label at runtime
Re: label at runtime
Yes, indeed Serge, thx. I wrote a post on a mobile phone :oops: I've changed that already.
jairpinho
Post by jairpinho »
edk wrote: Sat Sep 30, 2017 8:51 am Corrected. I added font attributes, and colors.
By the way, I found a bug in the source h_HMG_HPDF.Prg
If you want to use the Bold and/or Italic attributes you need to add in h_HMG_HPDF.Prg at line #1812: cFnt := cFont (after "Otherwise"). Otherwise, cFnt variable for declared cFont: "Courier" and "Helvetica" is Nil value, which results in an error.
After the change, of course, you have to rebuild the HMG.
Function Main()
Local i
SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300 LOG
SET HPDFDOC ENCODING TO "WinAnsiEncoding"
START HPDFDOC
    START HPDFPAGE
//	@10,10 HPDFPRINT "Rotate Demo"
        HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 90 )
	HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 180, .T.)
        HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 270, .T., .T.)
	HPDF_RotateText( 50, 80, "ABCxyz123", Nil, Nil, 0 , , .T.)
	FOR i=0 TO 250 STEP 10
		HPDF_RotateText( i, 10, "Happy HMG", "Courier", 15, 5, .T. , .T. , {200, i, 75})
	NEXT i
	FOR i=0 To 345 STEP 15
		HPDF_RotateText( 150, 150, "Happy HMG", Nil, 10, i, , , {255 , 255, 0} )
	NEXT i
    END HPDFPAGE
END HPDFDOC
Execute File 'sample.pdf'
PROCEDURE HPDF_RotateText( nRow, nCol, cTxt, cFont, nFontSize, nAngle, lBold, lItalic, aColors)
* Rotating text
   Local nRad, nTextWidth, oFont, cFnt
   Local hPdf        := _HMG_SYSDATA[ 150 ][ 1 ]
   Local hPage       := _HMG_SYSDATA[ 150 ][ 7 ]
   Local cPdfEnc     := _HMG_SYSDATA[ 150 ][ 10 ]
   Local nWidth      := _HMG_SYSDATA[ 150 ][ 4 ]
   Local nHeight     := _HMG_SYSDATA[ 150 ][ 5 ]
   Local nxPos       := _HMG_HPDF_MM2Pixel( nCol )
   Local nyPos       := nHeight - _HMG_HPDF_MM2Pixel( nRow )
   DEFAULT cFont       := "Helvetica"
   DEFAULT nFontSize   := 12
   DEFAULT cTXt        := ""
   DEFAULT nAngle      := 0
   DEFAULT lBold       := .F.
   DEFAULT lItalic     := .F.
   DEFAULT aColors     := { 0, 0, 0}
   If _HMG_SYSDATA[ 150 ][ 1 ] == Nil // PDF object not found!
      _HMG_HPDF_Error( 3 )
   If _HMG_SYSDATA[ 150 ][ 7 ] == Nil // PDF Page object not found!
      _HMG_HPDF_Error( 5 )
   // set color
   If VALTYPE( aColors )#'A' .OR. LEN( aColors )#3 .OR. ;
      VALTYPE( aColors[1] )#'N' .OR. VALTYPE( aColors[2] )#'N' .OR. VALTYPE( aColors[3] )#'N' .OR. ;
      aColors[1]<0 .OR. aColors[1]>255 .OR. ;
      aColors[2]<0 .OR. aColors[2]>255 .OR. ;
      aColors[3]<0 .OR. aColors[3]>255
   Endif
   HPDF_Page_SetRGBFill( hPage, aColors[1]/255, aColors[2]/255, aColors[3]/255 )
   // set font
   If HMG_LEN( AllTrim( cFont ) ) == 0
      cFont := _HMG_HPDF_SetFont( cFont, lBold, lItalic )
      oFont := HPDF_GetFont( hPdf, cFont, cPdfEnc )
      cFont := AllTrim(_HMG_HPDF_SetFont( cFont, lBold, lItalic ))
      if HMG_UPPER (cFileExt (cFont)) == '.TTF' // load ttf font
         cFnt := HPDF_LOADTTFONTFROMFILE( hPdf, cFont, .t. )
         If HMG_LEN( Alltrim( cFnt ) ) == 0
            _HMG_HPDF_Error( 6 , cFont )
         oFont := HPDF_GetFont( hPdf, cFnt, cPdfEnc )
         If HMG_UPPER( alltrim( cFont ) ) == "SYMBOL" .or. HMG_UPPER( alltrim( cFont ) ) == "ZAPFDINGBATS"
            oFont := HPDF_GetFont( hPdf, cFont, Nil )
         endIf
   endIf
   If oFont == Nil
   Endif
   HPDF_Page_SetFontAndSize( hPage, oFont, nFontSize )
   nTextWidth := HPDF_Page_TextWidth( hPage, cTxt )
   nRad := nAngle / 180 * 3.141592 	//radian value
   HPDF_Page_BeginText( hPage )
   HPDF_Page_SetTextMatrix ( hPage, cos ( nRad ), sin ( nRad ), -sin ( nRad ), cos ( nRad ), nxPos , nyPos - nFontSize)
   HPDF_Page_ShowText( hPage, cTxt )
   HPDF_Page_EndText( hPage )
thanks edk again, I need now to align this text on the right
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
In the source you have all the variables to try to do it yourself. There are coordinates and text width: nTextWidth. It remains a matter of what axis you need to align the text, the absolute X-axis of the page or the base line of the rotated text?
jairpinho
Post by jairpinho »
edk wrote: Sun Oct 01, 2017 8:24 am In the source you have all the variables to try to do it yourself. There are coordinates and text width: nTextWidth. It remains a matter of what axis you need to align the text, the absolute X-axis of the page or the base line of the rotated text?
I've tried everything I can not do, I'm trying to do based on their codes I started to play some haru codes but it's still very difficult for me to understand, I can modify some codes already ready to try to find solutions for my projects but sometimes I do not have a lot of understanding
Jair Pinho
This is simple. Just calculate the value of nxPos.
Knowing the width of the text, for alignment to the right, simply move the text to the left direction. Subtract the width of the text from nxPos. To center the text, nxPos subtract half the width of the text.
Conversely, if the text is at an angle, knowing the angle and width of the text, calculate the width of the base that the triangle forms. Use the calculated triangle base to calculate the new value of nxPos. Pure math. :roll:
Function Main()
Local i
START HPDFDOC
    START HPDFPAGE
    	@ 10, 100 HPDFPRINT LINE TO 220, 100 PENWIDTH 0.05
    	@ 10, 100 HPDFPRINT "AXIS" CENTER
    	@ 30, 100 HPDFPRINT "LEFT ALIGN"
	HPDF_RotateText( 50, 100, "ABCxyz123", Nil, Nil, 0 )
     HPDF_RotateText( 50, 100, "ABCxyz123", Nil, Nil, 45 )
     @ 80, 100 HPDFPRINT "RIGHT ALIGN" RIGHT
     HPDF_RotateText( 100, 100, "ABCxyz123", Nil, Nil, 0 , , ,{255 , 0, 0} , 'R' )
     HPDF_RotateText( 100, 100, "ABCxyz123", Nil, Nil, 45 , , ,{255 , 0, 0} , 'r' )
     @ 130, 100 HPDFPRINT "CENTER ALIGN" CENTER
     HPDF_RotateText( 150, 100, "ABCxyz123", Nil, Nil, 0 , , ,{0,255 , 0} , 'C' )
     HPDF_RotateText( 150, 100, "ABCxyz123", Nil, Nil, 45 , , ,{0,255 , 0} , 'c' )
    END HPDFPAGE
END HPDFDOC
PROCEDURE HPDF_RotateText( nRow, nCol, cTxt, cFont, nFontSize, nAngle, lBold, lItalic, aColors, cAlign)
* Rotating text
   DEFAULT cTXt        := ""
   DEFAULT nAngle      := 0
   DEFAULT cAlign      :='L'
   IF VALTYPE(cAlign)#'C' .OR. !(HMG_UPPER(cAlign)$'LRC')
      cAlign := 'L'		//Left as default
   // set color
   Endif
   // set font
         endIf
   endIf
   If oFont == Nil
   Endif
   //calculate nxPos
   IF HMG_UPPER(cAlign)='R'		//Right
      nxPos:=nxPos - (nTextWidth* cos (nRad))
   ELSEIF HMG_UPPER(cAlign)='C'	//Center
   	 nxPos:=nxPos - ((nTextWidth* cos (nRad))/2)
PS. If you want to align the text vertically, you should calculate the nyPos variable, correcting the coordinates by the height of that the triangle forms. Then you have to use the sinus function.
Note also that the height of the text corresponds to the nFontSize variable.
Try it yourself, I believe you will succeed.
Version with vertical alignment ;)
Function Main()
Local i
START HPDFDOC
    START HPDFPAGE
    	@ 50+_HMG_HPDF_Pixel2MM( 12 ), 10 HPDFPRINT LINE TO 50+_HMG_HPDF_Pixel2MM( 12 ), 200 PENWIDTH 0.05
     HPDF_RotateText( 50, 100, "Center Middle", Nil, Nil, 135 , , ,{0 , 0, 255} , 'cM' )
     HPDF_RotateText( 50, 100, "Top", Nil, Nil, 90 , , ,{255 , 0, 255} , 'T' )
    END HPDFPAGE
END HPDFDOC
* Rotating text
   DEFAULT cTXt        := ""
   DEFAULT nAngle      := 0
   DEFAULT cAlign      :=""		//Empty - Left and bottom, R - Right, C - Center, T - Top, M - Middle
      cAlign := ''		//Left as default
   // set color
   Endif
   // set font
         endIf
   endIf
   If oFont == Nil
   Endif
   //calculate nxPos
   IF 'R'$HMG_UPPER(cAlign)		//Right
   ELSEIF 'C'$HMG_UPPER(cAlign)	//Center
   //calculate nyPos
   IF 'T'$HMG_UPPER(cAlign)		//Top
      nyPos:=nyPos - (nTextWidth* sin (nRad))
   ELSEIF 'M'$HMG_UPPER(cAlign)	//Middle
   	 nyPos:=nyPos - ((nTextWidth* sin (nRad))/2)
jairpinho
Post by jairpinho »
edk wrote: Mon Oct 02, 2017 1:33 pm Version with vertical alignment ;)
Function Main()
Local i
START HPDFDOC
    START HPDFPAGE
    END HPDFPAGE
END HPDFDOC
* Rotating text
   DEFAULT cTXt        := ""
   DEFAULT nAngle      := 0
   // set color
   Endif
   // set font
         endIf
   endIf
   If oFont == Nil
   Endif
   //calculate nxPos
   //calculate nyPos
Thank you Edk, it was perfect.
Jair Pinho
jairpinho
Post by jairpinho »
Function Main()
Local i
START HPDFDOC
    START HPDFPAGE
    END HPDFPAGE
END HPDFDOC
* Rotating text
   DEFAULT cTXt        := ""
   DEFAULT nAngle      := 0
   // set color
   Endif
   // set font
         endIf
   endIf
   If oFont == Nil
   Endif
   //calculate nxPos
   //calculate nyPos
edk, help me on this grid only missing this part for my project, you understand this mathematics well
http://www.hmgforum.com/viewtopic.php?f=40&t=5425
Jair Pinho
I don't want to create new topic, because my problem is creation label placed on tab.
I've defined MainForm window and Tab_1 within.
I want to create at runtime placed on tab_1
   define label NewLabel
			parent MainForm.Tab_1
			row 115
			col 700
			backColor {96,96,96}
			value "BAR"
			height 180
			width  20
end label
but, MainForm.Tab_1 is unknown for application.
How to do it? Is it possible?
So on quickly:
 parent MainForm.Tab_1[nPage]
