FROM XML TO DBF
Re: FROM XML TO DBF
Working simplified sample:
#require "hbmxml.hbc"
DBCREATE( 'invoice.dbf', { { "uid", "C", 40, 0 },;
		{ "IssuerVatN" , "C", 9, 0 },;
		{ "CountVatN" , "C", 9, 0 },;
		{ "issueDate", "D", 8, 0 },;
		{ "totNetVal", "N", 10, 2 } } )
DBCREATE( 'invoiceDetails.dbf', { { "uid", "C", 40, 0 },;
		{ "LineNumber" , "N", 5, 0 },;
		{ "NetValue", "N", 10, 2 } } )
DEFINE WINDOW Form_1 AT 0 , 0 WIDTH 300 HEIGHT 100 TITLE "HMG" MAIN ON INIT Start()
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
Function Start()
Local cXmlFile := GetFile( {{'XML File', '*.xml'}}, 'Select XML', hb_CWD(), .F. , .T. )
IF EMPTY( cXmlFile )
	RETURN Nil
SELECT 1
USE invoice
ZAP
SELECT 2
USE invoiceDetails
ZAP
WAIT WINDOW "Processing ..." NOWAIT
hb_XMLParser( hb_MemoRead ( cXmlFile ), .T., { | aRowXML | Parser_Request ( aRowXML ) } )
WAIT CLEAR
MsgInfo ( "Done" )
Function Parser_Request ( aXmlOneRow )
Local cPath, cKey, xValue, hAttrib, xAttribValue
cPath   := aXmlOneRow [ 1 ]
cKey    := aXmlOneRow [ 2 ]
xValue  := aXmlOneRow [ 3 ]
hAttrib := aXmlOneRow [ 4 ]
****** DO CASE for the Request.xml file structure ********
DO CASE
	CASE cKey == "uid" .AND. cPath == "RequestedDoc/invoicesDoc/invoice"
		SELECT invoice
		APPEND BLANK
		REPLACE invoice->uid WITH xValue
	CASE cKey == "vatNumber" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/issuer"
		REPLACE invoice->IssuerVatN WITH xValue
	CASE cKey == "vatNumber" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/counterpart"
		REPLACE invoice->CountVatN WITH xValue
	CASE cKey == "issueDate" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/invoiceHeader"
		REPLACE invoice->issueDate WITH hb_CToD( xValue, "YYYY-MM-DD" )
	CASE cKey == "lineNumber" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/invoiceDetails"
		SELECT invoiceDetails
		APPEND BLANK
		REPLACE invoiceDetails->uid WITH invoice->uid
		REPLACE invoiceDetails->lineNumber WITH Val ( xValue )
	CASE cKey == "netValue" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/invoiceDetails"
		REPLACE invoiceDetails->netValue WITH Val ( xValue )
	CASE cKey == "totalNetValue" .AND. cPath == "RequestedDoc/invoicesDoc/invoice/invoiceSummary"
		SELECT invoice
		REPLACE invoice->totNetVal WITH Val ( xValue )
END CASE
STATIC FUNCTION hb_XMLParser( cXML, lOmitHeader, xFunction )
LOCAL pXML
Default lOmitHeader := .T.
IF hb_StrIsUtf8 ( cXML )
	cXML := hb_utf8ToStr( cXML )
pXML := mxmlLoadString( NIL, cXML, MXML_OPAQUE_CALLBACK )
IF !Empty( pXML )
	IF lOmitHeader
		hb_XMLParser_getnodes( mxmlGetFirstChild( pXML ), xFunction )
		hb_XMLParser_getnodes( pXML, xFunction )
	mxmlDelete( pXML )
STATIC FUNCTION hb_XMLParser_getnodes( pNode, xFunction )
LOCAL cKey, pChild, xResult, xValue, cPrevKey, hAttrib, pParrentNode, cPath
DO WHILE !Empty( pNode )
	IF mxmlGetType( pNode ) == MXML_ELEMENT
		cKey   := mxmlGetElement( pNode )
		pChild := mxmlGetFirstChild( pNode )
		IF hb_mxmlGetAttrsCount ( pNode ) > 0 .AND. !Empty( pChild ) .AND. ( mxmlGetOpaque( pNode ) = CRLF .OR. Empty ( mxmlGetOpaque( pNode ) ) )	//Support nodes with child node and attribute(s) and no value
			cPath := ""
			pParrentNode := mxmlGetParent( pNode )
			IF Left ( cKey, 8 ) == "![CDATA["
				xValue       := hb_StrShrink  ( mxmlGetCDATA ( pNode ), 2 )
				cKey         := mxmlGetElement( mxmlGetParent( pNode ) )
				pParrentNode := mxmlGetParent ( mxmlGetParent( pNode ) )
			DO WHILE !EMPTY ( pParrentNode )
				cPrevkey := mxmlGetElement( pParrentNode )
				IF Left ( cPrevkey, 4 ) <> "?xml"
					cPath := cPrevkey + IF( !Empty( cPath ), "/", "") + cPath
				pParrentNode := mxmlGetParent( pParrentNode )
			ENDDO
			hAttrib := hb_mxmlGetAttrs( pNode )
			IF HB_ISEVALITEM( xFunction )
				Eval( xFunction, { cPath, cKey, Nil, hAttrib } )
		xValue := hb_XMLParser_getnodes( pChild, xFunction )
		IF xValue == NIL
			xValue := mxmlGetOpaque( pNode )
			IF !(xValue == CRLF)
				cPath        := ""
				ENDDO
					Eval( xFunction, { cPath, cKey, xValue, hAttrib } )
				xResult := { cPath, cKey, xValue, hAttrib }
	pNode := mxmlGetNextSibling( pNode )
ENDDO
RETURN xResult
majkll_ns
Re: FROM XML TO DBF
Post by majkll_ns »
I need a help to run given prg.
1. Try build using HMG 3.4.4 IDE
Harbour 3.2.0dev (r1703241902)
C:/Users/mkl/AppData/Local/Temp/hbmk_8buq5p.dir/TEST.o:TEST.c:(.data+0x238): undefined reference to `HB_FUN_MXMLLOADSTRING'
C:/Users/mkl/AppData/Local/Temp/hbmk_8buq5p.dir/TEST.o:TEST.c:(.data+0x268): undefined reference to `HB_FUN_MXMLGETFIRSTCHILD'
C:/Users/mkl/AppData/Local/Temp/hbmk_8buq5p.dir/TEST.o:TEST.c:(.data+0x278): undefined reference to `HB_FUN_MXMLDELETE'
hbmk2[TEST]: Error: Running linker. 1
gcc.exe C:/Users/mkl/AppData/Local/Temp/hbmk_8buq5p.dir/TEST.o
C:/Users/mkl/AppData/Local/Temp/hbmk_8buq5p.dir/hbmk_dx5y41.o
D:/AW23/PROBAXML/_temp.o -pthread -static-libgcc -static-libstdc++
-static -lpthread -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex
-lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage
-lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio
-lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32
-lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug
-lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin
-lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx
-lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon
-lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi
-lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32
-lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib
-Wl,--end-group -oTEST.exe -LC:/hmg344/harbour/lib/win/mingw -LC:/hmg344/lib
hbmk2: Hint: Add option 'hbmxml.hbc' for missing function(s):
mxmlGetNextSibling(), hb_mxmlGetAttrs(), mxmlGetCDATA(),
mxmlGetParent(), mxmlGetOpaque(), hb_mxmlGetAttrsCount(),
mxmlGetElement(), mxmlGetType(), mxmlDelete(), mxmlGetFirstChild(),
mxmlLoadString()
2. after adding libs=hbmxml in # harbour contrib libs section of \HMG244\hmg32.hbc
try to build using HMG 3.4.4 IDE
C:/hmg344/harbour/lib/win/mingw\libhbmxml.a(core.o):core.c:(.text+0xe2): undefined reference to `mxmlIndexDelete'
C:/hmg344/harbour/lib/win/mingw\libhbmxml.a(core.o):core.c:(.text+0x1de): undefined reference to `mxmlRetain'
gcc.exe C:/Users/mkl/AppData/Local/Temp/hbmk_b6qcup.dir/TEST.o
C:/Users/mkl/AppData/Local/Temp/hbmk_b6qcup.dir/hbmk_7v4dl1.o
-pthread -static-libgcc -static-libstdc++ -static -lpthread
-mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph
-lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbmxml
-lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi
-lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd
-lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro
-lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32
-ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32
-lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32
-lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oTEST.exe
3. after adding #include "hbmxml.hbx" in test.prg
HMG Errorlog File
Error BASE/1003 Variable does not exist: MXML_OPAQUE_CALLBACK
Called from HB_XMLPARSER(103)
Called from START(45)
Called from (b)MAIN(19)
Called from _PROCESSINITPROCEDURE(5876)
Called from _ACTIVATEWINDOW(5627)
Called from MAIN(24)
4. after adding #include "hbmxml.hbx" in test.prg
HMG Errorlog File
Error BASE/1001 Undefined function: MXMLLOADSTRING
Called from MXMLLOADSTRING(0)
Called from HB_XMLPARSER(104)
Called from START(46)
Called from (b)MAIN(20)
Called from MAIN(25)
What am I doing wrong??
Re: FROM XML TO DBF
majkll_ns wrote: Wed Feb 15, 2023 1:58 pm
mxmlLoadString()
when want to add a "libs" do NOT use "Prefix" hb
hbmxml.hbc -> libs=mxml
when not found use "path" before "libs"
path=c:\hmg.3.4.4\HARBOUR\contrib\hbmxml
majkll_ns
Re: FROM XML TO DBF
Post by majkll_ns »
5. after puting libs=mxml in # harbour contrib libs section of \HMG244\hmg32.hbc
still get error
Re: FROM XML TO DBF
majkll_ns wrote: Wed Feb 15, 2023 1:58 pm I need a help to run given prg.
mxmlLoadString()
It's quite simple.
As hinted by the linker, just add libs=hbmxml.hbc to your project's configuration file.
You don't need to change anything in hmg32.hbc
The ready-to-use project can be found in the attachment.
majkll_ns.7z
(66.92 KiB) Downloaded 205 times
majkll_ns
Re: FROM XML TO DBF
Post by majkll_ns »
Thank you !!
I didn't know what it mean "just add libs=hbmxml.hbc to your project's configuration file" :)
Just add watter :D
It work fine now.
In a meanwhile, i need to have something, and make own parsing.
Maybe it can help somebody else too.
(in a code, i just show first 100 keys, but once parsing is done you can do whatever)
  appd  = GetStartUpFolder()+'\'
  mcrlf = chr(13)+chr(10)
  DEFINE WINDOW mainf;
    AT 140,300 ;
    WIDTH 1200 ;
    HEIGHT 750 ;
    TITLE 'ViewXML';
    MAIN
  	DEFINE MAIN MENU
        POPUP "View"
            ITEM "ViewXML" ACTION viewXml()
        END POPUP
    END MENU
	DEFINE EDITBOX Edit_1
      row 20
      col 20
      WIDTH  1100
	  HEIGHT 500
      FONTNAME "Courier"
      FONTSIZE 12
      VISIBLE .t.
	  VALUE ' '
      hscrollbar .f.
    END EDITBOX
  end window
  Mainf.Center
  mainf.Activate
procedure ViewXML()
fn := Getfile ( { {'XML','*.xml'} } , 'Open file' , appd , .f. )
if empty(fn)
  return
yxml := filestr(fn)
// xml_keys  is  array of elements {key, value, keypath}
xml_keys := parseXML(yxml)
estr    = ''
show_key = min(len(xml_keys), 100)
for xi=1 to show_key
  xml_e = xml_keys[xi]
  m_key = xml_e[1]
  m_val = xml_e[2]
  m_pat = xml_e[3]
  estr = estr+ ppad(m_key,20)+' '+ ppad(m_val,20)+' '+ppad(m_pat,70) + mcrlf
  mainf.edit_1.value:= estr
next xi
do events
return
function parseXML( yxml)
// return  array of elements {key, value, keypath}
xml_at  = 0    // parsing is done to this point
xml_lvl = 1    // key level
xml_do = .t.   // there is more to do
declare xml_path[100]  // store path in a way to key
afill(xml_path,'')
xml_ret = {}
do while xml_do
  p1 = xml_findkey(yxml, xml_at, xml_lvl)
  xml_lvl = p1[1]
  xml_typ = p1[2]
  xml_key = p1[3]
  xml_val = p1[4]
  xml_at  = p1[5]
  if xml_typ='V'  // add value to result
    xml_p =''
    for xi=1 to xml_lvl  // build path
      xml_p := xml_p + '/'+xml_path[xi]
    next xi
    xml_el = { xml_key, xml_val, xml_p}
    aadd(xml_ret, xml_el)
    DO EVENTS
  if p1[2]='-'
    xml_do = .f.
enddo
return xml_ret
function xml_findkey(xstr, xpos, xxml_lvl)
//                  <key     >value</key>
//  position        m1  m2a  m2    m3   m4
local m1, m2, m2a, m3, m4
local kyx, kyv, yt1, chm2
local yxml_at, ytyp, ykey
m1 = hb_at('<',xstr,xpos)
m2 = hb_at('>',xstr,m1+1,m1+1000)
m2a= hb_at(' ',xstr,m1+1,m1+1000)
m3 = hb_at('<',xstr,m2+1)
m4 = hb_at('>',xstr,m3+1)
chm2 = substr(xstr,m2-1,1)
if m1=0 .or. m2=0
  return {0, '-', '', '', -1}
if m2a=0
  m2a=m2
  if m2<m2a
    m2a=m2
duz= m2a-m1-1
ykey   = substr(xstr,m1+1,duz)
yvalue = ''
do case
  case substr(ykey,1,1)=chr(63)
    ytyp     = 'Z'
    yxml_lvl = xxml_lvl
    yxml_at  = m2+1
  case substr(ykey,1,1)='/'
    ytyp='E'
    yxml_lvl = xxml_lvl -1
    yxml_at  = m2+1
  otherwise
    // is value here
    if chm2 = '/'
      yvalue   = substr(xstr, m2a, m2-m2a-1)
      ytyp     = 'V'
      yxml_at  = m2+1
      yxml_lvl = xxml_lvl
    elseif substr(xstr,m3,duz+2)='</'+ykey
      yvalue   = substr(xstr, m2+1, m3-m2-1)
      ytyp     = 'V'
      yxml_at  = m4+1
      yxml_lvl = xxml_lvl
      ytyp='B'
      yxml_lvl = xxml_lvl +1
      xml_path[yxml_lvl]=ykey
      yxml_at  = m2+1
endcase
return {yxml_lvl, ytyp, ykey, yvalue, yxml_at}
FUNCTION PPAD(s,x)
return left(s+space(x),x)
tomtagaris
Re: FROM XML TO DBF
Post by tomtagaris »
LITLE HELP
online Service A.A.D.E. "Business Registry Basic Information Search"
The WSDL / ENDPOINT / XSD of the upgraded service are:
WSDL : https://www1.gsis.gr/wsaade/RgWsPublic2 ... blic2?WSDL
ENDPOINT: https://www1.gsis.gr/wsaade/RgWsPublic2/RgWsPublic2
XSD : https://www1.gsis.gr/wsaade/RgWsPublic2 ... lic2?xsd=1
This is a Soap JAX-WS 2.0 Web Service (SOAP version 1.2).
For a workstation to call the service, network access to www1.gsis.gr and port 443 is required.
If Java is used, Java 1.8 or later is required due to the use of the TLS1.2 communication protocol.
Included:
a) call examples (Request XML / Response XML) of the Web Service,
b) a SoapUI project to import into SoapUI. Recommended to use SoapUI Version 5.4.0 or later due to Java 1.8 ( https://www.soapui.org/downloads/latest-release.html ).
mjaviergutierrez
DBs Used: DBF, MySQL
Re: FROM XML TO DBF
Post by mjaviergutierrez »
Hola Colegas !
Probando el programa "XmlToPrg", no logro leer el archivo .xml que adjunto.
No sé, ya revise todo , lo unico que me hace ruido es que el archivo comienza con esta linea :
<?xml version="1.0" encoding="ISO-8859-1"?>
será por esa codificacion que no se puede leer ?
Saludos.
Jornada-0019.zip
(6.67 KiB) Downloaded 152 times
Re: FROM XML TO DBF
You're right in your guess.
If the XML file is encoded in a code page other than the current code page of the HMG application, it is necessary to convert the XML character string to a code page compatible with the current one.
This version of the program gets the encoding from the declaration contained in XML, compares the code pages and, if necessary, converts the XML.
Important, if you want to use this solution in your sources, do not forget to include all code pages in prg:
#include "hbextcdp.ch"
XmlToPrg.7z
(3.32 KiB) Downloaded 222 times
mjaviergutierrez
Re: FROM XML TO DBF
hola Colegas ! Muchas gracas "edk" , funciono Ok !
Gracias, saludos.
