Status of source code changes suggested in November 2014
Re: Status of source code changes suggested in November 2014
It is really off topic.
Is there any way to include tables in rich edit text? If it can be, then we can have our Grids/reports to be exported to a well formatted Rich Edit Text File.
Although richedittext is an interesting control, changes proposed by Karmody means investing too much hours to upgrade a control which have restricted uses (proccesing text only).- But what is inadmissible is the rude form Karmody uses to apply for to Claudio.- The best way to be part of a community is speak or write courtly.-
With regards. Eduardo
- srvet_claudio
Yes is possible, but maybe not easy with programming, click in Help icon of: C:\hmg.3.4.1\SAMPLES\Controls\RichEditBoxRathinagiri wrote:Hi,
- srvet_claudio
Ok no problem, I want to believe that is problem of translation.EduardoLuis wrote:But what is inadmissible is the rude form Karmody uses to apply for to Claudio.
- srvet_claudio
Hi Kevin,kcarmody wrote:Following my discussion with Claudio earlier in this thread, I'm resubmitting the following changes, all relating to the RichEditBox control. I've developed a patch, based on Claudio's current patch (patch 6), which incorporates these changes. My patch should be installed on top of Claudio's patch.
Individual modified source files are at http://kevincarmody.com/hmg/, and a zip of files in the patch is at http://kevincarmody.com/hmg/HmgChangeProposal.zip.
This patch includes an overhauled Rich Edit demo, which uses all the source code changes (except for the SelPasteSpecial method). The new Rich Edit demo is at http://kevincarmody.com/hmg/SAMPLES/Con ... chEditBox/.
New manifest constants RTFTXTFILE_ANSI etc.
These constants are RTF and TXT file types returned by the new function GetRtfTxtFileType() and can be used by the RtfTxtLoadFile and RtfTxtSaveFile methods of the RichEditBox control.
http://kevincarmody.com/hmg/INCLUDE/i_richeditbox.ch - lines 161-169
These constants are also used in the Rich Edit demo - http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 883-904 and lines 976-992.Code: Select all
// Following 5 #defines added by Kevin Carmody, September 2015 ***************** * File type * ***************** #define RTFTXTFILE_ANSI 1 // ANSI text file #define RTFTXTFILE_UTF8 2 // UTF-8 text file #define RTFTXTFILE_UTF16LE 3 // UTF-16 LE (little endian) text file #define RTFTXTFILE_RTF 4 // RTF file #define RTFTXTFILE_UTF16BE 5 // UTF-16 BE (big endian) text file
New function GetRtfTxtFileType( cFile, lUtf8Test ) --> nFileType
This function returns a file type (RTF, ANSI, UTF-16, UTF-8) which can be used in RtfTxtLoadFile and RtfTxtSaveFile methods of RichEditBox control.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 52, 512-578
// Following line added by Kevin Carmody, September 2015 #include "fileio.ch"This function is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 880Code: Select all
// Following function added by Kevin Carmody, September 2015 *-----------------------------------------------------------------------------* FUNCTION GetRtfTxtFileType ( cFile, lUtf8Test ) *-----------------------------------------------------------------------------* LOCAL hFile := FOPEN( cFile, FO_READ ) LOCAL cBuffer := SPACE( 5 ) LOCAL nBufRead := 0 LOCAL nType := 0 /* The following code block tests for the presence of non-ASCII characters in an unmarked text file. It assumes that such characters may be ANSI or parts of UTF-8 sequences. In UTF-8 mode, Windows reads bytes which are not part of a valid UTF-8 sequence as ANSI. It would be better to know if the file contained UTF-8 sequences for non-ANSI characters, but since some ANSI characters are not in the Latin-1 Supplement, testing for non-ANSI UTF-8 sequences is inefficient for large files. */ LOCAL bHasUnicodeChars := {|| LOCAL lHasUnicode := .N. LOCAL cChar, cStr cBuffer := SPACE( 0x400 ) nBufRead := 1 BEGIN SEQUENCE WHILE nBufRead > 0 nBufRead := FREAD( hFile, @cBuffer, 0x400 ) IF nBufRead > 0 cStr := LEFT( cBuffer, nBufRead ) FOR EACH cChar IN cStr IF cChar >= CHR(0x80) lHasUnicode := .Y. BREAK ENDIF NEXT ENDIF ENDDO END SEQUENCE RETURN lHasUnicode } BEGIN SEQUENCE IF hFile < 0 BREAK ENDIF nBufRead := FREAD( hFile, @cBuffer, 5 ) DO CASE CASE nBufRead >= 5 .AND. LEFT( cBuffer, 5 ) == "{\rtf" nType := RTFTXTFILE_RTF CASE nBufRead >= 3 .AND. LEFT( cBuffer, 3 ) == E"\xEF\xBB\xBF" nType := RTFTXTFILE_UTF8 CASE nBufRead >= 2 .AND. LEFT( cBuffer, 2 ) == E"\xFF\xFE" nType := RTFTXTFILE_UTF16LE CASE nBufRead >= 2 .AND. LEFT( cBuffer, 2 ) == E"\xFE\xFF" nType := RTFTXTFILE_UTF16BE CASE ! EMPTY( lUtf8Test ) .AND. bHasUnicodeChars:EVAL( ) nType := RTFTXTFILE_UTF8 OTHERWISE nType := RTFTXTFILE_ANSI ENDCASE END SEQUENCE FCLOSE( hFile ) RETURN nType
New function Utf16ByteSwap( cInFile, cOutFile )Code: Select all
LOCAL nFormat := GETRTFTXTFILETYPE(cFileName, .Y.)
This function supports the UTF-16 BE (big endian) file type for the RtfTxtLoadFile and RtfTxtSaveFile methods of RichEditBox control.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 52, 583-623
// Following line added by Kevin Carmody, September 2015 #include "fileio.ch"This function is used in RichEditBox_RtfTxtLoadFile() and RichEditBox_RtfTxtSaveFile() - see below.Code: Select all
// Following function added by Kevin Carmody, September 2015 *-----------------------------------------------------------------------------* FUNCTION Utf16ByteSwap( cInFile, cOutFile ) *-----------------------------------------------------------------------------* LOCAL hInFile := FOPEN( cInFile , FO_READ ) LOCAL hOutFile := FCREATE( cOutFile ) LOCAL cInBuffer := SPACE( 0x400 ) LOCAL nBufRead := 1 LOCAL lSuccess := .N. LOCAL cOutBuffer, cBytePair, nBufWrite, nByte BEGIN SEQUENCE IF hInFile < 0 BREAK ENDIF IF hOutFile < 0 BREAK ENDIF WHILE nBufRead > 0 cOutBuffer := "" nBufRead := FREAD( hInFile, @cInBuffer, 0x400 ) IF nBufRead > 0 FOR nByte := 1 TO nBufRead STEP 2 cBytePair := SUBSTR( cInBuffer, nByte, 2 ) cOutBuffer += RIGHT( cBytePair, 1 ) + LEFT( cBytePair, 1 ) NEXT nBufWrite := FWRITE( hOutFile, cOutBuffer ) IF nBufWrite < nBufRead BREAK ENDIF ENDIF ENDDO lSuccess := .Y. END SEQUENCE FCLOSE( hInFile ) FCLOSE( hOutFile ) RETURN lSuccess
Fixed RichEditBox_StreamIn( hWndControl, cFileName, lSelection, nDataFormat ) --> lSuccess
This function now skips over a byte order mark (BOM) in a Unicode text file if one is present.
http://kevincarmody.com/hmg/SOURCE/c_richeditbox.c - lines 190-192, 199-203, 216-233
This function is called by RichEditBox_RtfTxtLoadFile() - see below.Code: Select all
// RichEditBox_StreamIn ( hWndControl, cFileName, lSelection, nDataFormat ) --> return lSuccess HB_FUNC ( RICHEDITBOX_STREAMIN ) { HWND hWndControl = (HWND) HMG_parnl (1); TCHAR *cFileName = (TCHAR*) HMG_parc (2); BOOL lSelection = (BOOL) hb_parl (3); LONG nDataFormat = (LONG) hb_parnl (4); HANDLE hFile; // Following 3 lines added by Kevin Carmody, September 2015 BYTE bUtf8Bom[3]; BYTE bUtf16Bom[2]; DWORD dwRead; EDITSTREAM es; LONG Format; switch( nDataFormat ) { // Comments in this switch block modified by Kevin Carmody, September 2015 case 1: Format = SF_TEXT; break; // ANSI or UTF-8 with BOM or mixed (UTF-8 BOM removed, overlong UTF-8 accepted, invalid UTF-8 read as ANSI) case 2: Format = ( CP_UTF8 << 16 ) | SF_USECODEPAGE | SF_TEXT; break; // UTF-8 without BOM (BOM not removed) case 3: Format = SF_TEXT | SF_UNICODE; break; // UTF-16 LE without BOM (BOM not removed) case 4: Format = SF_RTF; break; // case 5, UTF-8 RTF, removed by Kevin Carmody, September 2015, because it can never occur default: Format = SF_RTF; break; } if ( lSelection ) Format = Format | SFF_SELECTION; if( ( hFile = CreateFile (cFileName, GENERIC_READ, FILE_SHARE_READ, NULL, OPEN_EXISTING, FILE_FLAG_SEQUENTIAL_SCAN, NULL )) == INVALID_HANDLE_VALUE ) { hb_retl (FALSE); return; } // Following switch block added by Kevin Carmody, September 2015 switch( nDataFormat ) { case 1: break; case 2: if ( ! ReadFile (hFile, bUtf8Bom, 3, &dwRead, NULL) ) // read past BOM if present hb_retl (FALSE); if ( ! ( dwRead == 3 && bUtf8Bom[0] == 0xEF && bUtf8Bom[1] == 0xBB && bUtf8Bom[2] == 0xBF ) ) SetFilePointer (hFile, 0, 0, FILE_BEGIN); break; case 3: if ( ! ReadFile (hFile, bUtf16Bom, 2, &dwRead, NULL) ) // read past BOM if present hb_retl (FALSE); if ( ! ( dwRead == 2 && bUtf16Bom[0] == 0xFF && bUtf16Bom[1] == 0xFE ) ) SetFilePointer (hFile, 0, 0, FILE_BEGIN); break; case 4: break; default: break; } es.pfnCallback = EditStreamCallbackRead; es.dwCookie = (DWORD_PTR) hFile; es.dwError = 0; SendMessage ( hWndControl, EM_STREAMIN, (WPARAM) Format, (LPARAM) &es ); CloseHandle (hFile); if( es.dwError ) hb_retl (FALSE); else hb_retl (TRUE); }
Fixed RichEditBox_StreamOut( hWndControl, cFileName, lSelection, nDataFormat ) --> lSuccess
This function now writes a byte order mark (BOM) to a Unicode text file.
http://kevincarmody.com/hmg/SOURCE/c_richeditbox.c - lines 269-271, 278-282, 295-302
This function is used in RichEditBox_RtfTxtSaveFile() - see below.Code: Select all
// RichEditBox_StreamOut ( hWndControl, cFileName, lSelection, nDataFormat ) --> return lSuccess HB_FUNC ( RICHEDITBOX_STREAMOUT ) { HWND hWndControl = (HWND) HMG_parnl (1); TCHAR *cFileName = (TCHAR*) HMG_parc (2); BOOL lSelection = (BOOL) hb_parl (3); LONG nDataFormat = (LONG) hb_parnl (4); HANDLE hFile; // Following 3 lines added by Kevin Carmody, September 2015 BYTE bUtf8Bom[3] = {0xEF, 0xBB, 0xBF}; BYTE bUtf16Bom[2] = {0xFF, 0xFE}; DWORD dwWritten; EDITSTREAM es; LONG Format; switch( nDataFormat ) { // Comments in this switch block modified by Kevin Carmody, September 2015 case 1: Format = SF_TEXT; break; // ANSI (non-ANSI characters converted to question marks) case 2: Format = ( CP_UTF8 << 16 ) | SF_USECODEPAGE | SF_TEXT; break; // UTF-8 without BOM case 3: Format = SF_TEXT | SF_UNICODE; break; // UTF-16 LE without BOM case 4: Format = SF_RTF; break; // case 5, UTF-8 RTF, removed by Kevin Carmody, September 2015, because it can never occur default: Format = SF_RTF; break; } if ( lSelection ) Format = Format | SFF_SELECTION; if( ( hFile = CreateFile (cFileName, GENERIC_WRITE, FILE_SHARE_WRITE, NULL, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, NULL )) == INVALID_HANDLE_VALUE ) { hb_retl (FALSE); return; } // Following switch block added by Kevin Carmody, September 2015 switch( nDataFormat ) { case 1: break; case 2: WriteFile( hFile, bUtf8Bom, 3, &dwWritten, NULL ); break; // write UTF-8 BOM at head of file case 3: WriteFile( hFile, bUtf16Bom, 2, &dwWritten, NULL ); break; // write UTF-16 LE BOM at head of file case 4: break; default: break; } es.pfnCallback = EditStreamCallbackWrite; es.dwCookie = (DWORD_PTR) hFile; es.dwError = 0; SendMessage ( hWndControl, EM_STREAMOUT, (WPARAM) Format, (LPARAM) &es ); CloseHandle (hFile); if( es.dwError ) hb_retl (FALSE); else hb_retl (TRUE); }
New RichEditBox property HasUnicodeChars (read only)
This property detects whether a rich edit control contains non-ASCII Unicode characters.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10266-10268, at end of _RichEditBox_GetProperty()
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - line 164Code: Select all
// Following case added by Kevin Carmody, September 2015 CASE Arg3 == "HASUNICODECHARS" xData := RichEditBox_HasUnicodeChars ( hWndControl ) RetVal := .T.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 418-440Code: Select all
;; // Following line modified by Kevin Carmody, September 2015 #xtranslate <w>. \<c\> . \<p:RTFTextMode,AutoURLDetect,Zoom,SelectRange,CaretPos,Value,GetSelectText,GetTextLength,ViewRect,HasUnicodeChars\> => GetProperty ( <"w">, \<"c"\> , \<"p"\> ) ;;
This function is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 945Code: Select all
// Following function added by Kevin Carmody, September 2015 /* The following function tests for the presence of non-ASCII characters in a rich edit control. It would be better to know if the control contained non-ANSI characters, but since some ANSI characters are not in the Latin-1 Supplement, testing for non-ANSI characters is inefficient for large documents. */ *-----------------------------------------------------------------------------* FUNCTION RichEditBox_HasUnicodeChars( hWndControl ) *-----------------------------------------------------------------------------* LOCAL cBuffer := RichEditBox_GetText( hWndControl , .N. ) LOCAL lHasUnicode := .N. LOCAL cChar FOR EACH cChar IN cBuffer IF cChar >= CHR(0x80) lHasUnicode := .Y. ENDIF NEXT RETURN lHasUnicode
New RichEditBox method RtfTxtLoadFile( cFile, lSelection, nType ) --> lSuccessCode: Select all
LOCAL lUnicode := wMain.ebDoc.HASUNICODECHARS
This method is a synonym for the RtfLoadFile method. It now uses the file type returned by GetRtfTxtFileType(). It skips over a byte order mark in a Unicode text file, and it supports UTF-16 BE (big endian Unicode text file).
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10440-10442
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - lines 172-173, 175Code: Select all
// Following case modified by Kevin Carmody, September 2015 CASE Arg3 == "RTFLOADFILE" .OR. Arg3 == "RTFTXTLOADFILE" xData := RichEditBox_RtfTxtLoadFile ( hWndControl, Arg4, Arg5, Arg6 ) // by default save in SF_RTF format RetVal := .T.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 445-477Code: Select all
;; // Following 2 lines modified by Kevin Carmody, September 2015 #xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>,\<arg3\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\>, \<arg3\> ) ;; #xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;; ;; // Following line added by Kevin Carmody, September 2015 #xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
This method is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 906Code: Select all
// Following function added by Kevin Carmody, September 2015 *-----------------------------------------------------------------------------* FUNCTION RichEditBox_RtfTxtLoadFile( hWndControl, cFile, lSelection, nType ) *-----------------------------------------------------------------------------* LOCAL lSuccess := .N. LOCAL cTempFile IF ! HB_ISLOGICAL( lSelection ) lSelection := .N. ENDIF IF ! HB_ISNUMERIC( nType ) nType := RTFTXTFILE_RTF ENDIF IF lSelection RichEditBox_UnSelectAll( hWndControl ) ENDIF IF RichEditBox_RTFLoadResourceFile( hWndControl, cFile, lSelection ) lSuccess := .T. ELSE IF nType == RTFTXTFILE_UTF16BE cTempFile := GETTEMPFOLDER() + "_RtfTxtLoadFile.txt" lSuccess := Utf16ByteSwap( cFile, cTempFile ) IF lSuccess lSuccess := RichEditBox_StreamIn( hWndControl, cTempFile, lSelection, RTFTXTFILE_UTF16LE ) ENDIF DELETE FILE ( cTempFile ) ELSE lSuccess := RichEditBox_StreamIn( hWndControl, cFile, lSelection, nType ) ENDIF ENDIF RETURN lSuccess
New RichEditBox method RtfTxtSaveFile( cFile, lSelection, nType ) --> lSuccessCode: Select all
IF ! wMain.ebDoc.RTFTXTLOADFILE(cFileName, .N., nFormat)
This method is a synonym for the RtfSaveFile method. It now uses the file type returned by GetRtfTxtFileType(), writes a byte order mark to a Unicode text file, and supports UTF-16 BE (big endian Unicode text file).
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10445-10447
// Following case modified by Kevin Carmody, September 2015 CASE Arg3 == "RTFSAVEFILE" .OR. Arg3 == "RTFTXTSAVEFILE" xData := RichEditBox_RtfTxtSaveFile ( hWndControl, Arg4, Arg5, Arg6 ) // by default save in SF_RTF format RetVal := .T.
http://kevincarmody.com/hmg/SOURCE/h_richeditbox.prg - lines 482-507Code: Select all
This method is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - line 993Code: Select all
// Following function added by Kevin Carmody, September 2015 *-----------------------------------------------------------------------------* FUNCTION RichEditBox_RtfTxtSaveFile( hWndControl, cFile, lSelection, nType ) *-----------------------------------------------------------------------------* LOCAL lSuccess := .N. LOCAL cTempFile IF ! HB_ISLOGICAL( lSelection ) lSelection := .N. ENDIF IF ! HB_ISNUMERIC( nType ) nType := RTFTXTFILE_RTF ENDIF IF nType == RTFTXTFILE_UTF16BE cTempFile := GETTEMPFOLDER() + "_RtfTxtLoadFile.txt" lSuccess := RichEditBox_StreamOut( hWndControl, cTempFile, lSelection, RTFTXTFILE_UTF16LE ) IF lSuccess lSuccess := Utf16ByteSwap( cTempFile, cFile ) ENDIF DELETE FILE ( cTempFile ) ELSE lSuccess := RichEditBox_StreamOut( hWndControl, cFile, lSelection, nType ) ENDIF RETURN lSuccess
New RichEditBox method SelPasteSpecialCode: Select all
IF ! wMain.ebDoc.RTFTXTSAVEFILE(cFileName, .N., nFormat)
Paste special - needs documentation of clipboard format argument.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 10458-10460
http://kevincarmody.com/hmg/INCLUDE/i_window.ch - line 179Code: Select all
// Following case added by Kevin Carmody, September 2015 CASE Arg3 == HMG_UPPER ("SelPasteSpecial") RichEditBox_PasteSpecial ( hWndControl, Arg4 ) RetVal := .T.
This method is not used in the Rich Edit demo.Code: Select all
;; // Following line added by Kevin Carmody, September 2015 #xtranslate <w>. \<c\> . \<p:SelPasteSpecial\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
Enhanced RichEditBox method RtfLoadFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfTxtLoadFile method described above.
Enhanced RichEditBox method RtfSaveFile( cFile, lSelection, nType ) --> lSuccess
This method is a synonym for the RtfTxtSaveFile method described above.
// Following 2 lines modified by Kevin Carmody, September 2015 #xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>,\<arg3\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\>, \<arg3\> ) ;; #xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>,\<arg2\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;; // Following line added by Kevin Carmody, September 2015 #xtranslate <w>. \<c\> . \<p:RTFLoadFile,RTFSaveFile,RtfTxtLoadFile,RtfTxtSaveFile\> (\<arg1\>) => DoMethod ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> ) ;;
Enhanced function DoMethod ( Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
Enabled this function to return a value from a RichEditBox method.
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - line 8869
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - lines 8881-8882Code: Select all
Function DoMethod ( Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 ) // Following line modified by Kevin Carmody, September 2015 Local xData, i, hWnd
http://kevincarmody.com/hmg/SOURCE/h_controlmisc.prg - line 10416Code: Select all
// Following 2 lines modified by Kevin Carmody, September 2015 IF _RichEditBox_DoMethod ( @xData, Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 ) == .T. Return xData ENDIF
The return value is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 906Code: Select all
// Following line modified by Kevin Carmody, September 2015 Function _RichEditBox_DoMethod ( xData, Arg1 , Arg2 , Arg3 , Arg4 , Arg5 , Arg6 , Arg7 , Arg8 , Arg9 )
The return value is used in http://kevincarmody.com/hmg/SAMPLES/Con ... x/demo.prg - lines 993Code: Select all
I have some suggestions on your code:
1) Insert/remove BOM for UTF16-BE, like:
#define UTF16BE_BOM 0xFEFF
DWORD dwBOM = 0;
if ( ! ReadFile (hFile, &dwBOM, 2, &dwRead, NULL) )
hb_retl (FALSE);
if ( ( dwBOM & UTF16BE_BOM ) != UTF16BE_BOM )
WriteFile( hFile, bUTF16BE_BOM, 2, &dwWritten, NULL );
2) Rewrite:
LOCAL cBuffer := RichEditBox_GetText( hWndControl , .F. )
RETURN HMG_IsUTF8( cBuffer )
#define RTFFILE_ANSI 1 // ANSI text file
#define RTFFILE_UTF8 2 // UTF-8 text file
#define RTFFILE_UTF16LE 3 // UTF-16 LE (little endian) text file
#define RTFFILE_RTF 4 // RTF file
#define RTFFILE_UTF16BE 5 // UTF-16 BE (big endian) text file
RichEditBox_RtfTxtLoadFile and RichEditBox_RtfTxtSaveFile for:
RichEditBox_RTFLoadFile
RichEditBox_RTFSaveFile
CASE Arg3 == HMG_UPPER ("RTFLoadFile")
CASE Arg3 == HMG_UPPER ("RTFSaveFile")
Please, make this changes and send me.
Thank you Claudio. Preparing a pre-formatted RTF using HMG coding would be great and useful.srvet_claudio wrote:Yes is possible, but maybe not easy with programming, click in Help icon of: C:\hmg.3.4.1\SAMPLES\Controls\RichEditBoxRathinagiri wrote:Hi,
This is a simple example given in the net.
{\rtf1\ansi\deff0
\trowd
\cellx1000
\cellx2000
\cellx3000
\intbl cell 1\cell
\intbl cell 2\cell
\intbl cell 3\cell
\row
} South or North HMG is worth.
Hi Claudio,srvet_claudio wrote:Hi Kevin,
1) Insert/remove BOM for UTF16-BE, like:Code: Select all
#define UTF16BE_BOM 0xFEFF DWORD dwBOM = 0; if ( ! ReadFile (hFile, &dwBOM, 2, &dwRead, NULL) ) hb_retl (FALSE); if ( ( dwBOM & UTF16BE_BOM ) != UTF16BE_BOM ) SetFilePointer (hFile, 0, 0, FILE_BEGIN);Code: Select all
2) Rewrite:3) rename constants:Code: Select all
FUNCTION RichEditBox_HasUnicodeChars( hWndControl ) LOCAL cBuffer := RichEditBox_GetText( hWndControl , .F. ) RETURN HMG_IsUTF8( cBuffer )4) rename the function:Code: Select all
#define RTFFILE_ANSI 1 // ANSI text file #define RTFFILE_UTF8 2 // UTF-8 text file #define RTFFILE_UTF16LE 3 // UTF-16 LE (little endian) text file #define RTFFILE_RTF 4 // RTF file #define RTFFILE_UTF16BE 5 // UTF-16 BE (big endian) text file
RichEditBox_RtfTxtLoadFile and RichEditBox_RtfTxtSaveFile for:4) in file h_controlmisc.prg, use only method names:Code: Select all
RichEditBox_RTFLoadFile RichEditBox_RTFSaveFilethe use of RtfTxtLoadFile and RtfTxtSaveFile It is an unnecessary duplecación.Code: Select all
CASE Arg3 == HMG_UPPER ("RTFLoadFile") CASE Arg3 == HMG_UPPER ("RTFSaveFile")
Thanks for your suggestions. I would really like to do these for you, but first please consider the following.
For number 1, it appears you are suggesting that I put this code into RichEditBox_StreamIn and RichEditBox_StreamOut in c_richeditbox.c. I considered this before and found it could not work there. These functions read and write text through the Windows EM_STREAMIN and EM_STREAMOUT messages. These messages accept UTF-8 and UTF-16LE formats but not UTF-16BE. So, unlike UTF-8 and UTF-16LE, for UTF-16BE we cannot remove the BOM and then use EM_STREAMIN or EM_STREAMOUT to read or write the text. I worked around this by using the function Utf16ByteSwap in RichEditBox_RtfTxtLoadFile and RichEditBox_RtfTxtSaveFile to convert between UTF-16BE to UTF-16LE.
For number 2, the function RichEditBox_HasUnicodeChars implements the HasUnicodeChars property. The purpose of this property is to detect whether the buffer has any non-ASCII characters. This is so we can warn the user if he tries to save non-ASCII characters to an ANSI file -- see demo.prg lines 961-965. The HMG_IsUtf8 function does not distinguish betweeen ASCII and non-ASCII. It only determines whether a string is in correct UTF-8 format, and pure ASCII is correct UTF-8. RichEditBox_GetText always returns correct UTF-8 text, so the function as you have written it will always return true.
Numbers 3, 4, and 5 will work, but I would prefer to have the names as RTFTXT instead of RTF only. Before I started making these changes, HMG supported only RTF reading and writing to and from rich edit controls. The changes I am submitting will enable it to support both RTF and TXT files, and I would like the names to reflect that. The name RTFFILE_UTF8, for example, is confusing, because it is not a format of an RTF file, but a TXT file.
Please let me know what you think.
Kevin
I have some experience with tables in RTF. The RTF code that Rathinagiri has given is a very basic RTF table for 3 columns and 1 row, although it is not necessary repeat \intbl for each cell, only at the beginning of a row.Rathinagiri wrote:Thank you Claudio. Preparing a pre-formatted RTF using HMG coding would be great and useful.srvet_claudio wrote:Yes is possible, but maybe not easy with programming, click in Help icon of: C:\hmg.3.4.1\SAMPLES\Controls\RichEditBoxRathinagiri wrote:Hi,
But it is not simple or as easy as HMG! And if it is Unicode, it is further complicated!Code: Select all
{\rtf1\ansi\deff0 \trowd \cellx1000 \cellx2000 \cellx3000 \intbl cell 1\cell \intbl cell 2\cell \intbl cell 3\cell \row }
{\rtf1\ansi\deff0
\trowd
\cellx1000
\cellx2000
\cellx3000
\intbl cell 1\cell
cell 2\cell
cell 3\cell
\row
} The table written with this code will have very thin grid lines around each cell. It is possible to do fancier formatting, but RTF code for tables can get very messy very quickly, and I have never tried to do this.
Unicode is quite easy in RTF. For each character, the syntax is \u followed by the code point in decimal, followed by a question mark. Example \u243? for ó.
A table-to-RTF function would have to have to know how wide the user wants each column to be, and would have to convert UTF-8 to RTF Unicode.
Kevin
I'm sorry, I will try to be more polite.EduardoLuis wrote:But what is inadmissible is the rude form Karmody uses to apply for to Claudio.- The best way to be part of a community is speak or write courtly.
Kevin
- srvet_claudio
Ok, I see your code, you first save in LE and swap, this convert file and Bom in BE, in load the process is inverse, this is ok.kcarmody wrote:For number 1, it appears you are suggesting that I put this code into RichEditBox_StreamIn and RichEditBox_StreamOut in c_richeditbox.c. I considered this before and found it could not work there. These functions read and write text through the Windows EM_STREAMIN and EM_STREAMOUT messages. These messages accept UTF-8 and UTF-16LE formats but not UTF-16BE. So, unlike UTF-8 and UTF-16LE, for UTF-16BE we cannot remove the BOM and then use EM_STREAMIN or EM_STREAMOUT to read or write the text. I worked around this by using the function Utf16ByteSwap in RichEditBox_RtfTxtLoadFile and RichEditBox_RtfTxtSaveFile to convert between UTF-16BE to UTF-16LE.
Your original code only detect ASCII character (firsts 128 character of ANSI and Unicode character set) then is RichEditBox_HasOnlyASCII()kcarmody wrote:For number 2, the function RichEditBox_HasUnicodeChars implements the HasUnicodeChars property. The purpose of this property is to detect whether the buffer has any non-ASCII characters. This is so we can warn the user if he tries to save non-ASCII characters to an ANSI file -- see demo.prg lines 961-965. The HMG_IsUtf8 function does not distinguish betweeen ASCII and non-ASCII. It only determines whether a string is in correct UTF-8 format, and pure ASCII is correct UTF-8. RichEditBox_GetText always returns correct UTF-8 text, so the function as you have written it will always return true.
I think this function is unnecessary in RichEdit because it is very easy to write and only in very special cases is required. In addition is far from the characteristics of the Windows control which is mainly thinking for working with RTF files.
kcarmody wrote:Numbers 3, 4, and 5 will work, but I would prefer to have the names as RTFTXT instead of RTF only. Before I started making these changes, HMG supported only RTF reading and writing to and from rich edit controls. The changes I am submitting will enable it to support both RTF and TXT files, and I would like the names to reflect that. The name RTFFILE_UTF8, for example, is confusing, because it is not a format of an RTF file, but a TXT file.
Then the right thing is RichEditBox_SaveFile() and RichEditBox_LoadFile(),
#define RICHEDITFILE_UTF8
