How to execute a google/yahoo/duckduck search from command line, or Harbour?
HGAutomator
Re: How to execute a google/yahoo/duckduck search from command line, or Harbour?
Post by HGAutomator »
No. No. That's one of the things that I'm trying to say, Serge. It really doesn't work.
First,
EXECUTE FILE isn't understood by the compiler. _HB_FUN__EXECUTE is reported as an unresolved external, when the application is compiled as a console app.
In fact, I can't even find EXECUTE FILE defined anywhere. I did a global search through all the .CH files, and it's nowhere in the Minigui distribution.
Second,
Yesterday I was able to include ShellExecute (although I don't recall how). However, when the application is run, the text mode/console menu doesn't display.
Right now, I can't figure out how to include ShellExecute. It's reported as undefined.
At any rate, Pete's solution worked perfectly. It uses standard HB_RUN().
https://drive.google.com/file/d/126Z-Kf ... sp=sharing
serge_girard wrote: Wed Aug 31, 2022 3:26 pm HGAut
What is text-mode app? You mean DOS screen? Then this works:
FUNCTION Main
REQUEST HB_GT_WIN_DEFAULT
cAPP := 'c:\Progra~1\Google\Chrome\Application\chrome.exe '
EXECUTE FILE "&cAPP "  PARAMETERS 'www.google.com/search?q=what+the'
return
hansmarc
Post by hansmarc »
Hi hmg'ers,
some information concerning 'Execute File' and 'ShellExecute' for those who are interested.
'Execute file' is translated by \minigui\include\i_exec.ch to 'WaitRunTerm' or '_Execute'.
The source of '_Execute' can be found in \minigui\source\h_winapimisc.prg.
And '_Execute' calls 'ShellExecute' that you can find in \minigui\source\c_winapimisc.c
This function is compiled in \minigui\harbour\lib\hbwin.lib.
If you want to use 'Execute file' or 'ShellExecute' include this lib when you compile your program.
Hans
HGAutomator
I see it, thanks Hans. It's defined as 'EXECUTE' with a 'FILE' parameter.
Unfortunately, I already tried linking in the hbwin library. After that compiles, the application runs but it doesn't display anything.
I'll look closer at it, in the debugger. Maybe there's something else that's happening, prior to displaying the menu.
Thanks and regards,
hansmarc wrote: Wed Aug 31, 2022 6:36 pm Hi hmg'ers,
Hans
i´m not a Internet Guru but i "think" you are using "ShellExecuteA()" wrong.
"normal" Files are assassinate with App so it will call EGDE, FireFox or Chrome when got a "http" or "https"
so you need "only" to call URL
this is a Sample how to get "Location" of a Adresse using Google Maps
PROCEDURE ShowMap( cTab )
//  http://maps.google.com/maps?q=Helstorfer%20Str.%207%2030625%20Hannover
LOCAL cURL := "http://maps.google.com/maps?q="
   cURL += STRTRAN( ( TRIM( XPPTEL->STRASSE ) ), " ", "%20" ) + "%20"
   cURL += STRTRAN( ( TRIM( XPPTEL->PLZ ) ), " ", "%20" ) + "%20"
   cURL += STRTRAN( ( TRIM( XPPTEL->STADT ) ), " ", "%20" )
   SHELLOPENFILE( cURL )
here my ""ShellExecuteA()" Function using DllCall
STATIC FUNCTION SHELLOPENFILE( cCmd, cParameter )
LOCAL lSuccess
LOCAL Retvar   := .F.
   IF EMPTY( cCmd )
      RETURN .F.
   lSuccess := DllCall( "SHELL32.DLL", DLL_STDCALL, ;
                        "ShellExecuteA",;
                         0,;
                         "open",;
                         cCmd, ;
                         cParameter,;
                         CURDIR(),;
                         SW_NORMAL )                    // SW_MAXIMIZE
   DO CASE
      CASE lSuccess > 32                                              // Aufruf erfolgreich
         Retvar := .T.
      CASE lSuccess = SE_ERR_NOASSOC                                  // Keine verknpfte Anwendung
         // Falls ShowOpenWithDialog = True, wird der Dialog
         // "™ffnen mit" fr diese Datei angezeigt:
         // Shell "RunDLL32 shell32.dll,OpenAs_RunDLL " & Filename
                  "OpenAs_RunDLL", 0, NIL, cCmd, ;
                  NIL, CURDIR(), SW_NORMAL )                          // SW_MAXIMIZE
         //  Die Auswahlm”glichkeit wird als Erfolg gewertet:
         Retvar := .T.
      OTHERWISE
         // ShellExecute war erfolglos.
         // Boolean-Standardwert False zurckgeben
         Retvar := .F.
   ENDCASE
RETURN Retvar
Jimmy,
Where is DllCall ?
Compile complains....
serge_girard wrote: Thu Sep 01, 2022 5:49 am Where is DllCall ?
oh, sorry ... Xbase++ Syntax
use this for HMG
#xtranslate DllCall => HMG_CallDLL
and DLL_STDCALL -> DLL_OSAPI
Thanks, and this "DLL_STDCALL -> DLL_OSAPI"?
serge_girard wrote: Thu Sep 01, 2022 6:11 am and this "DLL_STDCALL -> DLL_OSAPI"?
i´m getting old ...
it is from c:\hmg.3.4.4\HARBOUR\contrib\hbxpp\dll.ch to use Xbase++ Code under harbour
#define DLL_STDCALL                 0x20
#define DLL_SYSTEM                  0x04
#if defined( __PLATFORM__WINDOWS )
#define DLL_OSAPI                   DLL_STDCALL
#elif defined( __PLATFORM__OS2 )
#define DLL_OSAPI                   DLL_SYSTEM
#else
#define DLL_OSAPI                   DLL_CDECL
#endif
Great, now it works!
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hello, I just saw this thread and I want to comment that I have been able to pass parameters like this:
Execute File "Update_C.exe" Parameters "t"
To run it from the command line I would write:
Update_C /t
