EditBox control: increase capacity
Re: EditBox control: increase capacity
Wow Carlos, nice idea.
but with the new functions of HMG the code is more simple.
   DEFINE WINDOW Form_1 ;
      WIDTH 640 HEIGHT 480 ;
      TITLE 'HMG Demo' ;
      ICON 'DEMO.ICO' ;
      MAIN
      @ 30,10 EDITBOX Edit_1 ;
         WIDTH 410 ;
         HEIGHT 140 ;
         VALUE 'EditBox!!';
         MAXLENGTH 0       // same as --> SendMessage (GetControlHandle("Edit_1","Form_1"), 197, 0, 0 )
      DEFINE BUTTON D
         ROW   250
         COL   290
         WIDTH   130
         CAPTION  '_GetCaretPos'
         ACTION   MsgInfo (Form1.Edit_1.CaretPos)  // ---> MsgInfo() --> convert xData to STR
      END BUTTON
   // CREATE EVENT PROCNAME OnkeyEdit_1() HWND GetControlHandle("Edit_1","Form_1")     // --> Work only with Form1.Edit_1
   CREATE EVENT PROCNAME OnkeyAllEditBox()                                             // --> Work with all EditBox controls
   Form_1.Center()
   Form_1.Activate()
Function OnkeyEdit_1()
   IF EventMSG() == WM_CHAR
      IF .NOT. (GetKeyState(VK_INSERT) == 0) .AND. HMG_GetLastVirtualKeyDown() != VK_RETURN .AND. HMG_GetLastVirtualKeyDown() != VK_BACK
         SendMessage (EventHWND(), WM_KEYDOWN, VK_DELETE, 0)
Return NIL
Function OnkeyAllEditBox()
LOCAL nIndex := GetControlIndexByHandle (EventHWND())
   IF nIndex > 0 .AND. GetControlTypeByIndex (nIndex) == "EDIT"
         IF .NOT. (GetKeyState (VK_INSERT) == 0) .AND. HMG_GetLastVirtualKeyDown() != VK_RETURN .AND. HMG_GetLastVirtualKeyDown() != VK_BACK
Return NIL
Uhmm looks promising solution... :) Thanks Carlos and Claudio !
Hi dear Claudio, in your example are missing these functions:
  • EVENTMSG
    HMG_GETLASTVIRTUALKEYDOWN
    EVENTHWND
    GETCONTROLINDEXBYHANDLE
    GETCONTROLTYPEBYINDEX
I assume that will be available in the next release, but could you please anticipate to all of us ?
I do not know what the rest of his colleagues opine, but IMHO this new option of OVERWRITE in EDIT controls by key pressed, could be incorporated into the function INITEDITBOX C:\hmg.3.1.4\SOURCE\c_editbox.c adding a new property (a new parameter) as an option for the programmer.
Something like this:
DEFINE EDITBOX Edit_1
        ROW 30
        COL 10
        WIDTH 500
        HEIGHT 140
        VALUE "EditBox!!"
        OVERWRITE .T.
END EDITBOX
And this routine of key control would be only activated if OVERWRITE is .T.
Pablo César wrote:Uhmm looks promising solution... :) Thanks Carlos and Claudio !
  • EVENTMSG
    EVENTHWND
Yes, these are functions of the new version.
Pablo César wrote:I do not know what the rest of his colleagues opine, but IMHO this new option of OVERWRITE in EDIT controls by key pressed, could be incorporated into the function INITEDITBOX C:\hmg.3.1.4\SOURCE\c_editbox.c adding a new property (a new parameter) as an option for the programmer.
Later I will try to develop a real routine overwriting.
Carlos Britos
Post by Carlos Britos »
         WIDTH 410 ;
         HEIGHT 140 ;
         VALUE 'EditBox!!';
Hello Claudio
I was looking at the example code and the option "MaxLenght = 0" would invalidate the use of that property for text.
Carlos Britos
Carlos Britos wrote: I was looking at the example code and the option "MaxLenght = 0" would invalidate the use of that property for text.
Forget it, I'm wrong. :oops:
Los penales no me dejaron pensar claro. :lol:
Carlos Britos wrote:Los penales no me dejaron pensar claro. :lol:
Los penales errados hoy contra Francia y en la Copa de las Confederaciones contra Italia no me dejan dormir.
Pero como dijo hoy un colombiano en la pagina web de la FIFA: "pa´lante uruguayos, vamos que el segundo es el mejor entre los perdedores" :lol: :lol: :lol:
Post by EduardoLuis »
Hi Friends:
Did you consider where you'll store EditBox contents ?
Take notice of this:
*.txt file: Max. 65535 char
memo Field: Max. 29958 (aprox.)
To solve storage problem using large Editbox contents, you must split text on portions which it size matches with storage output.-
EduardoLuis wrote: Take notice of this:
Hello Eduardo
As far as I know text limit is for Clipper and memo field limit is for DBFNTX.
In Window environment and by using Harbour and DBFCDX will be everything OK 8-) ( hopefully ;) )
There will be other limits, but I couldn't reached yet ;)
Hi Esguici:
I've tested limits with HMG DBFNTX.-
Now i'll test limits with HMG DBFCDX.-
Thanks for you suggestion.-
Eduardo.-
