Page 3 of 7
Re: Migration from HMG to HMG Minigui
Posted: Tue Mar 29, 2022 2:30 pm
Grigory,
Is there some list with 'differences' and how to change to alternate syntax or whatever.
Posted: Tue Mar 29, 2022 5:36 pm
by Claudio Ricardo
serge_girard wrote: Tue Mar 29, 2022 2:30 pm Grigory,
I join the request again, I had already done it when (I think Jimmy) requested it a while ago.
Posted: Tue Mar 29, 2022 6:13 pm
by AUGE_OHR
i have "try" to write a Memo what is need to "translate" HMG into MiniGUI Extendet Version
but it is a "long" Memo and still incomplete ... and not all what i wrote is "correct" ( found later other Way)
i attach my Memo, hope it help you
HMG2EXT.ZIP
(1.98 KiB) Downloaded 374 times
Posted: Tue Mar 29, 2022 6:28 pm
Thanks Jimmy and Claudio,
I had much trouble at start but thanks to Grigory resolved. Now testing and some coding is not working yet
(aFrmList := _HMG_SYSDATA [66]) but I have commented the ones that gave problem and now real testing can begin...
But overall fast and easy migration, again MANY thanks to Grigory (and Marc at start!)
Posted: Wed Mar 30, 2022 6:41 am
by gfilatov
Serge,
Yes, of course.
We have the 'Harbour MiniGUI Extended Syntax Extensions' list in the file exdiff.txt in folder \Minigui\Doc :arrow:
IMHO The above file is slightly outdated due to the recent Minigui modifications. :lol:
Posted: Wed Mar 30, 2022 7:00 am
Thanks Grigory ! So much to see and learn.....
Posted: Wed Mar 30, 2022 11:07 am
Grigory,
One more question:
I now have a working program! ONE matter remains:
I used to start my programs from within a .BAT file which deletes a few working files etc.
and finally calls my program with a parameter.
This is done by a shortcut on the desktop which calls the BAT file in its working directory.
Then a DOS screen is opened and then my application is openend (2 screens!). These 2 screen remains
until one of them is closed. Closing (with X) the DOS screen will also close my application.
In my application the closing with X is prohibited (ON INTERACTIVECLOSE) and closing must be done
by pressing ESC which will do some extra tests before closing.
In HMG the DOS screen is opened, my application is openend and the DOS screen closes and then there is
only one way to close the application: ESC
So how to get rid of this DOS screen!
In HMG REQUEST HB_GT_WIN_DEFAULT would do the DOS thing...
Posted: Wed Mar 30, 2022 3:15 pm
by andyglezl
Hi Serge
Hace mucho tiempo yo convertía los .Bat en .Exe y me funcionaba
pero no recuerdo que programa era.
Tal vez este te sirva...
hi serge
A long time ago I converted the .Bat to .Exe and it worked for me
But I don't remember what program it was.
Maybe this will help you...
https://bat2exe.net
Posted: Thu Mar 31, 2022 12:17 am
by AUGE_OHR
hi Serge,
serge_girard wrote: Wed Mar 30, 2022 11:07 am I used to start my programs from within a .BAT file which deletes a few working files etc.
call a *.BAT using a *.LNK will default open DOS-BOX
but you can change DOS-BOX to "minimize"
Attached my DXE_CreateLNK() where you have access to
   oShellLink:ShowCommand
DXE_CreateLNK.ZIP
(967 Bytes) Downloaded 334 times
other Way is a small "Starter-EXE" using ShellOpenFile() API
PROCEDURE MAIN(,cApp,cParameter)
   IF FILE(cApp)
      ShellOpenFile(cApp,,cParameter)
FUNCTION SHELLOPENFILE( cPath, cFILE, cPara, cHome )
      lSuccess := ShellExecute( 0, ;
                                "open", ;
                                cPath + cFILE, ;
                                cPara, ;
                                cHome, ;
                                SW_HIDE )  // default SW_NORMAL
Posted: Thu Mar 31, 2022 7:57 am
It seems that START application followed by EXIT will START my APP.EXE and then force the DOS screen to close.
DEL  C:\MYFOLDER\SOMEFILES..
START C:\MYFOLDER\MYAPP somePARAMETER
EXIT
This is what I want! Thanks all for helping!
DXE_CreateLink is very interesting!
I use some similar code:
LOCAL WshShell		:= CreateObject("WScript.Shell")
LOCAL DesktopFolder	:= WshShell:SpecialFolders("Desktop")
LOCAL xDEFAULT                := ALLTRIM(DISKNAME() + ":\" + CURDIR() )
IF !FILE(DesktopFolder + "\My_App.lnk")
	FileShortcut := WshShell:CreateShortcut(DesktopFolder + "\My_App.lnk")
	FileShortcut:TargetPath		:= xDEFAULT + "\My_App.BAT"
	FileShortcut:Description	:= "My_App"
	FileShortcut:IconLocation	:= xDEFAULT + "\IMAGES\PROJ.ICO, 0"  //Zero is the index
	FileShortcut:WorkingDirectory := xDEFAULT
	FileShortcut:Save()
