index dbf character numbers
franco
Re: index dbf character numbers
Post by franco »
I have revised EDK`s sample. It is what my problem is.
I changed the starting number with 99999. When starting to enter numbers in text box it does not search one number.
When you hit 9 nothing happens. No scan search.
SET CENTURY ON
SET DATE TO ANSI
DEFINE WINDOW test AT 0 , 0 WIDTH 400 HEIGHT 600 TITLE "Demo" MAIN NOSIZE NOMAXIMIZE;
	ON INIT PrepareDBF()
	@ 20,10 TEXTBOX tSeek WIDTH 120 VALUE "" INPUTMASK "9999999999" ;
        ON CHANGE Iif( ! Empty( test.tSeek.Value ) ,  (DBSEEK ( VAL ( test.tSeek.Value )), test.Browse_1.Value := RecNo()) , Nil )
	@ 70,10 BROWSE Browse_1 ;
      OF test ;
      WIDTH 350 ;
      HEIGHT 430 ;
      FONT "Arial" ;
      SIZE 9 ;
      HEADERS { "Invoice #","Date", "Customer" } ;
      WIDTHS { 120,80, 120 } ;
      WORKAREA INVOICE ;
      FIELDS { "INV_NUMBER", "INV_DATE", "CustomerID" } ;
      ON GOTFOCUS Nil;
      ON CHANGE Nil ;
      ON DBLCLICK Nil ;
      JUSTIFY { 0,0, 0 }
CENTER WINDOW test
ACTIVATE WINDOW test
Function PrepareDBF()
Local aStru := { {"INV_NUMBER", "C", 10, 0}, {"INV_DATE", "D", 8, 0}, {"CustomerID", "N", 10, 0 } }
Local i, k := 99999
IF ! FILE ( "Invoice.dbf" )
	WAIT WINDOW "Preparing invoice.dbf, please wait ..." NOWAIT
	DBCREATE( "Invoice.dbf", aStru )
	USE Invoice.dbf NEW
	*FOR i := 122222 TO 1 STEP -1
for i := k to 999999
		*IF i % 100 = 0
			k++
		*ENDIF
		DO EVENTS
		APPEND BLANK
		REPLACE inv_number WITH AllTrim( Str ( i ) )
		REPLACE inv_date WITH Date() - k
		REPLACE CustomerId WITH hb_RandomInt ( 1, 1000 )
	NEXT i
	WAIT CLEAR
	CLOSE DATA
IF ! FILE ( "Invoice.ntx" )
	USE Invoice.dbf NEW
	WAIT WINDOW "Preparing invoice.ntx, please wait ..." NOWAIT
	INDEX ON Val ( inv_number ) TO Invoice.ntx
	CLOSE DATA
	WAIT CLEAR
SELECT 1
USE Invoice.dbf Index Invoice.ntx
All The Best,
Franco
Canada
hi franco,
franco wrote: Fri Jun 11, 2021 4:14 pm I have revised EDK`s sample. It is what my problem is.
can you provide a small DBF, not Code, so we got "same DBF" Sample to talk
you want to search in BROWSE ... how :?:
... do you want to search "increment" :idea:
let say cPrefix is 555B and you press 999
normal Index work ASCENDING ...
555Bxxx999YYYYMMDD
555Bxx999xYYYYMMDD
555Bx999xxYYYYMMDD
555B999xxxYYYYMMDD
but sometimes it is better to use DESCENDING while "last" have bigger Number
franco
Post by franco »
The code above is similar. In my system I do index descending. I have button to reindex. If ascending index descending and vice versa.
My problem is when index is numeric it looks good but can not seek one number at a time.
I think this is incremental search numeric.
All The Best,
Franco
Canada
franco wrote: Fri Jun 11, 2021 7:22 pm My problem is when index is numeric it looks good but can not seek one number at a time.
i had look at my Sample and saw that BROWSE
need SET BROWSESYNC ON
have no ONKEY :o
so how to get "input" for "increment search" when have no ONKEY for BROWSE :idea:
Sample for BROWSE using SCOPE and FILTER
viewtopic.php?f=5&t=6940
franco
Post by franco »
I find you can not seek part of a numeric value only all of the value.
if value of textbox is 1. if there is not a value of 1 in table, it will not find and changes the textbox value back to " ".
I am going to work on the substr(alltrim( and see what I get.
All The Best,
Franco
Canada
Check this code:
test.7z
(1.35 KiB) Downloaded 111 times
franco
Post by franco »
Edk, I spent some time trying to get your program to set focus to text box directly after search so it goes right to number and is ready for
another entry. It would speed up the search.
like enter 9 then 9 so seek would be 99, then enter 1 seek would be 991 automatically without pressing button. Then by pressing enter or dblclick grid to set the table for a calling program to make use of.
Also it would be goo if we could make the grid veiw to be substr(inv_number,5,8 ).
All The Best,
Franco
Canada
franco wrote: Sun Jun 13, 2021 11:24 pm Edk, I spent some time trying to get your program to set focus to text box directly after search so it goes right to number and is ready for another entry. It would speed up the search.
this is IHMO not the Way.
you need ONKEY with GRID
do you want to work with DBF or ARRAY ?
Edward show you a "virtual" GRID which need Array
franco wrote: Sun Jun 13, 2021 11:24 pm like enter 9 then 9 so seek would be 99, then enter 1 seek would be 991 automatically without pressing button.
so what is your Problem
LOCAL xValue := HMG_GetLastVirtualKeyDown()
LOCAL Old_Value := SEEKNUM.Text_1.VALUE
      cValue := CHR(xValue)
      IF cValue $ "0123456789"
         Old_Value := Old_Value + cValue
         SEEKNUM.Text_1.VALUE := Old_Value
         Do_Seek(.T.)
franco wrote: Sun Jun 13, 2021 11:24 pm Then by pressing enter or dblclick grid to set the table for a calling program to make use of.
remember navigation in "virtual" GRID does not move Record Pointer of DBF
franco wrote: Sun Jun 13, 2021 11:24 pm Also it would be goo if we could make the grid veiw to be substr(inv_number,5,8 ).
      ELSEIF xValue = VK_BACK .or. xValue = VK_DELETE
         IF LEN(Old_Value) > 0
            Old_Value := SUBSTR(Old_Value,1,LEN(Old_Value)-1)
            SEEKNUM.Text_1.VALUE := ""
         Do_Seek(.T.)
franco
Post by franco »
Thank you all for the help.
I am using browse not grid.
We have spent enough time on this. I am going to leave as it was for now.
It is inconvenient to see list.
1000
10001
1001
10002
1002
It is what it is.
Thanks again
Franco
All The Best,
Franco
Canada
hi
franco wrote: Tue Jun 15, 2021 4:53 pm It is inconvenient to see list.
1000
10001
1001
10002
1002
It is what it is.
Numeric are right align while Character are left align
when using Numeric as Character you must right align to get sort Order
if you have a "Prefix" i recommend to use seperate FIELD
it make it more easy to work with SCOPE, FILTER and OrdwildSeek()
SCOPE work on Index for Prefix
FILTER can be very slow ... but with SCOPE Data are reduce
OrdWildSeek() work like LOCATE but on Index so it is faster
   SEEK( cPrefix )
   IF FOUND()
      SET SCOPEBOTTOM TO ( cPrefix )
      SET SCOPETOP TO ( cPrefix )
   IF !EMPTY( cFilter )
      GO TOP
      * LOCATE FOR cFilter $ LTRIM( STR( SEEKNUM->INVOICE ) )
      cSeek := cPrefix
      cSeek += "*" + cFilter + "*"
      OrdWildSeek( cSeek )
      SET FILTER TO ( cFilter $ LTRIM( STR( SEEKNUM->INVOICE ) ) )
      SET FILTER TO
