Posts: 2117 Joined: Sun Aug 25, 2019 3:12 pm
Post
by AUGE_OHR » Sun May 02, 2021 10:19 am
chrisjx2002 wrote: ↑ Sun May 02, 2021 8:13 am
I uninstall and reinstall vlc. Always the same problem. I take a look in the registry and I find :
Ordinateur\HKEY_CLASSES_ROOT\
TypeLib \{DF2BBE39-40A8-433B-A279-073F48DA94B6}\1.0\0\win64
Not the same as yours.
you show me your "TypeLib" but i like to see "CLSID" and "ProgID"
Computer\HKEY_CLASSES_ROOT\CLSID \{9BE31822-FDAD-461B-AD51-BE1D1C159921}\ProgID
so search for 9BE31822-FDAD-461B-AD51-BE1D1C159921
which VLC Version did you install
have you "check" Option AciveX & WebPlugin when Install VLC
older x64 IMHO did not work but that Version 3.0.13 ( 3.0.12 ) did work for me under 64 Bit
Post
by AUGE_OHR » Mon May 03, 2021 9:06 pm
chrisjx2002 wrote: ↑ Mon May 03, 2021 4:45 pm
I search for search for 9BE31822-FDAD-461B-AD51-BE1D1C159921. And I find it.
But I have always the same problem. The VLC version is the one you have 3.0.12. I am working with windows 10 64 bits last update.
There is a problem with PLAYLIST
your last Snapshot is what i mean.
it looks all OK ... hm
can you "open" Registry Tree of last Snapshot to see what is in "ProgID"
Line 282 show this
IMHO it does not work while oControl fail, not :playlist
i guess ActiveX is not create ... hm
try this
::oControl := oControl
IF EMPTY(oControl)
MsgInfo("VLC not correct installed")
QUIT
::oPlaylist := oControl:playlist
in Source Code you can change
to
"{9BE31822-FDAD-461B-AD51-BE1D1C159921}"
and try it again
did 32 bit Version work
chrisjx2002
Posts: 192 Joined: Wed Jan 06, 2010 5:39 pm
Post
by chrisjx2002 » Tue May 04, 2021 8:22 am
I try again.
With 32 bit version it works!
With 64 bits always problem. I try with "{9BE31822-FDAD-461B-AD51-BE1D1C159921}"instead of "VideoLAN.VLCPlugin.2". Same problem.
When I change the code, I have not the message "VLC not correct installed" but the same error. See screnshot.
I search the progid in regedit. See screenshot.
vlc progid.jpg (71.82 KiB) Viewed 9678 times
Post
by AUGE_OHR » Tue May 04, 2021 9:54 am
chrisjx2002 wrote: ↑ Tue May 04, 2021 8:22 am
mystery ... 32 Bit is working and 64 Registry "seem" OK but does not work ...
try to change
IF EMPTY(oControl)
QUIT
into
IF VALTYPE(oControl) <> "O"
MsgInfo("VLC Object was not create")
QUIT
if you now get MsgInfo() than ACTIVEX Object was not create ... but i don´t know why
... ANSI or UNICODE IDE
chrisjx2002
Post
by chrisjx2002 » Tue May 04, 2021 4:05 pm
I made the test. I don't have the msginfo but the same error. Very strange.
Posts: 1461 Joined: Fri Oct 26, 2012 7:58 pm
Post
by andyglezl » Tue May 04, 2021 5:52 pm
Aquí, solo probando...
No tengo instalado el VLC !. (Win10/64)
Here, just testing ...
I don't have VLC installed !. (Win10/64)
chrisjx2002
Post
by chrisjx2002 » Wed May 05, 2021 12:18 pm
I have perhaps found the problem. I compile with hmg 32 bits and not 64 bits. It is probably why it does not work.
chrisjx2002
Post
by chrisjx2002 » Wed May 05, 2021 5:14 pm
Got it! It was a problem of 64 bits compilation. Now it works!
Post
by AUGE_OHR » Thu May 06, 2021 2:39 am
chrisjx2002 wrote: ↑ Wed May 05, 2021 12:18 pm
that can be the Problem when try to use 64 Bit Component with 32 Bit
