) + oOneAttribute:name + ": " + oOneAttribute:text )
    addlog ( Space ( 10 ) + "Language: " + oXMLFile:documentElement:selectNodes( "//sixml:CardData/sixml:Language" ):item(0):text )
FUNCTION addlog( cTxt )
main.log_.AddText ( LEN( main.log_.Value) ) := cTxt + CRLF
DO events
RETURN nil
I saved the data sent to the terminal in raw form, I did not have time to analyze the meaning of individual variables, except for those whose interpretation of their meaning did not raise any doubts. I focused on getting the correct communication between HMG and the payment terminal simulator.
The R.E. process is quite a tedious job, if you are interested I can send you the methodology I use, you can try to take the project further.
Posted: Fri Aug 11, 2023 6:44 am
Great Job Edward!
Posted: Fri Aug 11, 2023 10:07 am
by edk
Some improvements, some new events:
nTimeOut := 300
ipport := 7784
    DEFINE MAIN MENU
        DEFINE POPUP "Test"
        END POPUP
    END MENU
        ROW    10
        COL    10
        WIDTH  500
        HEIGHT 420
        VALUE ""
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .T.
    END RICHEDITBOX
    DEFINE Label Display
        ROW    10
        COL    520
        WIDTH  250
        VALUE "DISPLAY"
    END Label
        ROW    50
        COL    520
        WIDTH  250
        HEIGHT 170
        VALUE ""
        TOOLTIP ""
        FONTNAME "Courier"
        FONTSIZE 14
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .T.
    END RICHEDITBOX
    DEFINE Label Printer
        ROW    230
        COL    520
        WIDTH  250
        VALUE "PRINTER"
    END Label
        ROW    260
        COL    520
        WIDTH  250
        HEIGHT 170
        VALUE ""
        TOOLTIP ""
        FONTNAME "Courier"
        FONTSIZE 14
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        HELPID Nil
        TABSTOP .T.
        VISIBLE .T.
        READONLY .T.
    END RICHEDITBOX
CENTER WINDOW main
Procedure test
cPosId := "POS1234"
cUserID := "0"
oXMLFile := objXML ( '' )
hStatus := { "CardReaderStatus" => "", "TransactionStatus" => "", "ConnectionStatus" => "", "ManagementStatus" => "", "ReceiptInformation" => "", "TerminalID" => "" }
addlog ( ">> Initialization, Connect" )
TIM_RecvAll ( socket )
    return
nSequenceNumber++
    return
nSequenceNumber++
    return
addlog ( ">> Put System Information" )
nSequenceNumber++
IF !TIM_Send ( socket, TIM_PutSystemInformation ( nSequenceNumber ) )
    addlog ("Failed to send System Information")
    return
addlog ( ">> Activate" )
nSequenceNumber++
IF !TIM_Send ( socket, TIM_Activate ( nSequenceNumber, cUserID ) )
    addlog ("Failed to send Activate request")
    return
addlog ( ">> DeActivate" )
nSequenceNumber++
IF !TIM_Send ( socket, TIM_DeActivate ( nSequenceNumber ) )
    addlog ("Failed to send Deactivate request")
    return
addlog ( ">> Logout" )
nSequenceNumber++
IF !TIM_Send ( socket, TIM_Logout ( nSequenceNumber ) )
    addlog ("Failed to send logout request")
    return
IF ! hb_inetInit()
    RETURN Nil
    nTry ++
    IF nTCPIPErr = 0
        EXIT
    Inkey(.05)
ENDDO
IF nTCPIPErr # 0
    RETURN Nil
RETURN socket
RETURN cSIXml
RETURN cSIXml
FUNCTION TIM_PutSystemInformation ( nSequenceNumber )
                'Function="SystemInformation" ' + ;
                '<sixml:EcrData>' + ;
                '<sixml:EcrInfo EcrInfoType="EftAPI" ' + ;
                'EcrInfoName="HMG TIM API" ' + ;
                'EcrInfoManufacturerName="HMG community" ' + ;
                'EcrInfoVers="3.20.0-2513" ' + ;
                'EcrInfoArchitecture="harbour"/>' + ;
                '<sixml:EcrInfo EcrInfoType="Os" ' + ;
                'EcrInfoName="Microsoft Windows NT 6.2.9200.0" ' + ;
                'EcrInfoVers="6.2.9200.0" ' + ;
                'EcrInfoArchitecture="Win32NT"/>' + ;
                '</sixml:EcrData></sixml:Request>'
RETURN cSIXml
RETURN cSIXml
FUNCTION TIM_Logout ( nSequenceNumber, cPosID )
                'Function="Logout" ' + ;
RETURN cSIXml
FUNCTION TIM_Activate ( nSequenceNumber, cUserID )
                'Function="Activate" ' + ;
                '<sixml:UsrId>' + cUserID + '</sixml:UsrId></sixml:Request>'
RETURN cSIXml
FUNCTION TIM_DeActivate ( nSequenceNumber )
                'Function="Deactivate" ' + ;
RETURN cSIXml
    Return .F.
    hb_inetFD( socket )
        RETURN .T.
    nTry ++
ENDDO
RETURN .F.
Local cBuf, nBuf, nStartClock := Seconds(), cResponse := "", hResponse, nLength
    Return ""
DO While .T.
    hResponse := TIM_isRespSIXml ( socket )
    nLength := hResponse [ "ResposeLength" ]
    IF hResponse [ "IsSIXmlHeader" ] := .F.
        cResponse += hResponse [ "ReceivedString" ]
    IF !Empty( cResponse ) .OR. nBuf == -1
        RETURN cResponse
        addlog ( "Recv Timeout has been reached waiting for a response." )
        RETURN cResponse
ENDDO
hb_inetCleanup()
DO While .T.
            Return { "ResposeLength" => nLength, "ReceivedString" => cResponse, "IsSIXmlHeader" => .T. }
        Return { "ResposeLength" => nLength, "ReceivedString" => cResponse, "IsSIXmlHeader" => .F. }
    IF nBuf = -1
        addlog ( "Magic number Timeout has been reached waiting for a response." )
ENDDO
IF Empty ( cXMLString )
    Return oXMLFile
Local oMyErr
    RETURN Nil
RETURN oXMLFile
Local oOneElement
RETURN Nil
IF oXMLFile:documentElement:selectNodes( "//sixml:CardReaderStatus" ):length > 0
    hStatus [ "CardReaderStatus" ] := oXMLFile:documentElement:selectNodes( "//sixml:CardReaderStatus" ):item(0):text
IF oXMLFile:documentElement:selectNodes( "//sixml:TransactionStatus" ):length > 0
    hStatus [ "TransactionStatus" ] := oXMLFile:documentElement:selectNodes( "//sixml:TransactionStatus" ):item(0):text
IF oXMLFile:documentElement:selectNodes( "//sixml:ConnectionStatus" ):length > 0
    hStatus [ "ConnectionStatus" ] := oXMLFile:documentElement:selectNodes( "//sixml:ConnectionStatus" ):item(0):text
IF oXMLFile:documentElement:selectNodes( "//sixml:ManagementStatus" ):length > 0
    hStatus [ "ManagementStatus" ] := oXMLFile:documentElement:selectNodes( "//sixml:ManagementStatus" ):item(0):text
IF oXMLFile:documentElement:selectNodes( "//sixml:ReceiptInformation" ):length > 0
    hStatus [ "ReceiptInformation" ] := oXMLFile:documentElement:selectNodes( "//sixml:ReceiptInformation" ):item(0):text
IF oXMLFile:documentElement:selectNodes( "//sixml:TerminalId" ):length > 0
    hStatus [ "TerminalID" ] := oXMLFile:documentElement:selectNodes( "//sixml:TerminalId" ):item(0):text
RETURN hStatus
Local oLanguage := oXMLFile:documentElement:selectNodes( "//sixml:CardData/sixml:Language" )
    IF oLanguage:length > 0
        addlog ( Space ( 10 ) + "Language: " + oLanguage:item(0):text )
Procedure LogResponseInfo ( oXMLFile )
Local oResponse := oXMLFile:documentElement:selectNodes( "//sixml:Response" ):item(0):attributes
IF oResponse:length > 0
    addlog ( Space ( 5 ) + "Response:" )
    FOR EACH oOneAttribute IN oResponse
DO events
RETURN nil
FUNCTION TIM_RecvAll ( socket )
Local cResp
STATIC nCount := 1
DO WHILE .T.
    IF Empty ( cResp )
        EXIT
    strfile ( cResp, "resp" + strzero ( nCount, 3) + ".xml" )
    IF oXMLFile:documentElement:selectNodes( "//sixml:Notification" ):length > 0
    IF oXMLFile:documentElement:selectNodes( "//sixml:DisplayContent" ):length > 0
    IF oXMLFile:documentElement:selectNodes( "//sixml:Response" ):length > 0
    IF oXMLFile:documentElement:selectNodes( "//sixml:ReceiptHeader" ):length > 0
        PrintEFTReceipt ( oXMLFile:documentElement:selectNodes( "//sixml:ReceiptHeader" ) )
    IF oXMLFile:documentElement:selectNodes( "//sixml:PrintData/sixml:Receipt" ):length > 0
        PrintEFTReceipt ( oXMLFile:documentElement:selectNodes( "//sixml:PrintData/sixml:Receipt" ) )
    nCount ++
ENDDO
Function PrintEFTReceipt ( oNodeList /* oXMLFile */ )
//Local oNodeList := oXMLFile:documentElement:selectNodes( "//sixml:ReceiptHeader" )
Local oOneElement
IF oNodeList:length > 0     //Print the received receipt
    main.EFTPrinter_.AddText ( LEN( main.EFTPrinter_.Value) ) := CRLF
        main.EFTPrinter_.AddText ( LEN( main.EFTPrinter_.Value) ) := oOneElement:text + CRLF
Posted: Fri Aug 11, 2023 11:38 am
by Georg_BA
Hi Edward.
Thank you very much for your help.
Great job.
I'm still on the road today. I will test tomorrow and let you know the result.
Best regards, Georg
Posted: Sat Aug 12, 2023 12:57 am
Hola Georg y Eduard
Recuerdo que para crear la libreria hbssl que esta en la carpeta contrib de debe tener los archivos .c fuente y .h (include)
ademas de los .dll y de esa manera crear la libreria libhbssl.
undefined reference to `HB_FUN_TA_TERMINAL_GET_TIM_API_VERSION'
se debe a que falta timapi.h que no la encuentro en ningun sitio :roll: y colocar dicho archivo a la carpeta Include de HMG
Posted: Sat Aug 12, 2023 7:43 am
by Georg_BA
Hello Daniel
path to the file timapi.h
\C\TimApi\Include\timapi\
Georg
Posted: Sun Aug 13, 2023 3:12 pm
by Georg_BA
Hello everyone
Thanks again Edward.
My knowledge.
I tried to communicate with a real payment terminal. By default, the terminal has DHCP set for assigning an IP address. The assigned address can be displayed, but it can change after a power failure or disconnection. Communication should be done according to the terminal ID.
It does not detect a real connected payment card.
I don't know if it is necessary to submit a request for payment soon, then he should wait for the card to be inserted. I forced the example in ..TimAPI\DotNet\ExampleEcrSync\ExampleEcrSync.exe, it logs in after the payment request and waits for attachment (RC) or card insertion.
Best regards, Georg
Posted: Sun Aug 13, 2023 5:46 pm
by edk
Hi.
I don't have access to a physical terminal, so I'm testing on a simulator.
I just use the client application "\TIMAPI_DotNet\DotNet\Examples\AdvancedEcr\AdvancedEcr.exe"
Here is my configuration file:
TIMTest.zip
(614 Bytes) Downloaded 541 times
When it comes to establishing a connection via Terminal ID, communication via the UDP protocol is required. Here's a screenshot of the log.
I do not know if such communication can be carried out from the harbor level, I will look for it on the web.
Can't force static IP on terminal?
Regarding downloading data from the card:
Here's my flow chart. first do Connect, then Login, then Activate.
Insert a virtual card in the simulator.
The terminal should send the card details and the status should change.
When it comes to reading data from the card, it reads them from the simulator, the virtual ones. Perhaps the physical cards do not return this data.
Check what logs are with the physical terminal and physical card.
Posted: Sun Aug 13, 2023 11:13 pm
by edk
I think I managed to establish communication via UDP, at least it works on the terminal simulator.
Check this code and see if the physical terminal returns an ip address and port number. In the code, write the correct ID of the terminal.
cTerminal_ID := '12345678'
nTimeOut := 300
cBroadcastAdress := '255.255.255.255'
nTerminal_UDP_port := 33334
nListening_UDP_port := 33335
cUDP_CRLF := hb_inetCRLF()
cUPD_RAW_Data := 'SIXml' + cUDP_CRLF + 'TerminalRequest' + cUDP_CRLF + 'TID: ' + cTerminal_ID + cUDP_CRLF + 'Connect: false' + cUDP_CRLF
cUPD_RCV_Data := Space ( 1024 )
IF ! hb_inetInit()
    MsgStop ( "Inet could not be initialized!" )
    RETURN Nil
//socket := hb_inetDGram( .T. )
socket := hb_inetDGramBind( nListening_UDP_port, , .T. /* lBroadcast */ )
msgdebug ( 'hb_inetErrorCode', hb_inetErrorCode( socket ) )
//hb_inetFD( socket )
msgdebug ( 'UDP bytes sent"', hb_inetDGramSend( socket, cBroadcastAdress, nTerminal_UDP_port, cUPD_RAW_Data  ) )
msgdebug ( 'received UDP bytes:', nRecv_bytes := hb_inetDGramRecv( socket, @cUPD_RCV_Data ), 'received UDP data:', hb_Atokens ( Left ( cUPD_RCV_Data, nRecv_bytes ), cUDP_CRLF ))
Does it return that SSL is off or on?
