Screenshot-Captura_Pantallas
Re: Screenshot-Captura_Pantallas
To Roberto:
What is : "#pragma TEXTHIDDEN(1) " and what does it do ??
Thx,
Roberto Lopez wrote:Well...
Happy Capturing!!!
Enjoy!
OK, my two cent:
Postby Roberto Lopez » 03 Oct 2016 17:14
Well...
Be careful, since I've modified certain BOS Taurus functions to use handles instead window names.
Maybe you must rename some of such functions.
BT_WINHANDLE
BT_FILLRECTISNIL
BT_ADJUSTWIDTHHEIGHTRECT
BT_CLIENTAREAWIDTH
BT_CLIENTAREAHEIGHT
BT_BITMAPSAVEFILE
BT_BITMAPRELEASE
BT_BITMAPCAPTURECLIENTAREA
( added RL to BTs )
PROC Main()
   DEFINE WINDOW frmCS_Main ;
		  WIDTH 120 HEIGHT 90 ;
		  TITLE 'Capture Screen' ;
		  MAIN
      @ 10, 10 BUTTON btnCapture CAPTION "Capture !" ACTION CaptureSystem()
   frmCS_Main.Center
   frmCS_Main.Activate
RETU // CaptScrn.Main()
      DEFINE TIMER Timer_1 ;
      INTERVAL 30000 ;
FUNCTION CaptureSystem()
LOCAL cFileName
   frmCS_Main.Minimize()
   frmCS_Main.Hide
   cBaseDir := ''
   dDate   := DATE()
   cYear   := ALLTRIM( STR( YEAR( dDate ) ) )
   cMonth    := ALLTRIM( STRZERO(MONTH( dDate ) , 2 ) )
   cDay    := ALLTRIM( STRZERO(DAY  ( dDate ) , 2 ) )
   cTime   := TIME()
   cHour   := LEFT  ( cTime , 2 )
   cMinutes  := SUBSTR( cTime , 4 , 2 )
   cSeconds := RIGHT ( cTime , 2)
   cFileName := cBaseDir + cYear + '-' + cMonth + '-' + cDay + '-' + cHour + '-' + cMinutes + '-' + cSeconds
   xSAVEWINDOWBYHANDLE ( BT_SCR_GETDESKTOPHANDLE() , cFileName + '.' + 'jpg' , 0 , 0 , 1366 , 768 )
   frmCS_Main.Restore()
   frmCS_Main.Show
   MsgDebug( cFileName )
   FTPUP(cFileName + '.jpg' )
   DELETE FILE (cFileName + '.jpg' )
*._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-
PROCEDURE FTPUP(cFileName)
   cNetServer := 'your server addres here'
   cServer   := cNetServer + ':your server port here'
   cUser     := "your username"
   cPassword := "your password"
   #pragma TEXTHIDDEN(0)
   cUrl      := "ftp://" + cUser + ":" + cPassword + "@" + cServer
   oUrl              := tUrl():New( cUrl )
   oFTP              := tIPClientFtp():New( oUrl, .F. )
   oFTP:nConnTimeout := 20000
   oFTP:bUsePasv     := .T.
   /* We check if the user has an @ to force the userid */
   IF At( "@", cUser ) > 0
      oFTP:oUrl:cServer   := cServer
      oFTP:oUrl:cUserID   := cUser
      oFTP:oUrl:cPassword := cPassword
   IF oFTP:Open( cUrl )
      oFtp:UploadFile( cFileName )
      oFTP:Close()
      cStr := "Could not connect to the FTP server" + " " + oURL:cServer
      IF oFTP:SocketCon == NIL
         cStr += Chr( 13 ) + Chr( 10 ) + "Connection uninitialized"
      ELSEIF hb_InetErrorCode( oFTP:SocketCon ) == 0
         cStr += Chr( 13 ) + Chr( 10 ) + "Server Response:" + " " + oFTP:cReply
         cStr += Chr( 13 ) + Chr( 10 ) + "Connection Failed:" + " " + hb_InetErrorDesc( oFTP:SocketCon )
      *MSGSTOP(cStr)
FUNCTION XSAVEWINDOWBYHANDLE ( nHandle , cFileName , nRow , nCol , nWidth , nHeight )
LOCAL hBitmap
   hBitmap := BTRL_BITMAPCAPTURECLIENTAREA ( nHandle , nRow, nCol, nWidth, nHeight)
   IF hBitmap <> 0
   IF   UPPER(RIGHT( cFileName , 4 ) ) == '.GIF'
         BTRL_BITMAPSAVEFILE (hBitmap, cFileName , BT_FILEFORMAT_GIF )
   ELSEIF   UPPER(RIGHT( cFileName , 4 ) ) == '.JPG'
         BTRL_BITMAPSAVEFILE (hBitmap, cFileName , BT_FILEFORMAT_JPG )
   ELSEIF   UPPER(RIGHT( cFileName , 4 ) ) == '.PNG'
         BTRL_BITMAPSAVEFILE (hBitmap, cFileName , BT_FILEFORMAT_PNG )
   ELSEIF   UPPER(RIGHT( cFileName , 4 ) ) == '.BMP'
         BTRL_BITMAPSAVEFILE (hBitmap, cFileName , BT_FILEFORMAT_BMP )
   BTRL_BITMAPRELEASE (hBitmap)
RETURN hBitmap
Function BTRL_BITMAPCAPTURECLIENTAREA ( nHandle , Row, Col, Width, Height)
   LOCAL New_hBitmap
   LOCAL Max_Width  := BTRL_CLIENTAREAWIDTH( nHandle )
   LOCAL Max_Height := BTRL_CLIENTAREAHEIGHT( nHandle )
   BTRL_FILLRECTISNIL (@Row, @Col, @Width, @Height, 0, 0, Max_Width, Max_Height)
   BTRL_ADJUSTWIDTHHEIGHTRECT (Row, Col, @Width, @Height, Max_Width, Max_Height)
   New_hBitmap := BT_BMP_CAPTURESCR ( nHandle , Col, Row, Width, Height, BT_BITMAP_CAPTURE_DESKTOP)
Return New_hBitmap
Function BTRL_BITMAPSAVEFILE (hBitmap, cFileName, nTypePicture)
   LOCAL lRet
   nTypePicture := IF (Valtype(nTypePicture) == "U", BT_FILEFORMAT_BMP, nTypePicture)
   lRet := BT_BMP_SAVEFILE (hBitmap, cFileName, nTypePicture)
Return lRet
Function BTRL_BITMAPRELEASE (hBitmap)
   BT_BMP_RELEASE (hBitmap)
Function BTRL_CLIENTAREAWIDTH ( nHandle )
   LOCAL Width := BT_SCR_GETINFO ( nHandle , BT_SCR_CLIENTAREA, BT_SCR_INFO_WIDTH)
Return Width
Function BTRL_CLIENTAREAHEIGHT ( nHandle )
   LOCAL Height := BT_SCR_GETINFO ( nHandle , BT_SCR_CLIENTAREA, BT_SCR_INFO_HEIGHT)
Return Height
Function BTRL_FILLRECTISNIL (Row, Col, Width, Height, Row_value, Col_value, Width_value, Height_value)
   Row    := IF (Valtype(Row)    =="U",  Row_value,    Row)
   Col    := IF (Valtype(Col)    =="U",  Col_value,    Col)
   Width  := IF (Valtype(Width)  =="U",  Width_value,  Width)
   Height := IF (Valtype(Height) =="U",  Height_value, Height)
Function BTRL_ADJUSTWIDTHHEIGHTRECT (Row, Col, Width, Height, Max_Width, Max_Height)
   Width  := IF ((Col + Width  > Max_Width),  (Max_Width  - Col), Width)
   Height := IF ((Row + Height > Max_Height), (Max_Height - Row), Height)
Function BTRL_WINHANDLE (Win)
   LOCAL hWnd := IF (ValType(Win)=="N", Win, GetFormHandle(Win))
Return hWnd
Capturing and saving captured image OK.
But uploading to ftp failed :(
No any error message but file not found in the server :(
Does anyone can test on his own server ?
Viva HMG :D
serge_girard wrote:To Roberto:
Thx,
Basically, the content between #pragma TEXTHIDDEN(1) and #pragma TEXTHIDDEN(0) are not visible looking at the exe file (ie: with an hex editor).
In my case, the server address, port, username and password are 'hardcoded' inside the prg, so, they must be protected from curious people :)
esgici wrote:Does anyone can test on his own server ?
Me :)
It has been working for about two weeks.
Please, check address, username, port and password.
And... un-comment the error message display line to see what's going on...
Roberto Lopez wrote:And... un-comment the error message display line to see what's going on...
This is the line to un-comment:
  *MSGSTOP(cStr)
OOPS...
In fact I've uploaded a lot of unneeded code.
Since in Mustafa utility, the capture is already saved to a file, the only thing needed is the FtpUp() function.
You can ignore all other code.
Sorry.
Roberto Lopez wrote: This is the line to un-comment:
  *MSGSTOP(cStr)
And... please replace:
With:
		IF ! oFtp:UploadFile( cFileName )
			MSGINFO('Upload Error!')
			MSGINFO('Upload Ok!')
Thank you very much,
now I can see: my connection info has some problem :(
( In fact I haven't enough experience on that field :( )
Tomorrow I hope to find some remedies.
Viva HMG :D
Viva HMG :D
If you have not so much experience with FTP, I recommend you: "Quick and Easy FTP Server":
http://www.pablosoftwaresolutions.com/h ... _lite.html
The lite version supports up to three users, this is enough for testing.
Roberto Lopez wrote:...
If you have not so much experience with FTP, I recommend you:...
Thank you very much :arrow:
Viva HMG :D
