Messages OFF TOPIC from another HMG 3.4.1 topic
Re: Messages OFF TOPIC from another HMG 3.4.1 topic
Amarante wrote: I believe that you did not understand my thinking.
I tried to say that the language was never a barrier to people to express forum.
And I do not think English is the best language for it.
The best language is the willingness to understand others and see it missing here.
For a good listener, half a word is enough.
Definitely you made some private conversations after your previous post :mrgreen:
Here became the Tower of Babel because of language chaos built by some people based on above pretexts.
If not found some hidden intents behind that subversive activities, best solution is Roberto's suggestion :arrow:
Viva "unclouded" HMG :D
Amarante wrote:Esgici,
Acredito que você não compreendeu meu pensamento.
Não é que eu queira jogar mais fogo na fogueira, mas devo dizer que ele não vê porque lamentavelmente não consegue...
Amarante wrote:Eu tentei dizer que o idioma nunca foi barreira para as pessoas se expressarem no fórum.
E não acho que o inglês seja o melhor idioma para isso.
O melhor idioma é a boa vontade de entender o próximo e vejo que isso falta aqui.
Para um bom entendedor, meia palavra basta.
Amigo, você tem muito bom senso e outra vez digo: lamentavelmente você tem razão, porque como queríamos que isso você bem diferente.
I'will answer to you Esgici, once again in public, because you decided to treat this in public and acuses us for something unfair.
esgici wrote:Definitely you made some private conversations after your previous post :mrgreen:
We can prove with forum database that you are completely wrong my friend !
You use to do this disgusting things... (many colleagues here) could confirm that you send private messages to make complot about me... this I'm pretty sure about that (and I know very well their names) !
Why you not confirm that you have sent to Roberto a PM to claiming a lot about me ?
Come on put your hand in your heart and tell us if is true what I'm saying... (I'm not stupid).
esgici wrote:Here became the Tower of Babel because of language chaos built by some people based on above pretexts.
Have you welcome ! Here's a INTERNATIONAL forum. Many people: many languages.
Roberto Lopez wrote:The site should be reorganized based on major native languages of our users, in the same way like (ie) the Fivewin forum does.
Roberto, puedo tratarte de igual para igual ?
Sé que mi cabeza la estaré poniendo a disposicion, porque creo que me vás a odear o me vás a perdonar por lo que voy a decir.
Ya que hablás de FiveWin forum, muy buen ambiente y muy productivo tambien. La cual tambien participo, eso porque mantengo mi cabeza abierta, creo que muchos me entenderan. Pero a diferencia de allá y aqui, Antonio Linares cuando le hablan en español él responde en español, él no niega su raiz, su cultura y/o el buen entendimiento. Aqui parece que cuando hablamos en español, es algo totalmente errado. Esa es la impresion que tengo, creo que se deba más porque vos sos argentino y hablás en castellano/español y aqui hay vários que nos sentimos en casa poder hablar en nuestra lengua nativa. Entonces pienso que los que no son hispanicos, pueden sentir un cierto celo. Yo no tengo la culpa de vos ser argentino o que yo lo sea, pero ventajas entre nosotros no las hay, solo el mismo idioma cuando es usado y eso no ocurre hace mucho (por lo menos de tu parte y de otros colegas hispanicos). Por qué todo eso ? Es un crimen escribir en español ? Nos tenemos que cuidar para comunicarnos ? Para mi todo esto es un mero capricho de quienes quieren todo fácil y quedan reclamando y haciendonos sentir mal porque no escribimos en inglés.
Yo escribo en español, talvez un poco enredado visto a mi formacion aqui en Brasil (país que tanto amo, uno de los mejores países del mundo para vivir) y me gusta hablar los dos, porque yo hablo con el corazon. No con la vanidad que el ingles exige. Esa es mi opinion personal, puede ser que yo sea el único a sentirme asi. Pero cuando quiero que algo se resuelva de la mejor forma, rápida y efectiva con mi ayuda, lo hago en español/português o English (hasta en mayusculas tiene que ser) cuando la otra persona habla el mismo idioma que yo. Eso es un crimen ? Tenemos que ser dividido por eso ?
Todo deben haber leído mi primer mensaje en este tópico (en ingles), talvez no pude expresar con palabras correctas para alcanzar el buen entendimiento con todos.
Pero alli pregunto al colega: tienes interés en ese asunto ? no me entendiste ? Por qué no preguntas lo que no entendiste ?
Nada de eso obtuve respuesta, eso porque creo que es pura vanidad, puro comodismo, algun celos por detrás, alguna envidia ? -> talvez !
Dejemosnos de perder el tiempo con este asunto que está irritando a todos.
Yo aprendi a callarme en la vida (tengo 50 años), pero naci hablando la verdad.
La verdad hay que decirla, cueste lo que cueste hermano. Quien es cristiano, sabe lo importante que es eso.
No se puede pretender que todos dominen el ingles y vos como buen suramericano que eres sabés a lo que me refiero. Sabés lo que nos cuesta a todos dominar ese idioma estranjero. Al margen de cualquier cuestion politica que lamentablemente está ocurriendo y afectando a todos en forma global. No podemos dejar nuestras raíces, no podemos dejar de lado nuestra cultura, no podemos olvidarnos de lo mejor que un latino sabe hacer: hablar con el corazon !
Quieren obligarme a escribir en ingles, quieren empujar eso. No quiero ser robotizado, quiero ser libre de poder hablar lo que siento y si aqui no es lugar para hacerlo: entonces estoy perdiendo mi tiempo.
Como dije y dijieron mucho colegas sábios aqui en el fórum: dejemosnos de estar discutiendo estas pavadas y empecemosnos a respectar uno al otro. Algunos hablan de respecto, pero no lo tienen cuando es en español... vamos que es eso ? Una dictadura ? El dueño de este site que es Rathinagiri (creo yo) y que es el admisnitrador del fórum ya dijo, nadie es obligado a un idioma restricto (sea en ingles o sea en español): FREE COMMUNICATION !
Yo ya hé visto en la seccion Español, escribiendo en ingles. Alguien de los hispánicos se quejó ? Nadie !!!
Yo sé Roberto que pensarás que un dia tuvistes la mala suerte de crea la seccion Español. Pero vos tuviste muy buena intencion y merecés crédito tambien por eso. Pero algunos, te hacen sentir mal por eso: no es asi ?
Yo puedo afirmar que es asi, porque te veo con buenos ojos Roberto, eso porque te veo con los ojos de HMG.
Esta todavia es mi segunda familia, amo estar aqui y poder crecer y creo que asi como yo mucho se sienten igual, agradecidos y no estar protestando... que es lamentable, parece que son desagradecidos...
Y por favor respondeme mis mensajes, me duele que vos me desprecies o me hagas un hielo.
Creo que una forma de entendernos es comunicandonos, hablando, escribiendo pero el silencio no hace bien a nadie.
Ahhh me olvidaba. Cierta vez fui acusado, por la misma persona en que tu Roberto confias y eres tan amigo, dijo en re-edictar mensajes de los participantes aqui en el forum.
Quiero volver aclarar que esa NUNCA pero NUNCA hé cambiado el contexto, teor, fundamento a ningun mensaje de otros.
Cometí el error de traer el mismo concepto que tenia cuando era moderador en otro forum, porque allá si hay reglas, bien claras y está todo definido como tambien sigue el buen comportamiento y trato entre miembros de aquél forum (que el señor Toledo lo diga). Pero ese error fué porque yo era reciente y jamás pero jamás el Rathi me dijo que aqui no hay reglas. Presenté muchas ideas, muchas se adopataron pero esta de las reglas: NO. Y fué eso que me vi prejudicado y que hasta el dia de hoy no me olvido porque me acusaron de re-edictar los mensajes de la gente. Edictaba si, pero era para adicionar las notas de moderacion, dando el motivo de la accion.
Tambien quiero informate Roberto y demás, que ese mismo señor le pidió al Sr. Rathinagiri que le diera los super poderes como moderador para poder re-edictar (según él) sus mensajes. Y fué concedido, tal es asi que pudo apagar las cosas malas que me dijo (debe ser por conveniencia, yo nunca hice eso), lo que está dicho está dicho. Y quedó meses usando eses super poderes, hasta que el dia en que yo lo descubrí y hice un pirnt screen del lugar indebido en que este usuário estaba.Todo eso despues de tantas barbaridades que me dijo y aprontó. No quiero su expulsion, solo quiero revelar todo lo que pasó y me la morfé solito... (solo mi familia sabe). El tiempo revela y hace justicia porque la luz impera (ya leiste esto en algun lugar ?). Pero bueno, si aqui quieren las cosas como están... es un asunto que debe ser pensado bien. Porque yo discordo en no haber regla alguna.
Yo quiero el bien de HMG.
Soy yo por acaso el mal en todo esto ?
O les molestan que hable la verdad ?
Hoy en dia contamos con muchos muchos recursos de traduccion (no soy yo el único que lo dice) y entonces pregunto cual es el problema ?
No es suficiente todo lo que uno hace ? Quiere todo masticado ? Todo servidito ? Todo en el idioma que algunos más le convenga ? Torre de Babel ? Que feo esa descriminacion, porque para mi no pasa de eso.
Dejemos de actuar asi ! Ya ! Ahora o será que quiere hacerme callar ? Puedo hablar lo que siento ? Creen que decir la verdad es malo ?
Quisera poder poner un fin a este tema. Me gustaria mucho trancar el tópico. Pero no me dejan... :(
Yo ya habia considerado por finalizado este asunto, creo que ustedes volvieron con más fuego...
(eso por mala influencia de alguien) lamentablemente...
Si quieren todos ustedes, cambios: entonces hagamos las cosas bien.
No se puede conducir un forum donde no hayan reglas cuando exigen esto, lo otro... para exigir algo, debe haber una regla de fórum. Algo que los moderadores, administradores y usuários puedan guiarse. No se puede exigir algo porque a alguien se lo ocurrió...
PS: La escrita en color rojo fué adicionada despues de postearla. El mensaje sufrió alteracion.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
The problem is not language than the content, many times I read the posts in Spanish and then I see that something is unimportant and perhaps for that reason avoid posts that are not in English.
For me write how you want, but what is important to highlight that somehow challenges the attention and to look at, can only *** and being all clear
Recently it was that you complained to translate into English and after no answer to that text.
Hi Dragan,
I never said and never will say NO for translations if is required with gentle but not as funny thing...
Please do not make confusion with MOL's sense of humor ...
When somebody do not understand something, he/she ask for more explanations about (normally makes quotation of text) when is not been understood. Right ?
Even when some others latin speaker writes in bad only in English and I could not understand anything. I write: "Sorry, I do not understand...". And this happen when they are making their translations with some abreviated native words or using some king of slangs and they not put together the native language, what it could be for improving and the better understanding when is in the same language. And all of these happen, because latinos are feeling that we are forced to write in English at any instance. Not everybody are master in Enlgish. The good understanding always could happen. PATIENT should be the way and ASK what you do not understand.
Here's is Babel, because there are many user from many countries, then many languages too. This should be not a problem, right ?
Amarante
Post by Amarante »
Esgici,
Diferente do que você pensa, já que não me conhece, eu não sou maquiavélico e nem sou um imbecil para ser manipulado. Não uso Mensagens Privadas para conspirar.
Para mim este assunto está encerrado, já que não acrescenta em nada ao crescimento de HMG.
"O sábio pode mudar de opinião, o ignorante nunca."
Immanuel Kant
Esgici,
Different than you think, because you do not know me, I'm not Machiavellian nor am I a fool to be manipulated. I do not use private messages to conspire.
For me this matter is closed, since it does not add anything to HMG growth.
"The wise man can change his mind, the ignorant never."
Immanuel Kant
A ja tylko chciałem, żeby nie mieszać w postach ważnych dla wszystkich angielskiego i hiszpańskiego.
Tłumaczcie sobie to jak chcecie, ciekawe, co wam google podpowie :-D
Nikogo personalnie nie chciałem urazić, bo nic złego w moim poście wywołującym tą dyskusję nie było.
mol wrote:Nikogo personalnie nie chciałem urazić, bo nic złego w moim poście wywołującym tą dyskusję nie było.
So, why have you done that infame question in public ?
By the way. What is Tłumaczcie ? (seems not academic word or it's bad written)
Roberto Lopez wrote:My humble opinion:
- English Forums
- Foros en Español
- Forum Italiani
- Forum Portuguese
- Forum German
This way, users can choose your preferred language.
Simple as that.
And...
I'm not interested on answer to aggressive / disrupting comments.
I just believe that if there is a controversy and the best way I know, to solve controversies is THE DEMOCRACY.
So, this should be the decision of the users.
A poll, should be created.
We want an unique forum with no rules about language or language specific ones (like my proposal)?
I'm sure that all we will accept the users decision. Hopefully, that will end discussions creating division between HMG users.
PS: You can add 'no language rules' to my original list of proposed forums :)
