use FMG more than once
Re: use FMG more than once
mmmm...
Senti curiosidad por el manejo de las formas FMG y me puse a la tarea de ver como funcionaban.
Pero resulta que como nunca las había manejado, no sabía de donde salian, y veo que el IDE de HMG
las genera, pero como tampoco nunca he manejado el IDE, pues quede en las mismas.
Tomando como base el ejemplo compartido por EDK, (Gracias !)
( https://www.hmgforum.com/viewtopic.php? ... 105#p60105 )
empece a programarlo de la forma en que yo lo se hacer y pues esto resulto.
P.D. Tengo el problema de que al dar doble click en el GRID, deja de funcionar el ratón en el mismo GRID.
Si señalo con el ratón y oprimo la tecla ENTER, si funciona bien.
(Se tratara de un bug ?)
A ver si alguien le encuentra solución y nos la comparte. ;)
mmm...
I was curious about the handling of FMG forms and I
put the task to see how they worked.
But it turns out that since I had never handled them, I didn't know where they came from, and I see that the HMG
IDE generates them, but neither have I ever managed the IDE, then stay in them.
Based on the example shared by EDK, (Thanks !)
I started to program it the way I know how to do it, and this resulted.
P.S. I have the problem that by double clicking on the GRID,
the mouse stops working on the same GRID.
If I point the mouse and press the ENTER key, it works fine.
(Is it a bug?)
Let's see if someone finds a solution and shares it with us. ;)
Main.zip
(2.17 KiB) Downloaded 221 times
Andrés,
I sometimes have the same problem and can not find cause and solution. I live with it....
andyglezl wrote: Wed Nov 27, 2019 5:31 am I started to program it the way I know how to do it, and this resulted.
YES, that is the Way i'm searching while User want more than SDI like Cl*pper
i have play with your Sample an include some Textbox.
i play with your Array and can "load" from Array an "store" it to Textbox this Way
PROCEDURE DoStoreData(ChildForm)
LOCAL nRow := Getproperty("FormMain", "Grid_1", "CellRowFocused")
LOCAL cText1,cText2,cText3
   cText1 := GetProperty( "FormMain","Grid_1", "Cell", nRow, 1 )
   cText2 := GetProperty( "FormMain","Grid_1", "Cell", nRow, 2 )
   cText3 := GetProperty( "FormMain","Grid_1", "Cell", nRow, 3 )
   SetProperty( ChildForm, "TEXT_1", "Value", cText1 )
   SetProperty( ChildForm, "TEXT_2", "Value", cText2 )
   SetProperty( ChildForm, "TEXT_3", "Value", cText3 )
now the opposite is need to "write-back" but again i got Problem with Syntax
PROCEDURE DoReplaceData(ChildForm,nID)
LOCAL nRow := nID
   cText1 := GetProperty( ChildForm, "TEXT_1", "Value" )
   cText2 := GetProperty( ChildForm, "TEXT_2", "Value" )
   cText3 := GetProperty( ChildForm, "TEXT_3", "Value" )
ALTD()
   // how is the right Syntax
   SetProperty( "FormMain","Grid_1", "Cell", nRow, 1, cText1)
   SetProperty( "FormMain","Grid_1", "Cell", nRow, 2, cText2)
   SetProperty( "FormMain","Grid_1", "Cell", nRow, 3, cText3)
   FormMain.Grid_1.refresh
please have a look into Attachment, Thx
ok have fix it with direct write into Array and Refresh Grid
   // update Array direct
   aRows[nRow][1] := cText1
   aRows[nRow][2] := cText2
   aRows[nRow][3] := cText3
all seems to work ... but Refresh does not show change but i can see it in Debugger that aRows have change it :!:
so why Refresh does not work ... is there a RefreshALL or do i need some Parameter :?:
attached Sample
MAIN02.ZIP
(2.63 KiB) Downloaded 209 times
Change :
* aRows[nRow][1] := cText1
* aRows[nRow][2] := cText2
* aRows[nRow][3] := cText3
FormMain.Grid_1.Cell( nID , 1 ) := cText1
FormMain.Grid_1.Cell( nID , 2 ) := cText2
FormMain.Grid_1.Cell( nID , 3 ) := cText3
or
FormMain.Grid_1.Cell( nID , 1 ) := GetProperty( ChildForm, "TEXT_1", "Value" )
FormMain.Grid_1.Cell( nID , 2 ) := GetProperty( ChildForm, "TEXT_2", "Value" )
FormMain.Grid_1.Cell( nID , 3 ) := GetProperty( ChildForm, "TEXT_3", "Value" )
andyglezl wrote: Thu Nov 28, 2019 3:21 am Change :
or
OK, that work , THX
but i still wonder why Refresh does not work :?:
p.s. how to set Color for one Cell :?:
Alguna idea de porque no se pueden abrir varias ventanas con un FOR-NEXT ?
Tengo que cerrar cada una de ellas para que se pueda abrir la siguiente...
Any idea why you can't open several windows with a FOR-NEXT?
I have to close each of them so that the next one can be opened ...
FUNCTION MultiWin( nCol )
	aNombMulti := { 2, 4, 6, 8 }
	FOR i1 = 1 TO HMG_LEN( aNombMulti )
		ChildForm( aNombMulti[i1] )
		*MSGDEBUG( aNombMulti, aNombMulti[i1] )
//  * Ejemplo de Multiventanas CHILD desde un GRID hecho por AndyGlezL (Andrés González López) 26/NOV/2019
//  * Tomado del Ejemplo compartido por EDK.   https://www.hmgforum.com/viewtopic.php?f=12&t=6209&p=60105#p60105
//  * Example of CHILD Multiwindows from a GRID made by AndyGlezL (Andrés González López) 26/NOV/2019
//  * Taken from the Example shared by EDK.    https://www.hmgforum.com/viewtopic.php?f=12&t=6209&p=60105#p60105
//  * E-mail: andyglezl@hotmail.com   -   dari_disenos@hotmail.com
//  * http://daridisenos.wix.com/dariweb
//  * Desarrollado en HMG 3.4.4                 VIVA HMG !!!
//_______________________________________________________________________________________________________
#define  fColor { || if ( This.CellRowIndex/2 == int(This.CellRowIndex/2) , WHITE , { 235, 245, 245 } ) }
#xtranslate _HMG_aFormNames => _HMG_SYSDATA\[66\]
FUNCTION Main()
   PUBLIC nForm  := 1
   PUBLIC  aRows [20] [3]
      aRows [1]   := {'Simpson','Homer','555-5555'}
      aRows [2]   := {'Mulder','Fox','324-6432'}
      aRows [3]   := {'Smart','Max','432-5892'}
      aRows [4]   := {'Grillo','Pepe','894-2332'}
      aRows [5]   := {'Kirk','James','346-9873'}
      aRows [6]   := {'Barriga','Carlos','394-9654'}
      aRows [7]   := {'Flanders','Ned','435-3211'}
      aRows [8]   := {'Smith','John','123-1234'}
      aRows [9]   := {'Pedemonti','Flavio','000-0000'}
      aRows [10]  := {'Gomez','Juan','583-4832'}
      aRows [11]  := {'Fernandez','Raul','321-4332'}
      aRows [12]  := {'Borges','Javier','326-9430'}
      aRows [13]  := {'Alvarez','Alberto','543-7898'}
      aRows [14]  := {'Gonzalez','Ambo','437-8473'}
      aRows [15]  := {'Batistuta','Gol','485-2843'}
      aRows [16]  := {'Vinazzi','Amigo','394-5983'}
      aRows [17]  := {'Pedemonti','Flavio','534-7984'}
      aRows [18]  := {'Samarbide','Armando','854-7873'}
      aRows [19]  := {'Pradon','Alejandra','???-????'}
      aRows [20]  := {'Reyes','Monica','432-5836'}
   DEFINE WINDOW FormMain AT 0 , 0 WIDTH GetDesktopWidth() HEIGHT GetDesktopHeight()-5 NOSIZE MAIN  BACKCOLOR { 230 , 230 , 250 }
      DEFINE MAIN MENU
         DEFINE POPUP "Menu"
            MENUITEM "Open several Windows" ACTION MultiWin()
            MENUITEM "Exit"      			ACTION ReleaseAllForms()
         END POPUP
      END MENU
      @ 010,010 GRID Grid_1 OF FormMain WIDTH 450 HEIGHT 600 ITEMS aRows FONT "Verdana" SIZE 10 HEADERS { 'Last Name', 'First Name', 'Phone' }  WIDTHS { 140 , 140 , 140 } ;
              VALUE 1 DYNAMICBACKCOLOR { fColor, fColor, fColor } ON DBLCLICK ( ChildForm( GetProperty( "FormMain","Grid_1", "Value" ) ) ) ;
              TOOLTIP "DblClick para Abrir" JUSTIFY { GRID_JTFY_CENTER, GRID_JTFY_RIGHT, GRID_JTFY_RIGHT }
              FOR i1=1 TO 3        // Colores al ENCABEZADO de las 3 Columnas
                 SetProperty( "FormMain", "Grid_1", "HeaderDYNAMICFONT",      i1, { || ARRAY FONT "Consolas" SIZE 12 ITALIC BOLD } )
                 SetProperty( "FormMain", "Grid_1", "HeaderDYNAMICFORECOLOR", i1, { || { 100 , 149 , 237 } } )
              CellNavigationColor( _SELECTEDROW_FORECOLOR, WHITE )   ;  CellNavigationColor( _SELECTEDROW_BACKCOLOR, BLUE )   // Renglon seleccionado
    ACTIVATE WINDOW FormMain
FUNCTION ReleaseAllForms()
   LOCAL i
   FOR i = Len( _HMG_aFormNames ) TO 1 STEP -1        // Ir cerrando las ventanas de la última a la primera
      IF IsWindowDefined( &( _HMG_aFormNames [i] ) )
         DoMethod( _HMG_aFormNames [i], "Release")
   NEXT i
FUNCTION ChildForm( nIndexRow )
   LOCAL ChildForm :="ChildForm_", i
   cNombre :=  GetProperty( "FormMain","Grid_1", "Cell", nIndexRow, 1 ) + "  " +  ;
               GetProperty( "FormMain","Grid_1", "Cell", nIndexRow, 2 ) + "  " +  ;
               GetProperty( "FormMain","Grid_1", "Cell", nIndexRow, 3 )
   ChildForm := hb_StrReplace( cNombre, { ' ' => '', '-' => '', '?' => '' } )    // Dejo ChildForm sin espacios o carateres "raros"
   IF ! IsWindowDefined( &( ChildForm ) )
      DEFINE WINDOW &ChildForm AT 0 , 0 WIDTH 550 HEIGHT 350 CHILD NOSIZE NOMINIMIZE NOMAXIMIZE ;
			 ON INIT DoStoreData(ChildForm)
         @ 000 , 000 LABEL Label_1 OF &ChildForm VALUE "Simple context Menu of Grid" WIDTH 550 HEIGHT 20 FONT 'Arial' SIZE 9 CENTERALIGN
         SetProperty( ChildForm, "Title", "#" +  Alltrim( Str( nForm )+SPACE(15)+cNombre ) )
         SetProperty( ChildForm, "Col", 440 + (25 * nForm ) )
         SetProperty( ChildForm, "Row", 30  + (25 * nForm ) )
         nForm ++
         @ 060,125 TEXTBOX TEXT_1 ;
           MAXLENGTH 40
         @ 090,125 TEXTBOX TEXT_2 ;
           MAXLENGTH 40
         @ 120,125 TEXTBOX TEXT_3 ;
           MAXLENGTH 40
         @ 150,125 BUTTON SaveButton ;
            PARENT ChildForm         ;
            CAPTION "&Save"          ;
            WIDTH   40               ;
            HEIGHT  40               ;
            ONCLICK DoReplaceData(ChildForm,nIndexRow)
      ACTIVATE WINDOW &ChildForm
      FOR i = 1 TO Len( _HMG_aFormNames )
         IF ChildForm = GetProperty( _HMG_aFormNames[i], "Title" )
            DoMethod( ChildForm, "SetFocus")
            EXIT
      NEXT i
	LOCAL nRow := Getproperty("FormMain", "Grid_1", "Value")
	SetProperty( ChildForm, "TEXT_1", "Value", GetProperty( "FormMain","Grid_1", "Cell", nRow, 1 ) )
	SetProperty( ChildForm, "TEXT_2", "Value", GetProperty( "FormMain","Grid_1", "Cell", nRow, 2 ) )
	SetProperty( ChildForm, "TEXT_3", "Value", GetProperty( "FormMain","Grid_1", "Cell", nRow, 3 ) )
	DoMethod( ChildForm, "Release")
FUNCTION MultiWin(  )
Hola
Seguí "jugando" con esto de los MultiForms...
HI
I kept "playing" with this MultiForms ...
MySystem.zip
(4.19 MiB) Downloaded 224 times
Confirmado: "Problemas con el Mouse"
Hay "algo" que al crear las ventanas CHILD, queda "desactivado".
Y mientras alguna de ellas quede activa, no lo libera.
(Qué y porqué ? No lo se todavia...)
Confirmed: "Problems with the Mouse"
There is "something" that when creating the CHILD windows, is "disabled".
And as long as one of them is active, it does not release it.
(What and why? I don't know yet...)
(dblclick creates a CHILD window)
"I sometimes have the same problem and can not find cause and solution. I live with it...."
Any idea why you can't open several windows (CHILD) with a FOR-NEXT?
Algo que podamos hacer ?????
Something we can do ?????
