Login to website
tomtagaris
Re: Login to website
Post by tomtagaris »
i send file
tomresp.zip
(389 Bytes) Downloaded 210 times
Strange, this response should not generate an error.
Please, show the piece of code with the line numbers where this error occurs.
Also, please try to:
Msgdebug ( GetFromXML ( ohttp:ResponseBody(), "entityUid" ) )
Also try this code (based on mxml and hash array)
#include "hbmxml.ch"
cXml := ohttp:ResponseBody()
pRoot := mxmlLoadString( NIL, cXml, MXML_OPAQUE_CALLBACK )
hHash := XMLtoHash( pRoot, 'response' )
mxmlDelete( pRoot )
MsgInfo( "entitylineNumber: " + hHash["entitylineNumber"] + CRLF + ;
		"statusCode: " + hHash["statusCode"]  + CRLF + ;
		"entityUid: " + hHash["entityUid"]  + CRLF + ;
		"entityMark: " + hHash["entityMark"] )
FUNCTION XMLtoHash( pRoot, cElement )
Local pNode, hNext
Local Map := {=>}
If Empty( cElement )
	pNode := pRoot
Else
	pNode := mxmlFindElement( pRoot, pRoot, cElement, NIL, NIL, MXML_DESCEND )
Endif
IF Empty( pNode )
	RETURN Map
hNext := mxmlWalkNext( pNode, pNode, MXML_DESCEND )
Map :=  NodeToHash( hNext )
Return Map
STATIC FUNCTION NodeToHash( node )
Local hNext
Local hHashChild := {=>}
Local hHash := {=>}
DO WHILE node != NIL
	IF mxmlGetType( node ) == MXML_ELEMENT
     	If HB_HHASKEY( hHash, mxmlGetElement( node ) )
     		if valtype( hHash[ mxmlGetElement( node ) ] ) <> "A"
     			hHash[ mxmlGetElement( node ) ] := mxmlGetOpaque( node )
     			//Jest to tablica, dlatego pomijamy
     	Else
     	Endif
     	If HB_MXMLGETATTRSCOUNT( node ) > 0
     		hHash[ mxmlGetElement( node ) + "@attribute"] := HB_MXMLGETATTRS( node )
     	Endif
     	If Empty(  mxmlGetOpaque( node ) ) // Zagladamy do srodka
     		hNext := mxmlWalkNext( node, node, MXML_DESCEND )
     		iF hNext != NIL
     			if Empty( hHash[ mxmlGetElement( node ) ]  )
     				hHash[ mxmlGetElement( node ) ] := {}
     			hHashChild :=  NodeToHash( hNext  )
     			if hHashChild != NIL
     				AADD( hHash[ mxmlGetElement( node ) ], hHashChild )
     		enDiF
     	EndIf
     node := mxmlGetNextSibling( node )
ENDDO WHILE
RETURN hHash
Remember to add #include "hbmxml.ch" at the beginning of your code.
You must also add "hbmxml.hbc" to your project (preferably in a .hbp file)
tomtagaris
yes it works perfectly
thank you very much
tomtagaris
Something else
if i send two invoices the answer is double or triple depending on how much i send
is there any way to get the answer because you don't get it with for ...next
thanks
<?xml version="1.0" encoding="utf-8"?>
<ResponseDoc xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<response>
<entitylineNumber>1</entitylineNumber>
<statusCode>Success</statusCode>
<entityUid>8B5F90485B444AC25259C053646A3F098C6965F9</entityUid>
<entityMark>1000000278308</entityMark>
</response>
<response>
<entitylineNumber>2</entitylineNumber>
<entityMark>1000000278309</entityMark>
</response>
</ResponseDoc>
hHash := XMLtoHash( pRoot, /* start from root node */ )
mxmlDelete( pRoot )
hResponse := hHash["ResponseDoc"][1]["response"]  //All <response> nodes
For i=1 TO Len( hResponse )
MsgInfo( "entitylineNumber: " + hResponse[i]["entitylineNumber"] + CRLF + ;
		"statusCode: " + hResponse[i]["statusCode"]  + CRLF + ;
		"entityUid: " + hResponse[i]["entityUid"]  + CRLF + ;
		"entityMark: " + hResponse[i]["entityMark"] , hb_NTOS(i) + " response" )
Next i
tomtagaris
perfect
I have no words to thank you
I wish you the best edk
thank you very much
tomtagaris
SOMETHING ELSE EDK
I USE THE SAME PROCEDURE TO PROVIDE DATA FROM THE XML FILE RETURNED WITH RequestInvoices BUT I DON'T GET ANYTHING
WHAT I DON'T DO right
mxmlDelete( pRoot )
hResponse := hHash["invoicesDoc"][2]["invoice"] //All <response> nodes
MsgInfo( "uid: " + hResponse["uid"] + CRLF + ;
"mark: " + hResponse["mark"] + CRLF + ;
"vatNumber: " + hResponse["vatNumber"] + CRLF + ;
"mark: " + hResponse["mark"] , hb_NTOS(i) + " response" )
next i
the returned xml
<requestedInvoicesDoc xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<invoicesDoc xmlns="http://www.aade.gr/myDATA/invoice/v1.0">
<invoice>
<uid>8B5F90485B444AC25259C053646A3F098C6965F9</uid>
<mark>1000000280441</mark>
<issuer>
<vatNumber>029690710</vatNumber>
<country>GR</country>
<name>οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½</name>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<series>οΏ½</series>
<aa>2</aa>
<issueDate>2019-07-19</issueDate>
<invoiceType>1.1</invoiceType>
<vatPaymentSuspension>true</vatPaymentSuspension>
<currency>EUR</currency>
<exchangeRate>8.00</exchangeRate>
<correlatedInvoices />
<selfPricing>false</selfPricing>
<dispatchTime>16:47:51.7000000+00:00</dispatchTime>
<vehicleNumber />
<movePurpose>1</movePurpose>
</invoiceHeader>
<invoiceDetails>
<lineNumber>1</lineNumber>
<measurementUnit>1</measurementUnit>
<netValue>140</netValue>
<vatCategory>2</vatCategory>
<vatExemptionCategory>1</vatExemptionCategory>
<dienergia>
<applicationId />
<applicationDate>1986-12-20</applicationDate>
<shipId />
</dienergia>
<discountOption>true</discountOption>
<withheldAmount>0</withheldAmount>
<stampDutyPercentCategory>1</stampDutyPercentCategory>
<feesAmount>0</feesAmount>
<otherTaxesPercentCategory>1</otherTaxesPercentCategory>
<deductionsPercentage>0</deductionsPercentage>
<incomeClassification>
<classificationType>101</classificationType>
<classificationCategory>1</classificationCategory>
<amount>140</amount>
</incomeClassification>
</invoiceDetails>
<invoiceDetails>
<quantity>10</quantity>
<invoiceDetailType>1</invoiceDetailType>
<dienergia>
<applicationId />
<applicationDate>2004-12-14</applicationDate>
<shipId />
</dienergia>
<withheldPercentCategory>1</withheldPercentCategory>
</invoiceDetails>
<invoiceSummary>
<totalNetValue>140</totalNetValue>
<totalVatAmount>18.2</totalVatAmount>
<totalWithheldAmount>0</totalWithheldAmount>
<totalFeesAmount>0</totalFeesAmount>
<totalStampDutyAmount>0</totalStampDutyAmount>
<totalOtherTaxesAmount>0</totalOtherTaxesAmount>
<totalDeductionsAmount>0</totalDeductionsAmount>
<totalGrossValue>158.2</totalGrossValue>
<amount>158.2</amount>
</invoiceSummary>
</invoice>
<invoice>
<mark>1000000280442</mark>
<issuer>
<name>ΤΑΓΑΡΗΣ</name>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<aa>1</aa>
<exchangeRate>1.00</exchangeRate>
<dispatchTime>16:47:51.0000000+00:00</dispatchTime>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
<quantity>1</quantity>
<invoiceDetailType>2</invoiceDetailType>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
<invoice>
<mark>1000000280443</mark>
<issuer>
</issuer>
<counterpart>
</counterpart>
<invoiceHeader>
<branch>0</branch>
<aa>2</aa>
<vehicleNumber />
</invoiceHeader>
<invoiceDetails>
<dienergia>
<applicationId />
<shipId />
</dienergia>
</invoiceDetails>
<invoiceDetails>
<dienergia>
<applicationId />
<shipId />
</dienergia>
</invoiceDetails>
<invoiceSummary>
</invoiceSummary>
</invoice>
</invoicesDoc>
</requestedInvoicesDoc>
Hi Tom.
I see you have a problem understanding the hash array structure.
Unfortunately, my English is not very good to explain, so I made a pictorial description. I hope it will be helpful.
Bez tytułu.png (55.27 KiB) Viewed 7660 times
Source code below:
hInvoice := hHash["requestedInvoicesDoc"][ 1 ]["invoicesDoc"][ 1 ]["invoice"] //All <invoice> nodes
For i=1 TO Len( hInvoice )
	// the "invoice" root node
	cInv_Root   := "uid: " + hInvoice[ i /* n-th invoice */ ]["uid"] + CRLF + ;
			"mark: " + hInvoice[ i ]["mark"]
	// the "invoice" node has only one [1] "issuer" node
	cInv_Issuer := "issuer -> vatNumber:" + hInvoice[ i /* n-th invoice */ ]["issuer"][ 1 /* 1-st and only sub-node "issuer" */ ]["vatNumber"] + CRLF +;
			"issuer -> counrty:" + hInvoice[ i ]["issuer"][ 1 ]["country"] + CRLF +;
			"issuer -> name:" + hInvoice[ i ]["issuer"][ 1 ]["name"]
	// the "invoice" node has only one [1] "counterpart" node
	cInv_Counterpart := "counterpart -> vatNumber:" + hInvoice[ i /* n-th invoice */ ]["counterpart"][ 1 /* 1-st and only sub-node "counterpart" */ ]["vatNumber"] + CRLF +;
				"counterpart -> country:" + hInvoice[ i ]["counterpart"][ 1 ]["country"]
	// the "invoice" node has only one [1] "invoiceHeadert" node
	cInv_Header := "invoiceHeader -> branch:" + hInvoice[ i /* n-th invoice */ ]["invoiceHeader"][ 1 /* 1-st and only sub-node "invoiceHeader" */ ]["branch"] + CRLF +;
			"invoiceHeader -> series:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["series"] + CRLF +;
			"invoiceHeader -> aa:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["aa"] + CRLF +;
			"invoiceHeader -> issueDate:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["issueDate"] + CRLF +;
			"invoiceHeader -> invoiceType:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["invoiceType"] + CRLF +;
			"invoiceHeader -> vatPaymentSuspension:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["vatPaymentSuspension"] + CRLF +;
			"invoiceHeader -> currency:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["currency"] + CRLF +;
			"invoiceHeader -> exchangeRate:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["exchangeRate"] + CRLF +;
			"invoiceHeader -> correlatedInvoices:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["correlatedInvoices"] + CRLF +;
			"invoiceHeader -> selfPricing:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["selfPricing"] + CRLF +;
			"invoiceHeader -> dispatchTime:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["dispatchTime"] + CRLF +;
			"invoiceHeader -> vehicleNumber:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["vehicleNumber"] + CRLF +;
			"invoiceHeader -> movePurpose:" + hInvoice[ i ]["invoiceHeader"][ 1 ]["movePurpose"]
	MsgInfo( "Invoice #" + hb_ntos (i) + CRLF + ;
		cInv_root + CRLF +;
		cInv_Issuer + CRLF +;
		cInv_Counterpart + CRLF +;
		cInv_Header )
	// the "invoice" node can have several "invoiceDetails" nodes
	FOR nDetails = 1 TO Len ( hInvoice[ i /* n-th invoice */ ]["invoiceDetails"] )
		hDetails := hInvoice[ i /* n-th invoice */ ]["invoiceDetails"][ nDetails /* n-th sub-node "invoiceDetails" */ ]
		cInv_Details := "invoiceDetails -> lineNumber:" + hDetails["lineNumber"] + CRLF
		//I am not sure if the item exists (may be optional), so I will ask for it using the function hb_HGetDef (<hHash>, <Key>, [<DefaultValue>]) => xValue | NIL
		cInv_Details += "invoiceDetails -> quantity:" + hb_HGetDef( hDetails , "quantity" , "") + CRLF
		cInv_Details += "invoiceDetails -> measurementUnit:" + hb_HGetDef( hDetails , "measurementUnit" , "") + CRLF
		cInv_Details += "invoiceDetails -> netValue:" + hb_HGetDef( hDetails, "netValue", "") + CRLF
		cInv_Details += "invoiceDetails -> vatCategory:" + hb_HGetDef( hDetails, "vatCategory", "") + CRLF
		cInv_Details += "invoiceDetails -> vatExemptionCategory:" + hb_HGetDef( hDetails, "vatExemptionCategory", "") + CRLF
		//the "invoiceDetails" node has the optional "dienergy" node. Let's check if it exists
		IF hb_HHasKey( hDetails, "dienergia" )
			//I don't know if the "dienergia" node can occur more than once. Just in case, I check all occurrences
			FOR j = 1 TO Len( hDetails["dienergia"] )
				cInv_Details += "invoiceDetails -> dienergia -> applicationId:" + hb_HGetDef( hDetails["dienergia"][ j /* n-st sub-node "dianergia" */ ], "applicationId", "") + CRLF
				cInv_Details += "invoiceDetails -> dienergia -> applicationDate:" + hb_HGetDef( hDetails["dienergia"][ j ], "applicationDate", "") + CRLF
				cInv_Details += "invoiceDetails -> dienergia -> shipId:" + hb_HGetDef( hDetails["dienergia"][ j ], "shipId", "") + CRLF
			NEXT j
		cInv_Details += "invoiceDetails -> discountOption:" + hb_HGetDef( hDetails, "discountOption" , "") + CRLF
		cInv_Details += "invoiceDetails -> withheldAmount:" + hb_HGetDef( hDetails, "withheldAmount" , "") + CRLF
		cInv_Details += "invoiceDetails -> stampDutyPercentCategory:" + hb_HGetDef( hDetails, "stampDutyPercentCategory" , "") + CRLF
		cInv_Details += "invoiceDetails -> feesAmount:" + hb_HGetDef( hDetails, "feesAmount" , "") + CRLF
		cInv_Details += "invoiceDetails -> otherTaxesPercentCategory:" + hb_HGetDef( hDetails, "otherTaxesPercentCategory" , "") + CRLF
		cInv_Details += "invoiceDetails -> deductionsPercentage:" + hb_HGetDef( hDetails, "deductionsPercentage" , "") + CRLF
		//the "invoiceDetails" node has the optional "incomeClassification" node. Let's check if it exists
		IF hb_HHasKey( hDetails, "incomeClassification" )
			//I don't know if the "incomeClassification" node can occur more than once. Just in case, I check all occurrences
			FOR j = 1 TO Len( hDetails["incomeClassification"] )
				cInv_Details += "invoiceDetails -> incomeClassification -> classificationType:" + hb_HGetDef( hDetails["incomeClassification"][ j /* n-st sub-node "incomeClassification" */ ], "classificationType", "") + CRLF
				cInv_Details += "invoiceDetails -> incomeClassification -> classificationCategory:" + hb_HGetDef( hDetails["incomeClassification"][ j ], "classificationCategory", "") + CRLF
				cInv_Details += "invoiceDetails -> incomeClassification -> amount:" + hb_HGetDef( hDetails["incomeClassification"][ j ], "amount", "") + CRLF
			NEXT j
		MsgInfo( "Invoice #" + hb_ntos (i) + "   Detail #" + hb_ntos (nDetails) + CRLF + cInv_Details)
	Next nDetails
	// the "invoice" node has only one [1] "invoiceSummary" node
	hSummary := hInvoice[ i /* n-th invoice */ ]["invoiceSummary"][ 1 /* 1-st and only sub-node "invoiceSummary" */ ]
	cInv_Summary := "invoiceSummary -> totalNetValue:" + hSummary["totalNetValue"] + CRLF +;
			 "invoiceSummary -> totalVatAmount:" + hSummary["totalVatAmount"] + CRLF +;
			 "invoiceSummary -> totalWithheldAmount:" + hSummary["totalWithheldAmount"] + CRLF +;
			 "invoiceSummary -> totalFeesAmount:" + hSummary["totalFeesAmount"] + CRLF +;
			 "invoiceSummary -> totalStampDutyAmount:" + hSummary["totalStampDutyAmount"] + CRLF +;
			 "invoiceSummary -> totalOtherTaxesAmount:" + hSummary["totalOtherTaxesAmount"] + CRLF +;
			 "invoiceSummary -> totalDeductionsAmount:" + hSummary["totalDeductionsAmount"] + CRLF +;
			 "invoiceSummary -> totalGrossValue:" + hSummary["totalGrossValue"] + CRLF
	//the "invoiceSummary" node has the optional "incomeClassification" node. Let's check if it exists
	IF hb_HHasKey( hSummary, "incomeClassification" )
			FOR j = 1 TO Len( hSummary["incomeClassification"] )
				cInv_Summary += "invoiceSummary -> incomeClassification -> classificationType:" + hb_HGetDef( hSummary["incomeClassification"][ j /* n-st sub-node "incomeClassification" */ ], "classificationType", "") + CRLF
				cInv_Summary += "invoiceSummary -> incomeClassification -> classificationCategory:" + hb_HGetDef( hSummary["incomeClassification"][ j ], "classificationCategory", "") + CRLF
				cInv_Summary += "invoiceSummary -> incomeClassification -> amount:" + hb_HGetDef( hSummary["incomeClassification"][ j ], "amount", "") + CRLF
			NEXT j
	MsgInfo( "Invoice #" + hb_ntos (i) + "   Summary:" + CRLF + cInv_Summary)
next i
I split hHash into individual variables to make the structure easier to understand.
Edward.
tomtagaris
thank you very much edk
I'm trying to understand how it works
it's too deep for me
and my english is not good
your work is amazing
Thank you very much
without your help I wouldn't succeed
I hope this is the last thing I ask of you
