HMG New Version in GitHub
Re: HMG New Version in GitHub
bpd2000 wrote: Tue Jul 14, 2020 4:30 am BCC is commercial product and not under GPL
HMG is under GPL so we are not using BCC
ooohh ... i thought BCC v5.x are free
sorry i´m still a harbour Newbie
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi @AUGE_OHR,
AUGE_OHR wrote: Tue Jul 14, 2020 10:52 pm hi,
Yes, Borlad Compilers 5.5x and 5.8x are free.
Look at this post : http://mail.hmgforum.com/viewtopic.php?t=6294
Salamandra, Brazil
When it comes to "free software", it is not that the price is free, but it is software that is open source that can be copied, modified and redistributed.
"Free software" can be sold, a price can be charged for it, but sources must always be provided .
BCC is proprietary closed source software, sources cannot be accessed or modified. BCC is freeware but not "free software".
OK understand.
i have made some enhancement on Debugger Code
http://www.hmgforum.com/viewtopic.php?f ... 73&p=59910
i like to request to use modification in next Release
You can submit the source code (after verifying yourself for bugs) yourself please.
franco
Post by franco »
All The Best,
Franco
Canada
Anand
Post by Anand »
Very good news and using 'Actions' of GitHub will make it much easier for all developers of HMG.
Anand
Anand
Carlos Britos
Post by Carlos Britos »
If you are interested there is a pull request from https://github.com/asistex/HMG
changes are:
- remove space at end of lines in prg files.
- harbour functions names lower and upper case follow the harbour standard.
- pacified harbour warning +-380 ( -w3 ) There are still 4 to check.
The code was tested with severals samples but need more.
You can test it from my fork before merge it with the original. You must create the binary hmg.lib
Carlos
Rathinagiri wrote: Wed Jul 15, 2020 7:17 am You can submit the source code (after verifying yourself for bugs) yourself please.
i´m still a Newbie and have not work with Github before.
when i "think" a have found a BUG and made some Correction how to share Code :idea:
i have made some enhance in HMG Debugger e.g. use BEGIN SEQUENCE to avoid crash.
i´m old school and don´t use Version-Control System ... i compare manual e.g. with Windiff
when using Github to synchronize (how :idea: ) Source how do i know "what" was override :?:
If you are sure enough your code is good, you can submit here also. I will try to review and submit myself.
