HMG_HPDF - Export to PDF made easy... (New Version)
Request to add border option for Image object
Dear Rathi,
Add following line
@ 17, 07 HPDFPRINT rectangle to 129, 153 penwidth 2 color { 0, 0, 255 }
after / before code for IMAGE 'peacock.png' it looks nice
This message make me crazy :mrgreen:
xxx.exe stopped !
Windows can search a solution to this problem.
> Search online help
> Close program
Problem is : if you have an image to add to .pdf, the image file must be exist;
otherwise Window will make you crazy :mrgreen: until you find the source of error.
By the way, some (probably all) function of hbhpdf library returns pointers, no objects.
ExcptErr.zip
Exception error log
(1.39 KiB) Downloaded 381 times
ErrorRpt.zip
Some humble suggestions to avoid such errors
(717 Bytes) Downloaded 354 times
Hi
A new version of HPdfDemo :)
Added:
  • - a table : COMPANY ( hard coded company info removed )
    - an option : WayBill
    - VAT
    - Multiple pages
Changed : some cosmetics
Pleas note that hmg_hpdf.Prg is slightly different than original.
Enjoy :D
Screen shoot of HPdfDemo 2012.10.04
HPdfDemoCA04.zip
Source files and test tables of HPdfDemo 2012.10.04
(104.38 KiB) Downloaded 429 times
esgici wrote:Hi
HPdfDemoCA04.zip
Good
I have attached herewith a new version of HMG_HPDF.
Change Log:
1. Error checking and avoiding (Thanks to Esgici). Image file is tested for existence now.
2. Implemented Rounded Rectangle. Now we can set the curve length also. Please see the sample.
3. "Set HPDFDOC PERMISSION to" and "Set HPDFDOC PageMode to" commands. I don't know what these commands do. Please see the hmg_hpdf.ch file for details.
pdf.zip
(582.43 KiB) Downloaded 445 times
Thanks a lot Mr. Diamond :D
Best regards
rathinagiri wrote:I have attached herewith a new version of HMG_HPDF.
Change Log:
pdf.zip
PDF created by following command
"SET HPDFDOC PASSWORD OWNER 'owner' USER 'user'"
PDF opened by user password user can do all function like view, copy print, edit PDF
Command "SET HPDFDOC PERMISSION TO READ" will permit to user to read file only
[Mainly this type of file use to send password to user by mail etc.]
Command "SET HPDFDOC PERMISSION TO PRINT" will permit to user to PRINT PDF file
Command "SET HPDFDOC PERMISSION TO COPY" will permit to user to copy PDF content
rathinagiri wrote:...Implemented Rounded Rectangle...
Tested, works perfect :arrow:
Again, thanks a lot :)
Also tried a shadow effect by adding (by courtesy of author) two new HPDFPRINT commands :
#xcommand @ <Row>, <Col> HPDFPRINT ERASE TO <ToRow> , <ToCol> ;
_HMG_HPDF_RECTANGLE ( <Row> , <Col> , <ToRow> , <ToCol> , , 255, 255 , 255 , .F. , .T. , .T. )
#xcommand @ <Row>, <Col> HPDFPRINT ERASE TO <ToRow> , <ToCol> ROUNDED;
_HMG_HPDF_ROUNDRECTANGLE ( <Row> , <Col> , <ToRow> , <ToCol> , , 255, 255 , 255 , .F. , .T. , .T. )
This implementation assume that back-color is WHITE.
Does we can define and query back-color ?
My method for ( rounded ) shadow effect is :
@ nRow + 1, nCol + 1  HPDFPRINT RECTANGLE ;
                       TO ( nRow + 36 ), ( nCol + 111 ) ;
                       FILLED COLOR LIGHTGRAY ;
                       ROUNDED
@ nRow,  nCol  HPDFPRINT ERASE TO nRow + 35, nCol + 110 ROUNDED
@ nRow,  nCol  HPDFPRINT RECTANGLE ;
                       TO nRow + 35, nCol + 110 ;
                       ROUNDED
In HPdfDemo.prg, add this two line at beginning of WriteCompany procedure, after deleting
@ nRow + 1,  nCol + 1  HPDFPRINT RECTANGLE ; ...
command.
HMG PDF Rounded Rectangle and shadow effect
Hi Dave
bpd2000 wrote:...following commands...
Apparently you are a good researcher :arrow:
So you can build a good documentation ( user guide ) for HMG_HPDF, I think ;)
Hi
IMHO it's time to introduce national characters subject ;)
