HMG Beginner
vierirom
Re: HMG Beginner
Post by vierirom »
Hi Danielmaximiliano
I did some tryes and found that it doesn't care if you put the line run=no or run=yes or omit the line in IDE CONFIGURATION TAB.
The HMG IDE runs the application in any case at the end of compilation.
It seems it doesn't use build.bat to run the application.
I think that only Rathinagiri could have an answer for that behaviour.
Thank you in any case for the answer.
Vieri
Re: HMG Beginner
vierirom wrote:Hi Danielmaximiliano
Vieri
HMG IDE using build.bat, you can modify these lines to see and understand its use.
rem ******************************************************************************
rem CALL HBMK2
rem The the fourth parameter
rem -gt<name>           link with GT<name> GT driver, can be repeated to link
rem                     with more GTs. First one will be the default at runtime
if "%runafterbuild%" == ".t." (
Echo Run > run.txt
Echo %*  >> run.txt
Echo %runafterbuild% >> Run.txt
HBMK2 -o%~n1.exe %HMGPATH%\hmg.hbc -q %gtdrivers% %debug%  %1 %2 %3 %4 %5 %6 %7 %8  >hbmk.log 2>&1
) ELSE (
Echo NoRun > NoRun.txt
Echo %*  >> NoRun.txt
Echo %runafterbuild% >> NoRun.txt
HBMK2 -o%~n1.exe -q  -norun %HMGPATH%\hmg.hbc %gtdrivers% %debug%  %1 %2 %3 %4 %5 %6 %7 %8 >hbmk.log 2>&1
rem CREATE LOGS
there is a problem of options passed to HBMK2
Harbour Make (hbmk2) 3.1.0dev (Rev. 17111)
Copyright (c) 1999-2011, Viktor Szakats
http://harbour-project.org/
Syntax:
  hbmk2 [options] [<script[s]>] <src[s][.prg|.c|.obj|.o|.rc|.res|.def|.po|.pot|.hbl|@.clp|.d]>
Options:
-[no]run            run/do not run output executable
I'm looking and trying to understand this option as it really
vierirom
Re: HMG Beginner
Post by vierirom »
I made some more in deep investigation....
The HMG IDE runs the executable AFTER completing the execution of build.bat.
It ALWAYS passes " /n" as first parameter to build.bat, so , leaving build.bat as is, build.bat NEVER runs the executable.
If you comment out ("rem") the line :
rem if "%runafterbuild%"==".t." if exist %~n1.exe %~n1.exe
and put two more lines after:
if exist %~n1.exe copy /y %~n1.exe %destexe%\%~n1.exe > nul
if exist %destexe%\%~n1.exe %destexe%\%~n1.exe
The executable runs from %destexe% folder.
(I manually added a set definition in the first lines of build.bat "set destexe=C:\HARBAPP\WORKING_FOLDER")
This way the ececutable runs from build.bat.
As soon as you close the executable it starts again (this time launched from HMG IDE).
What seems to appear is that build.bat is used from HMG IDE but never starts the application when used by the IDE.
Ciao
Vieri
Re: HMG Beginner
Ciao
Vieri
The executable runs HBMK2 account, please copy build.bat to keep the original content and then delete all lines after the line HBMK2
@echo off
rem SYNTAX
rem	build [ /n ] [ /d ] [ /c ] <program.prg> | <project.hbp> [<hbmk2 params>]
rem
rem	/n	no run after build
rem	/d	enabled debugger
rem	/c	console mode
rem
rem
rem	This batch file passes information to hbmk2 to make possible an easy (zero
rem	configuration build of HMG applications).
rem
rem	You can achieve a customized build passing parameters directly to hbmk2.
rem	Please, take a look at hbmk2 help:
rem
rem	hbmk2 --help
rem SET DEFAULT OPTIONS
	set gtdrivers=-gtgui -gtwin
	set runafterbuild=.t.
	set debug=
rem DELETE FILES FROM PREVIOUS BUILD
	if exist build.log del build.log
	if exist error.log del error.log
rem SET HMGPATH
rem
rem Using %~dp0 the HMGPATH is automatically set to current (hmg) folder making it
rem portable (zero config)
	SET HMGPATH=%~dp0
rem SET BINARIES PATHS
rem PROCESS PARAMETERS
rem
rem	/c	console mode
rem
	if "%1"=="/n" set runafterbuild=.f.
	if "%1"=="/n" shift
	if "%1"=="/d" set gtdrivers=-gtwin -gtgui
	if "%1"=="/d" set debug=-b
	if "%1"=="/d" echo options norunatstartup > init.cld
	if "%1"=="/d" shift
	if "%1"=="/c" set gtdrivers=-gtwin -gtgui
	if "%1"=="/c" shift
rem COMPILE RESOURCES
	echo #define HMGRPATH %HmgPath%\RESOURCES > _hmg_resconfig.h
	COPY /b %HMGPATH%\resources\hmg.rc+%~n1.rc+%HMGPATH%\resources\filler _temp.rc >NUL
	windres -i _temp.rc -o _temp.o >windres.log 2>&1
rem SET PROJECT OUTPUT FILE NAME
rem
rem The first parameter sent to hbmk2 is -o%~n1.exe. I've added to it create the
rem application with the project basename (<projectname.hbp> specified by the user.
rem SET DEFAULT CONFIGURATION FILE
rem
rem The second parameter sent to hbmk2 is the hmg.hbc script to set config required.
rem SET QUIET MODE
rem
rem The third parameter sent to hbmk2 is -q (Harbour quiet mode)
rem CALL HBMK2
Echo Run > run.txt
Echo %*  >> run.txt
) ELSE (
REM EOF Build.bat
vierirom
Re: HMG Beginner
Post by vierirom »
No. It's not the HBMK2 Line that starts the appllication.
I already tried that way.
The application start anyway AFTER HBMK2 has completing his task.
If you Put a "Pause" after the line of HBMK2 you'll see what I mean.
Thank you for your Replay.
Vieri
Re: HMG Beginner
Vieri
In my case, HBMK2 is running the application I'm compiling.
after modifying build.bat as previously published application runs.
not know why your build.bat is different because it is the same version of HMG.
HMG.3.0.40
Harbour compiler
Administrador Cwindowssystem32cmd.png (111.99 KiB) Viewed 6804 times
can test the modification made ​​by me to check.
vierirom
Re: HMG Beginner
Post by vierirom »
I copy The same Lines (those belonging to HBMK2 Execution).
The .txt response files is the same as your.
So Runafterbuild = .f. (as it apper from norun.txt)
NoRun
/n C:\HARBAPP\AUTOMAN2\AUTOMAN2.hbp C:\HARBAPP\AUTOMAN2\AUTOMAN2.hbc
.f.
The application starts after building.... as before
The problem remains the same.
I don't Know why the IDE starts the application
Could be a good Idea if someone else reports his behaviour of the IDE.
Are you shure you are using HMG 3.0.40 IDE ?
Thank you for your intersting
Vieri
vierirom
Re: HMG Beginner
Post by vierirom »
Hi Danilemaximiliano
one more thing....
double seeing your build.bat I observe that it's not EXACTLY same as mine.
Following is an exact copy of the original Build.bat
@echo off
rem SYNTAX
rem
rem /c console mode
rem
rem
rem
rem
rem hbmk2 --help
set debug=
rem SET HMGPATH
rem
SET HMGPATH=%~dp0
rem
rem /c console mode
rem
if "%1"=="/n" shift
if "%1"=="/d" shift
if "%1"=="/c" shift
rem
rem
rem SET QUIET MODE
rem
rem CALL HBMK2
HBMK2 -o%~n1.exe %HMGPATH%\hmg.hbc %gtdrivers% %debug% -q %1 %2 %3 %4 %5 %6 %7 %8 >hbmk.log 2>&1
rem CREATE LOGS
if errorlevel 1 if exist windres.log copy /a windres.log+hbmk.log error.log >nul
if errorlevel 1 if not exist windres.log copy /a hbmk.log error.log >nul
if errorlevel 0 if exist windres.log copy /a windres.log+hbmk.log build.log >nul
if errorlevel 0 if not exist windres.log copy /a hbmk.log build.log >nul
rem CLEANUP
if exist windres.log del windres.log
if exist hbmk.log del hbmk.log
if exist _hmg_resconfig.h del _hmg_resconfig.h
if exist _temp.rc del _temp.rc
if exist _temp.o del _temp.o
rem SHOW LOG
if exist error.log type error.log
if exist build.log type build.log
rem RUN APPLICATION
The differences are in the HBMK2 Line
and there is no "fourth parameter"
In any case this doesn't change the Ide beahviour (.. mean it launches the application AFTER build, AFTER the complete execution of all build.bat)
Thank you
