files on external drives
Re: files on external drives
hi edk <--- :idea:
Works great for backing up from one folder to another
I have put this little change the rest the same, Everything Ok!
*Local cFile1:= "C:\BOOKS\AUTHORS.dbf"
*Local cFile2:= "E:\BOOKS\AUTHORS.dbf"
 Local cFile1 := HB_Curdrive() +":\"+Rtrim(Curdir() ) + "\"+"Facturas_PdF\TRANS.DBF"
 Local cFile2 := HB_Curdrive() +":\"+Rtrim(Curdir() ) + "\"+"Control_Back\TRANS.DBF"
 Local nSuccess
CLOSE DATA
IF !File ( cFile1 )
	MsgStop ( " .......
thanks for the Sample
Templar
Post by Templar »
This is very odd! So I get a failure and for everybody else it works!
I know that it is copying the files ok, because I can see them in File explorer; it just doesn't want to open them.
I'm using Windows10; is everyone else?
Templar
W7 works fine!
franco
Post by franco »
Templar,
I still do everything old school, lack of time to learn a lot of new coding
Your table must have 1 record and data in first two fields.
a:= getcurrentfolder()+'\acmotor.dbf' //acmotor is your table name
b:= 'd:\acmotor1.dbf'
copy file &a to &b
select 0
use &a alias ta
select 0
use &b alias tb
select ta // c drive table
c:=field(1)
msgbox(&c)
select tb // d drive table
d:=field(2)
msgbox(&d)
return
This works 3.44 Windows10
Everyone stay safe .
Franco
All The Best,
Franco
Canada
Templar wrote: Thu Apr 02, 2020 2:33 pm This is very odd! So I get a failure and for everybody else it works!
you seems to have a Strange Problem that can not be reproduce. :roll:
so i recommend to test same on other Hardware if you App work OK.
