SET TOOLTIPBACKCOLOR
emzampi
Re: SET TOOLTIPBACKCOLOR
Post by emzampi »
changing profiles areo set TOOLTIPBACKCOLOR works,
There is the possibility that this "anomaly" is answered?
Thank you for your help
For me it's working Mr Claudio ! Thank you again !
emzampi
Post by emzampi »
hello, I tried to insert the hmg.3.3.1_Patch5 and my program stopped working giving me the following errors
attachment before excluding this command from the program "" "busta1.retr_d.tooltip: = ('ZA1 =' + str (m, 8.3) + '- (' + str (NVALUE2,8,3) + '* ('+ str (NVALUE1,8,3) +' + '+ str (nore12,8,3) +' + '+ str (nore14,8,3) +')) ') "" "b attached after excluded (note in the program there are other tooltip)
emzampi wrote:hello, I tried to insert the hmg.3.3.1_Patch5 and my program stopped working giving me the following errors
Thanks for report the bug, please test with this new patch: viewtopic.php?f=43&t=3827&p=38507#p38507
emzampi
Post by emzampi »
thanks, it works with the new patch 5b
But 'SET TOOLTIPBACKCOLOR only works without aero mode?
I have tried your program indicated in the post and it works with the size and colors of the characters, but not with the background mode aero win. that's right!?
Yes, TOOLTIPBACKCOLOR not work with Windows Theme.
emzampi
Post by emzampi »
ok tanks
Hola Dr. Claudio Soto,
A mi solo me funciona en Window Clásico pero no en Windows 7 Basic que ambos no son de Aero.
Esto es correcto?
Javier Tovar wrote:Hola Dr. Claudio Soto,
Esto es correcto?
Works fine for me in Aero and non Aero styles (Win 7).
