Notepad++ Function List
Re: Notepad++ Function List
+1mol wrote:I cant'get list of functions. What's going on? (I have newest version of NPP)
that my funcionlist.xml of Notepad++ 6.6.9 tranformed in functionlist.txt in file .rar
- functionlist.rar
- (2.51 KiB) Downloaded 650 times
L'Algerie vous salut
Y.TABET
Y.TABET
For anyone who still have this issue, please edit the file functionList.xml as below
if langID cannot be found above, you can still set the file extensions
<association ext=".my_passer_ext1" id="my_passer_id"/>
<association ext=".my_passer_ext2" id="my_passer_id"/>
for User Defined Languages:
<association userDefinedLangName="my user defined language" id="my_udl_passer_id"/>
<association userDefinedLangName="Autocad" id="my_autocad_passer_id"/>
==> Add this line
<association userDefinedLangName="xBase" ext=".prg" id="xBase"/>
</associationMap>
<parsers>
==> and Add following lines
<parser id="xBase" displayName="Harbour" commentExpr="">
<function
mainExpr="^[\t ]*(!Func|Function|Proc|Procedure)[\t ]+[^\r\n]*$"
displayMode="$functionName">
<functionName>
<nameExpr expr="(?(?=[\t ]*)[\t ]*[\t ]+[^\s]+|[^\r\n]*)"/>
</functionName>
</function>
</parser>
==> Add this line
</associationMap>
<parsers>
<function
<functionName>
</functionName>
</function>
</parser>
Hello bonsoit tout le monde
la fonction 'FUNCTIONLIST' n'est pas reconnu au niveau de NOTPAD++ 6.9.1.0
Function 'FUNCTIONLIST dos not work in the notpad++ ver 6.9.1.0
==> Add this line
</associationMap>
<parsers>
<function
<functionName>
</functionName>
</function>
</parser>Function 'FUNCTIONLIST dos not work in the notpad++ ver 6.9.1.0
- Sans titre.jpg (67.57 KiB) Viewed 7821 times
Y.TABET
Y.TABET
==> Please modify this line
to
<association userDefinedLangName="Harbour" ext=".prg" id="xBase"/>
I also attached a rar file for your referance.
to
- functionList.rar
- (8.36 KiB) Downloaded 422 times
Merci beaucoup mon ami, mais ca ne marche pas avec la nouvelle version mais fonctionne très bien avec les anciennes
ci joint la nouvelle
Thank you very much my friend, but it does not work with the new version but works fine with older
Attached is the new version.
I use Windows 10 64 bit
- npp.6.9.2.Installer.rar
- (3.85 MiB) Downloaded 442 times
Y.TABET
Y.TABET
I can't get it right. My function list is always empty. I tried with NotePad++ 6.9.2 Portable on Windows 10 Home.What am I doing wrong ?
Included my function list and language file. My language is "HMG".
Kind regards, Marc
Kind regards, Marc
- functionList.zip
- (2.91 KiB) Downloaded 422 times
- Language.zip
- (4.6 KiB) Downloaded 415 times
- IMG_1.png (11.4 KiB) Viewed 7741 times
Try to replace files in
%appdata%\Notepad++
and not in C:\Notepad++
ES
%appdata%\Notepad++
ES
If you can get this function work on old version such as the 6.8xx, you can download the new version 6.9.2 with "zip" file and then unpack to a temporary folder. You can then copy all the files except the "functionList.xml" and paste them back to the folder of NOTEPAD++. I am using the new version 6.9.2 and I use this way to upgrade the NOTEPAD++ every time.
