HMG Case
Re: HMG Case
Hola dragancesu,
En la pantalla siguiente:
-Que trabajo viene a ser "Block", por que unos campos tienen Block = 1 y otros Block = 2 ???
-"Input" y "Edit" no es lo mismo???
-Por que tienes 2 "Display"
-Para que sirven los campos DBF, Key, Valid y Display.
-Y que diferencia hay entre "Form" y "M/D Forms"
Disculpa mis preguntas pero quiero saber el funcionamiento de tu programa.
P.D.: No se como quitar la segunda imagen.
Re: HMG Case
Hola,
También al querer compilar el ejemplo "DICT" me sale este error:
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: HMG Case
Post by dragancesu »
Form is to work with a single table, M/D is a Master / Detail form and is designed to work with two tables that have a field for the relation
A typical example is the invoices in one table (order) position number, date, customer code, and still somewhat in the second (items) store items: number, code, quantity, price
In this case the field code finds out the relationships between tables, each order has one or more items (usually more)
It is something that I struggled and once a topic
viewtopic.php?f=5&t=3434" onclick="window.open(this.href);return false;
and when I decided I set an example
http://hmgforum.com/viewtopic.php?f=8&t=3789" onclick="window.open(this.href);return false;
dragancesu
Re: HMG Case
I forgot to upload another manual, how to make an application, in this case, the household budget
Practical guidance how to use options of the application HMGCASE and create form, master / detail forum, reports and menu
howto.zip
(37.01 KiB) Downloaded 489 times
HOWTOmanual.zip
(1.05 MiB) Downloaded 461 times
Re: HMG Case
Gracias por la información! En la siguiente semana reviso y te doy mi opinión.
Saludos :)
dragancesu
Re: HMG Case
And now new version
hmgcase.zip
(1.66 MiB) Downloaded 471 times
Re: HMG Case
Hola,
Thank you for sharing
dragancesu
Re: HMG Case
And small demo
demo.zip
(59.73 KiB) Downloaded 431 times
Re: HMG Case
Nice job Dragan!
quartz565
Re: HMG Case
Post by quartz565 »
Thank you Dragan !
Nikos.
os: Windows Server 2019 - 64
