QR Code in HMG
JRGEMS
Re: QR Code in HMG
Post by JRGEMS »
Dear All,
If any one generated QRCODE in HMG, for INDIAN E-Invoice IRN, I would be thankful for sharing the code.
The QRCODE generated by me gives Error 3. QRCODE data received from INDIAN GST site has 3400 to 3600 character length.
I do not know how to attach program file in HMG forum.
Thanks every one in advance.
Ramesh Bhat.
Re: QR Code in HMG
JRGEMS wrote: Mon Oct 19, 2020 5:36 am
Ramesh Bhat.
When composing a post use the option "Full Editor & Preview" inside look for the "Attachment" tab look for the code in ZIP or RAR format
JRGEMS
Re: QR Code in HMG
Post by JRGEMS »
Thank you Danielmaximiliano.
The QRCODE when scanned by scanner (Downloaded from GST E-Invoice website) should give result like this.
qrc.zip
(1.84 MiB) Downloaded 3593 times
Re: QR Code in HMG
JRGEMS wrote: Mon Oct 19, 2020 3:00 pm The QRCODE when scanned by scanner (Downloaded from GST E-Invoice website) should give result like this.
1. Received data from INDIAN GST is saved in JSON format - it is not the QR Code itself. Other data is also stored there.
2. The JSON string stored in the database should be converted into the Hash array.
3. The contents of the "SignedQRCode" key should be read from the Hash array.
4. The content of this key is the content of the QR Code.
Try this:
Function Main()
   Local hHash, cHash, cSignedQRCode := ""
   REQUEST DBFCDX, DBFFPT
   RDDSETDEFAULT( "DBFCDX" )
   SELECT 0
   USE seljsn INDEX seljsn
   GO TOP
   cHash := AllTrim ( seljsn->qrcode )
   nLen := hb_JsonDecode( cHash, @hHash )
   IF nLen = 0
   		MsgStop ("Error while decoding JSON")
   		Close Data
   		Quit
   cSignedQRCode := hb_HGetDef( hHash, "SignedQRCode", "")
   IF EMPTY (cSignedQRCode)
   		MsgStop ("No SignedQRCode into JSON")
   		Close Data
   		Quit
   //msgdebug ( cSignedQRCode)
   //msgdebug (hb_HKeys (hHash))
   SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300 LOG
   SET HPDFDOC ENCODING TO "WinAnsiEncoding"
   START HPDFDOC
      START HPDFPAGE
         @10, 10 HPDFPRINT "QRCODE line width = 1"
         HPDFDrawBarcode(10, 70, cSignedQRCode , "QRCODE", 1)
         @55, 10 HPDFPRINT "QRCODE line width = 1.5"
         HPDFDrawBarcode(55, 70, cSignedQRCode , "QRCODE", 1.5)
         @120, 10 HPDFPRINT "QRCODE line width = 2"
         HPDFDrawBarcode(120, 70, cSignedQRCode , "QRCODE", 2)
      END HPDFPAGE
   END HPDFDOC
   Execute File 'sample.pdf'
PROCEDURE HPDFDrawBarcode( nRow, nCol, cCode, cType, nLineWidth, nLineHeight, lShowDigits, lCheckSum, lWide2_5, lWide3 )
   Local hZebra, cTxt, nFlags, nSizeWidth, nTextWidth
   Local hPdf        := _HMG_SYSDATA[ 150 ][ 1 ]
   Local hPage       := _HMG_SYSDATA[ 150 ][ 7 ]
   Local nWidth      := _HMG_SYSDATA[ 150 ][ 4 ]
   Local nHeight     := _HMG_SYSDATA[ 150 ][ 5 ]
   Local nxPos       := _HMG_HPDF_MM2Pixel( nCol )
   Local nyPos       := nHeight - _HMG_HPDF_MM2Pixel( nRow )
   Local cFont       := "Helvetica"
   Local nFontSize   := 9
   Local nTextHeight := 0
   DEFAULT nLineWidth  := 1
   DEFAULT nLineHeight := 18
   DEFAULT lCheckSum   := .F.
   DEFAULT lWide2_5    := .F.
   DEFAULT lWide3      := .F.
   DEFAULT lShowDigits := .F.
   nFlags := 0
   IF lChecksum
      nFlags := nFlags + HB_ZEBRA_FLAG_CHECKSUM
   IF lWide2_5
      nFlags := nFlags + HB_ZEBRA_FLAG_WIDE2_5
   IF lWide3
      nFlags := nFlags + HB_ZEBRA_FLAG_WIDE3
   IF nFlags == 0
      nFlags := Nil
   SWITCH cType
   CASE "EAN13"      ; hZebra := hb_zebra_create_ean13( cCode, nFlags )   ; EXIT
   CASE "EAN8"       ; hZebra := hb_zebra_create_ean8( cCode, nFlags )    ; EXIT
   CASE "UPCA"       ; hZebra := hb_zebra_create_upca( cCode, nFlags )    ; EXIT
   CASE "UPCE"       ; hZebra := hb_zebra_create_upce( cCode, nFlags )    ; EXIT
   CASE "CODE39"     ; hZebra := hb_zebra_create_code39( cCode, nFlags )  ; EXIT
   CASE "ITF"        ; hZebra := hb_zebra_create_itf( cCode, nFlags )     ; EXIT
   CASE "MSI"        ; hZebra := hb_zebra_create_msi( cCode, nFlags )     ; EXIT
   CASE "CODABAR"    ; hZebra := hb_zebra_create_codabar( cCode, nFlags ) ; EXIT
   CASE "CODE93"     ; hZebra := hb_zebra_create_code93( cCode, nFlags )  ; EXIT
   CASE "CODE11"     ; hZebra := hb_zebra_create_code11( cCode, nFlags )  ; EXIT
   CASE "CODE128"    ; hZebra := hb_zebra_create_code128( cCode, nFlags ) ; EXIT
   CASE "PDF417"     ; hZebra := hb_zebra_create_pdf417( cCode, nFlags ); nLineHeight := nLineWidth * 3 ; lShowDigits := .f. ; EXIT
   CASE "DATAMATRIX" ; hZebra := hb_zebra_create_datamatrix( cCode, nFlags ); nLineHeight := nLineWidth ; lShowDigits := .f. ; EXIT
   CASE "QRCODE"     ; hZebra := hb_zebra_create_qrcode( cCode, nFlags ); nLineHeight := nLineWidth ; lShowDigits := .f. ; EXIT
   ENDSWITCH
   IF hZebra != NIL
      IF hb_zebra_geterror( hZebra ) == 0
         IF lShowDigits
            cTxt := ALLTRIM(hb_zebra_getcode( hZebra ))
            nSizeWidth  := HMG_Zebra_GetWidth  (hZebra, nLineWidth, nLineHeight, NIL)
            nSizeHeight := HMG_Zebra_GetHeight (hZebra, nLineWidth, nLineHeight, NIL)
            HPDF_Page_SetFontAndSize( hPage, HPDF_GetFont( hPdf, cFont, NIL ), nFontSize )
            nTextWidth := HPDF_Page_TextWidth( hPage, cTxt )
            nTextHeight:= nFontSize - 1
            HPDF_Page_BeginText( hPage )
            HPDF_Page_TextOut( hPage, (nxPos + ( nSizeWidth / 2 )) - ( nTextWidth / 2 ), nyPos - nSizeHeight, cTxt )
            HPDF_Page_EndText( hPage )
         hb_zebra_draw_hpdf( hZebra, hPage, nxPos, nyPos, nLineWidth, -(nLineHeight-nTextHeight))
         MsgInfo ("Type "+ cType + CRLF +"Code "+ cCode+ CRLF+ "Error  "+LTrim(hb_valtostr(hb_zebra_geterror(hZebra))))
      hb_zebra_destroy( hZebra )
      MsgStop("Invalid barcode type !", cType)
STATIC FUNCTION hb_zebra_draw_hpdf( hZebra, hPage, ... )
   IF hb_zebra_geterror( hZebra ) != 0
      RETURN HB_ZEBRA_ERROR_INVALIDZEBRA
   hb_zebra_draw( hZebra, {| x, y, w, h | HPDF_Page_Rectangle( hPage, x, y, w, h ) }, ... )
   HPDF_Page_Fill( hPage )
   RETURN 0
FUNCTION HMG_Zebra_GetWidth (hZebra, nLineWidth, nLineHeight, iFlags)
LOCAL x1:= 0, y1 := 0, nBarWidth := 0, nBarHeight := 0
   // always --> nBarHeight = nLineHeight
   IF hb_zebra_GetError( hZebra ) != 0
// hb_zebra_draw ( hZebra,   bCodeBlock,  dX, dY,     dWidth,     dHeight, iFlags )
   hb_zebra_draw ( hZebra, {| x, y, w, h | nBarWidth:=MAX(x+w-x1, nBarWidth), nBarHeight:=MAX(y+h-y1, nBarHeight) }, x1, y1, nLineWidth, nLineHeight, iFlags )
RETURN nBarWidth
// hb_zebra_draw ( hZebra, {| x, y, w, h | nBarWidth:=x+w-x1, nBarHeight:=y+h-y1 }, x1, y1, nLineWidth, nLineHeight, iFlags )
// hb_zebra_draw ( hZebra, {| x, y, w, h | nBarWidth:=MAX(x+w-x1, nBarWidth), nBarHeight:=MAX(y+h-y1, nBarHeight) }, x1, y1, nLineWidth, nLineHeight, iFlags )
FUNCTION HMG_Zebra_GetHeight (hZebra, nLineWidth, nLineHeight, iFlags)
RETURN nBarHeight
Enjoy
JRGEMS
Re: QR Code in HMG
Post by JRGEMS »
Wow! it is working.
I never thought it is so simple.
Thank you EDK. It made my life much more simple.
Ramesh Bhat.
Re: QR Code in HMG
mol wrote: Sat Oct 19, 2019 6:00 am I'm afraid there is no newer version.
Try to search reported bugs and solutions on the forum
As of now, this is the first and foremost requirement of HMG.
I think we can make use of the Git.
apais
Re: QR Code in HMG
Post by apais »
I've published things to be implemented on the GIt ( automatic compilation ). But no one cared...
Some other people here had similar experiences.
Reported fixes totally ignored.
Is there a real interest on keeping this tool alive?
Angel Pais
Re: QR Code in HMG
Maybe many of HMG-members have some corona trouble to handle..?
Re: QR Code in HMG
Sorry, I'm not familiar with Github.
I also don't touch sources because of none knowledge of this
Re: QR Code in HMG
apais wrote: Tue Oct 20, 2020 1:29 pm I've published things to be implemented on the GIt ( automatic compilation ). But no one cared...
Hi
We would like to contribute / generate / publish HMG but most of the user are not familiar with Git hub
You are master in Harbour but we have not such knowledge
I am old clipper user, even I am not using IDE, I prefer to write code
Anyone guide us how to work with Git or GIt ( automatic compilation )
