HMG 3.2 (Stable)
Re: HMG 3.2 (Stable)
Something is wrong with ANSI version of HMG3.2
I've rebuilt library to ansi version, but I get strange mosaic within GRID controls:
When I use BROWSE, everything looks OK:
So this stable version is not so stable :(
HMG 3.2 (Stable)
mol wrote:So this stable version is not so stable :(
I regret your frustration Marek and I hope that everything will be solved for you. But his designation of "stable" should not exist !! For this and any other version release. :oops:
Not that this release or any other is not stable, in my opinion this classification of releases do not need these ratings.
Everything is new, should be tested and nothing is perfect or error free.
Wait for a product that does not contain flaws is like believing in invincibility, this is something that you need never be improved or overcome.
mol wrote:Something is wrong with ANSI version of HMG3.2
Hi Marek.
This strange behavior of GRID is only in HMG.3.2 or also exists in HMG.3.1.5?
PS: you do not need to rebuild the lib to work in ANSI, you just need to in Unicode put at the beginning of Main function:
SET CODEPAGE TO POLISH
and continue programming in ANSI without any changes in the code (eg len, left, upper, lower, at, etc. functions).
You should consider the Unicode as a code page more (SET CODEPAGE TO UNICODE).
Hi Marek.
HMG 3.1.5 was OK.
I've reinstalled HMG 3.2 to backward rebuilding library and GRID looks OK.
So, something is wrong with recompilation of library.
Another problem I found with CREATE EVENT. I can't describe it now, I'll try to detect what is wrong - the same sample works OK with HMG315.
Post by EduardoLuis »
Hi Friends:
I've tested (not in deep) all my developements compiling them using new 3.2 version, and all works fine (till now i hope it still continue fine).-
For the records, i only installed it on a new folder and copyed new IDE's posted by Claudio.
I don't make any library recompilation.- I use both IDE ANSI & UNICODE (with SET CODEPAGE TO SPANISH).-
As Daniel Maximiliano notice some trouble with AVAST, i use ESET and no warning was recieved.
I'll continue with the tests.-
Eduardo
EduardoLuis wrote:Hi Friends:
Eduardo
Thanks Eduardo.
dhaine_adp
Post by dhaine_adp »
I rebuild HMG 3.2 Stable in Unicode and compiled three of my Apps and so far I don't have a problem. I recompiled because I wish to see if I can rebuild the library.
I think Marek's problem is localized to the Grid Control (if there are changes to it). IMHO
Danny
Danny
Manila, Philippines
dhaine_adp wrote:I rebuild HMG 3.2 Stable in Unicode and compiled three of my Apps and so far I don't have a problem. I recompiled because I wish to see if I can rebuild the library.
Thanks Danny.
dhaine_adp wrote:I think Marek's problem is localized to the Grid Control (if there are changes to it). IMHO
Except Tree control, the other controls are unchanged are the same as in HMG.3.1.5
dhaine_adp wrote:Hi All,
Danny
I'm using ANSI only. No problems with 3.15. So it's strange...
HMG 3.2 (Stable)
Hi Marek,
Is it possible you post any short example with the same behaviour ?
