pdf grid
jairpinho
Re: pdf grid
Post by jairpinho »
Hi Edk, I need the print grid function to accept accents in the mod ansi not working with SET HPDFDOC ENCODING TO "WinAnsiEncoding" in the print_grid function inside the array aDados
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: pdf grid
There was no character encoding declaration for the HPDF_GetFont function.
Here you have the program code working for me:
demo.7z
(1.79 KiB) Downloaded 572 times
I can not insert the ãà chars from the keyboard into NP++ editor as ANSI. The pasted characters from the Windows Character Table into the NP++ editor are also swapped in my Windows to Unicode, so I used the equivalent ASCII code in the source.
I am also enclosing a character table that is supported by WinAnsiEncoding.
HaruPDF WinAnsiEncoding.7z
(71.17 KiB) Downloaded 561 times
Post Scriptum: Essa é outra garrafa de cachaça.
jairpinho
Re: pdf grid
Post by jairpinho »
edk wrote: Tue Dec 25, 2018 10:30 pm There was no character encoding declaration for the HPDF_GetFont function.
Here you have the program code working for me:demo.7z
thanks edk, it worked perfectly the edit already use ansi was only in function even in getfont
Jair Pinho
