Harbour MiniGUI 2.8.2
Re: Harbour MiniGUI 2.8.2
esgici wrote:
gfilatov wrote: We have a Cell read/write property for that. :idea:
Sorry, where is selected :?:
Hi Esgici,
Take a look for the following working sample (function SetGridCell(row,col) especially):
* MiniGUI Grid Demo
* (c) 2009 Roberto Lopez
#include "minigui.ch"
Local aRows [40] [3]
	SET CELLNAVIGATION ON
	DEFINE WINDOW Form_1 ;
		WIDTH 640 ;
		HEIGHT 400 ;
		TITLE 'Mixed Data Type Grid Test' ;
		MAIN
		DEFINE MAIN MENU
			DEFINE POPUP 'File'
				MENUITEM 'Set Value'	ACTION Form_1.Grid_1.Value := 5
				MENUITEM 'Get Value'	ACTION MsgInfo( Str ( Form_1.Grid_1.Value ) )
				SEPARATOR
				MENUITEM 'Set Value 5 Column 2'	ACTION SetGridCell(5,2)
				MENUITEM 'Set Value 10 Column 1'	ACTION SetGridCell(10,1)
				MENUITEM 'Set Value 40 Column 3'	ACTION SetGridCell(40,3)
			END POPUP
		END MENU
		aRows [1]	:= {'Simpson','Homer','555-5555'}
		aRows [2]	:= {'Mulder','Fox','324-6432'}
		aRows [3]	:= {'Smart','Max','432-5892'}
		aRows [4]	:= {'Grillo','Pepe','894-2332'}
		aRows [5]	:= {'Kirk','James','346-9873'}
		aRows [6]	:= {'Barriga','Carlos','394-9654'}
		aRows [7]	:= {'Flanders','Ned','435-3211'}
		aRows [8]	:= {'Smith','John','123-1234'}
		aRows [9]	:= {'Pedemonti','Flavio','000-0000'}
		aRows [10]	:= {'Gomez','Juan','583-4832'}
		aRows [11]	:= {'Fernandez','Raul','321-4332'}
		aRows [12]	:= {'Borges','Javier','326-9430'}
		aRows [13]	:= {'Alvarez','Alberto','543-7898'}
		aRows [14]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [15]	:= {'Batistuta','Gol','485-2843'}
		aRows [16]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [17]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [18]	:= {'Samarbide','Armando','854-7873'}
		aRows [19]	:= {'Pradon','Alejandra','???-????'}
		aRows [20]	:= {'Reyes','Monica','432-5836'}
		aRows [21]	:= {'Fernandez','Raul','321-4332'}
		aRows [22]	:= {'Borges','Javier','326-9430'}
		aRows [23]	:= {'Alvarez','Alberto','543-7898'}
		aRows [24]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [25]	:= {'Batistuta','Gol','485-2843'}
		aRows [26]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [27]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [28]	:= {'Samarbide','Armando','854-7873'}
		aRows [29]	:= {'Pradon','Alejandra','???-????'}
		aRows [30]	:= {'Reyes','Monica','432-5836'}
		aRows [31]	:= {'Fernandez','Raul','321-4332'}
		aRows [32]	:= {'Borges','Javier','326-9430'}
		aRows [33]	:= {'Alvarez','Alberto','543-7898'}
		aRows [34]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [35]	:= {'Batistuta','Gol','485-2843'}
		aRows [36]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [37]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [38]	:= {'Samarbide','Armando','854-7873'}
		aRows [39]	:= {'Pradon','Alejandra','???-????'}
		aRows [40]	:= {'Reyes','Monica','432-5836'}
		@ 10,10 GRID Grid_1 ;
			WIDTH 500 ;
			HEIGHT 322 ;
			HEADERS {'Column 1','Column 2','Column 3'} ;
			WIDTHS {100,100,100} ;
			ITEMS aRows ;
			VALUE 1 EDIT
	Form_1.grid_1.setfocus
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Function SetGridCell(x,y)
Local i, z := GetGridColumnNumber( 'Form_1', 'Grid_1' )
	Form_1.Grid_1.Value := x
	if z > 1
		For i := 1 To z - 1
			INSERTLEFT()
			do events
		Next
	For i := 1 To y-1
		INSERTRIGHT()
		do events
	Next
FUNCTION GetGridColumnNumber( cWindowName, cGridName )
RETURN ( _HMG_SYSDATA [15] [ GetControlIndex ( cGridName , cWindowName ) ] )
* Low Level C Routines
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
#include "hbapiitm.h"
HB_FUNC (INSERTLEFT)
			keybd_event(
			VK_LEFT	,	// virtual-key code
			0,		// hardware scan code
			0,		// flags specifying various function options
			0		// additional data associated with keystroke
HB_FUNC (INSERTRIGHT)
			keybd_event(
			VK_RIGHT ,	// virtual-key code
#pragma ENDDUMP
I hope that helps.
Ok....
I've read all the messages (Grigory, Esgici, Rathinagiri).
I propose the following:
- 'Value' property will return an array with row and col selected for a grid only when Set CellNavigation is On.
- If no cell is selected, it will return {0,0} as result.
Property will be read/write.
As Grigory said, 'Cell' property allows read and write cell content for a grid.
Rathinagiri: 'Item' property already exists and allows to set or get an entire row via an 'n' elements array (when 'n' is the number of columns of the grid).
I'm listening...
Fantastic Roberto. That would be more than enough for me. :)
Roberto Lopez wrote: - 'Value' property will return an array with row and col selected for a grid only when Set CellNavigation is On.
In universal :) language :
  if IsCellNavigationOn
     if IsSelectionMade
         value := { nSelectedRowNo, nSelectedColNo }
         value := { 0, 0}
     if IsSelectionMade
         value := nSelectedRowNo
         value := 0
After that there isn't anything to talk; that's all.
Thanks a lot Roberto :D
Best Regards
Grigory, Rathinagiri, Esgici, All...
I've attached to this message 2.8.2 modified code with changes to value property in 'by cell' grids.
Merge H_windows.prg and h_controlmisc.prg with 2.8.2 an test it.
A demo is included too.
TIA.
hmg283b.rar
(52.41 KiB) Downloaded 369 times
Thanks a lot Roberto. :)
One of my friends when leaving the college, wrote a note to me saying "Be a volcano!". And, I am seeing such a person being a volcano today. :)
rathinagiri wrote:Thanks a lot Roberto. :)
He isn't volcano, he is simply a ROY :!: !
But not by inheritance, by fist law :!:
It works fine, thanks a lot Roberto :D
Best Regards
Test result for Selected Row/Col values in Grid Sample.
Roberto Lopez wrote: I've attached to this message 2.8.2 modified code with changes to value property in 'by cell' grids.
Hi
I want make some experiments on this demo.
I had encountered some questions and can't find answer by myself :(
All of these are probably my faults. But more importantly ONCHANGE event doesn't triggering by column changing; works only by row changing; this may be normal behavior?
Sorry for delayed report after impatient confirmation :(
Best Regards
Hi
Best Regards
This code doesn't work because is not correct:
* IF IsControlDefined( "spnRow", "Form_1" ) // This doesn't work !
You've omitted the underscore '_' (_IsControlDefined) should be used if the arguments are strings.
The other problem is that I've not considered that OnChange event should be fired when selected column changes.
