Re: HMG 2.8.3 (Forum Test)
Posted: Tue Apr 14, 2009 2:04 pm
Thanks, but I can't accept; you don't read my recent post about good/bad tester ?sudip wrote: ... A good tester "must" be like you!!! ...
Only a joke
Exclusive forum for HMG, a Free / Open Source xBase WIN32/64 Bits / GUI Development System
http://mail.hmgforum.com/
Grigory,gfilatov wrote: You are right! I've a small fix for this issue in h_windows.prg below:
Please be so kind to test it
Roberto,Roberto Lopez wrote:Grigory,gfilatov wrote: You are right! I've a small fix for this issue in h_windows.prg below:
I've not tested, but I'm afraid that your solution allows multiple execution of OnChange event when you click in a different row and column, from previously selected.
Please, check it.
In standard grid, you can select an entire row and 'Onchange' is fired when you change the selection (the row).gfilatov wrote: I've tested with Esgici's sample and it runs a two OnChange events when you click in a different row and column.
But it may be right because you change a two elements - row and column![]()
mmm...gfilatov wrote: If you click in a different row and similar column it runs one OnChange event.
If you click in a different column and similar row it runs one OnChange event also.![]()
OOPS! I've not noticed about that. It could screw up the tests...gfilatov wrote: Remark: you should remove the OnChange events in the spinners in Esgici's sample
I had fully removed both spinners and added STATUS BAR for tracking changes.Roberto Lopez wrote:OOPS! I've not noticed about that. It could screw up the tests...gfilatov wrote: Remark: you should remove the OnChange events in the spinners in Esgici's sample
RegardsRoberto Lopez wrote:the internal variables holding the new values were updates AFTER the event is called
Roberto, perdoná mi ignorancia, el parche 2.8.3 lo debo actualizar sobre qué versión? lo hice sobre la 2.7.2 y cuando ejecuto el ejemplo GRID_21 me dá error, lo mismo que el ejemplo GridTest de Egisci y con GRID_22 no veo que la navegación sea por celda, evidentemente debe ser sobre otra versión no?Roberto Lopez wrote:Well...
I hope that this be the last one
I've made various changes:
1. I've eliminated Set CellNavigation On | Off command.
2. I've added the 'CellNavigation' property to grid.
3. I've modified the original sample and added another.
4. Fixed a problem with OnChange event (Thanks to Esgici).
The sources are attached to this message.
Please test it and report any problem.
If all goes fine I'll do a full release with it.
Roberto.
Thank You Esgici for you words and help!!!esgici wrote:Hola Fernando
I'm happy by seeing you in the "test team"![]()
Please open .rar file on a clean ( not applied privious patch) version 2.81.
