Re: Harbour MiniGUI 2.7.0
Posted: Mon Mar 30, 2009 4:28 pm
It was a JOKE!!!esgici wrote:]
Sorry Roberto![]()
No problem at all !!!
Roberto.
Exclusive forum for HMG, a Free / Open Source xBase WIN32/64 Bits / GUI Development System
http://mail.hmgforum.com/
Sorry Roberto![]()
In that case sorry for don't understood the jokeRoberto Lopez wrote: It was a JOKE!!!
I am feeling at home in this forumThis was a little pleasantry between Sudip and me.
We had use this term only as opposite of program makers, that's all.
System.clipboard := cMemoI am experimenting more deeply on new features.Roberto Lopez wrote:- Harbour MiniGUI 2.7.0 Changelog:
- New: 'System' object. It will aloow to read (and write when possible) various operating system properties.
Hello Esgici,esgici wrote: Now we will demand adding more properties to it.
F.e. System.Infos => <aSystemInfos>
* MINIGUI - HARBOUR - Win32
ANNOUNCE RDDSYS
#include "minigui.ch"
#define PROGRAM "System Metrics"
#define VERSION " v.1.0"
#define COPYRIGHT " 2005 Grigory Filatov"
#define NTRIM( n ) LTrim( Str( n ) )
* GetSystemMetrics() codes
#define SM_CXSCREEN 0
#define SM_CYSCREEN 1
#define SM_CXVSCROLL 2
#define SM_CYHSCROLL 3
#define SM_CYCAPTION 4
#define SM_CXBORDER 5
#define SM_CYBORDER 6
#define SM_CXDLGFRAME 7
#define SM_CYDLGFRAME 8
#define SM_CYVTHUMB 9
#define SM_CXHTHUMB 10
#define SM_CXICON 11
#define SM_CYICON 12
#define SM_CXCURSOR 13
#define SM_CYCURSOR 14
#define SM_CYMENU 15
#define SM_CXFULLSCREEN 16
#define SM_CYFULLSCREEN 17
#define SM_CYKANJIWINDOW 18
#define SM_MOUSEPRESENT 19
#define SM_CYVSCROLL 20
#define SM_CXHSCROLL 21
#define SM_DEBUG 22
#define SM_SWAPBUTTON 23
#define SM_RESERVED1 24
#define SM_RESERVED2 25
#define SM_RESERVED3 26
#define SM_RESERVED4 27
#define SM_CXMIN 28
#define SM_CYMIN 29
#define SM_CXSIZE 30
#define SM_CYSIZE 31
#define SM_CXFRAME 32
#define SM_CYFRAME 33
#define SM_CXMINTRACK 34
#define SM_CYMINTRACK 35
#define SM_CXDOUBLECLK 36
#define SM_CYDOUBLECLK 37
#define SM_CXICONSPACING 38
#define SM_CYICONSPACING 39
#define SM_MENUDROPALIGNMENT 40
#define SM_PENWINDOWS 41
#define SM_DBCSENABLED 42
#define SM_CMOUSEBUTTONS 43
#define SM_CXFIXEDFRAME SM_CXDLGFRAME /* ;win40 name change */
#define SM_CYFIXEDFRAME SM_CYDLGFRAME /* ;win40 name change */
#define SM_CXSIZEFRAME SM_CXFRAME /* ;win40 name change */
#define SM_CYSIZEFRAME SM_CYFRAME /* ;win40 name change */
#define SM_SECURE 44
#define SM_CXEDGE 45
#define SM_CYEDGE 46
#define SM_CXMINSPACING 47
#define SM_CYMINSPACING 48
#define SM_CXSMICON 49
#define SM_CYSMICON 50
#define SM_CYSMCAPTION 51
#define SM_CXSMSIZE 52
#define SM_CYSMSIZE 53
#define SM_CXMENUSIZE 54
#define SM_CYMENUSIZE 55
#define SM_ARRANGE 56
#define SM_CXMINIMIZED 57
#define SM_CYMINIMIZED 58
#define SM_CXMAXTRACK 59
#define SM_CYMAXTRACK 60
#define SM_CXMAXIMIZED 61
#define SM_CYMAXIMIZED 62
#define SM_NETWORK 63
#define SM_CLEANBOOT 67
#define SM_CXDRAG 68
#define SM_CYDRAG 69
#define SM_SHOWSOUNDS 70
#define SM_CXMENUCHECK 71
#define SM_CYMENUCHECK 72
#define SM_SLOWMACHINE 73
#define SM_MIDEASTENABLED 74
#define SM_MOUSEWHEELPRESENT 75
#define SM_XVIRTUALSCREEN 76
#define SM_YVIRTUALSCREEN 77
#define SM_CXVIRTUALSCREEN 78
#define SM_CYVIRTUALSCREEN 79
#define SM_CMONITORS 80
#define SM_SAMEDISPLAYFORMAT 81
Function Main()
LOCAL i, m, aItems := {}, sm := ;
{SM_ARRANGE, "SM_ARRANGE", "Flags specifying how the system arranged minimized windows. For more information about minimized windows, see the following Remarks section."},;
{SM_CLEANBOOT, "SM_CLEANBOOT", "Value that specifies how the system was started: 0 Normal boot; 1 - Fail-safe boot; 2 - Fail-safe with network boot. Fail-safe boot (also called SafeBoot) bypasses the user's startup files."},;
{SM_CMONITORS, "SM_CMONITORS", "Windows 2000 and later; Windows 98: Number of display monitors on the desktop."},;
{SM_CMOUSEBUTTONS, "SM_CMOUSEBUTTONS", "Number of buttons on mouse, or zero if no mouse is installed."},;
{SM_CXBORDER, "SM_CXBORDER", ""},;
{SM_CYBORDER, "SM_CYBORDER", "Width and height, in pixels, of a window border. This is equivalent to the SM_CXEDGE value for windows with the 3-D look."},;
{SM_CXCURSOR, "SM_CXCURSOR", ""},;
{SM_CYCURSOR, "SM_CYCURSOR", "Width and height, in pixels, of a cursor. The system cannot create cursors of other sizes. "},;
{SM_CXDLGFRAME, "SM_CXDLGFRAME", ""},;
{SM_CYDLGFRAME, "SM_CYDLGFRAME", "Same as SM_CXFIXEDFRAME and SM_CYFIXEDFRAME. "},;
{SM_CXDOUBLECLK, "SM_CXDOUBLECLK", " "},;
{SM_CYDOUBLECLK, "SM_CYDOUBLECLK", "Width and height, in pixels, of the rectangle around the location of a first click in a double-click sequence. The second click must occur within this rectangle for the system to consider the two clicks a double-click. (The two clicks must also occur within a specified time.) To set the width and height of the double-click rectangle, call SystemParametersInfo with the SPI_SETDOUBLECLKHEIGHT and SPI_SETDOUBLECLKWIDTH flags."},;
{SM_CXDRAG, "SM_CXDRAG", ""},;
{SM_CYDRAG, "SM_CYDRAG", "Width and height, in pixels, of a rectangle centered on a drag point to allow for limited movement of the mouse pointer before a drag operation begins. This allows the user to click and release the mouse button easily without unintentionally starting a drag operation. "},;
{SM_CXEDGE, "SM_CXEDGE", ""},;
{SM_CYEDGE, "SM_CYEDGE", "Dimensions, in pixels, of a 3-D border. These are the 3-D counterparts of SM_CXBORDER and SM_CYBORDER. "},;
{SM_CXFIXEDFRAME, "SM_CXFIXEDFRAME", ""},;
{SM_CYFIXEDFRAME, "SM_CYFIXEDFRAME", "Thickness, in pixels, of the frame around the perimeter of a window that has a caption but is not sizable. SM_CXFIXEDFRAME is the width of the horizontal border and SM_CYFIXEDFRAME is the height of the vertical border. Same as SM_CXDLGFRAME and SM_CYDLGFRAME."},;
{SM_CXFRAME, "SM_CXFRAME", ""},;
{SM_CYFRAME, "SM_CYFRAME", "Same as SM_CXSIZEFRAME and SM_CYSIZEFRAME. "},;
{SM_CXFULLSCREEN, "SM_CXFULLSCREEN", ""},;
{SM_CYFULLSCREEN, "SM_CYFULLSCREEN", "Width and height of the client area for a full-screen window on the primary display monitor. To get the coordinates of the portion of the screen not obscured by the system taskbar or by application desktop toolbars, call the SystemParametersInfo function with the SPI_GETWORKAREA value. "},;
{SM_CXHSCROLL, "SM_CXHSCROLL", ""},;
{SM_CYHSCROLL, "SM_CYHSCROLL", "Width, in pixels, of the arrow bitmap on a horizontal scroll bar; and height, in pixels, of a horizontal scroll bar. "},;
{SM_CXHTHUMB, "SM_CXHTHUMB", "Width, in pixels, of the thumb box in a horizontal scroll bar. "},;
{SM_CXICON, "SM_CXICON", " "},;
{SM_CYICON, "SM_CYICON", "The default width and height, in pixels, of an icon. The LoadIcon function can load only icons of these dimensions. "},;
{SM_CXICONSPACING, "SM_CXICONSPACING", ""},;
{SM_CYICONSPACING, "SM_CYICONSPACING", "Dimensions, in pixels, of a grid cell for items in large icon view. Each item fits into a rectangle of this size when arranged. These values are always greater than or equal to SM_CXICON and SM_CYICON. "},;
{SM_CXMAXIMIZED, "SM_CXMAXIMIZED", ""},;
{SM_CYMAXIMIZED, "SM_CYMAXIMIZED", "Default dimensions, in pixels, of a maximized top-level window on the primary display monitor. "},;
{SM_CXMAXTRACK, "SM_CXMAXTRACK", ""},;
{SM_CYMAXTRACK, "SM_CYMAXTRACK", "Default maximum dimensions, in pixels, of a window that has a caption and sizing borders. This metric refers to the entire desktop. The user cannot drag the window frame to a size larger than these dimensions. A window can override these values by processing the WM_GETMINMAXINFO message. "},;
{SM_CXMENUCHECK, "SM_CXMENUCHECK", ""},;
{SM_CYMENUCHECK, "SM_CYMENUCHECK", "Dimensions, in pixels, of the default menu check-mark bitmap. "},;
{SM_CXMENUSIZE, "SM_CXMENUSIZE", ""},;
{SM_CYMENUSIZE, "SM_CYMENUSIZE", "Dimensions, in pixels, of menu bar buttons, such as the child window close button used in the multiple document interface. "},;
{SM_CXMIN, "SM_CXMIN", ""},;
{SM_CYMIN, "SM_CYMIN", "Minimum width and height, in pixels, of a window. "},;
{SM_CXMINIMIZED, "SM_CXMINIMIZED", ""},;
{SM_CYMINIMIZED, "SM_CYMINIMIZED", "Dimensions, in pixels, of a normal minimized window. "},;
{SM_CXMINSPACING, "SM_CXMINSPACING", ""},;
{SM_CYMINSPACING, "SM_CYMINSPACING", "Dimensions, in pixels, of a grid cell for minimized windows. Each minimized window fits into a rectangle this size when arranged. These values are always greater than or equal to SM_CXMINIMIZED and SM_CYMINIMIZED. "},;
{SM_CXMINTRACK, "SM_CXMINTRACK", ""},;
{SM_CYMINTRACK, "SM_CYMINTRACK", "Minimum tracking width and height, in pixels, of a window. The user cannot drag the window frame to a size smaller than these dimensions. A window can override these values by processing the WM_GETMINMAXINFO message. "},;
{SM_CXSCREEN, "SM_CXSCREEN", " "},;
{SM_CYSCREEN, "SM_CYSCREEN", "Width and height, in pixels, of the screen of the primary display monitor. These are the same values you obtain by calling GetDeviceCaps(hdcPrimaryMonitor, HORZRES/VERTRES). "},;
{SM_CXSIZE, "SM_CXSIZE", ""},;
{SM_CYSIZE, "SM_CYSIZE", "Width and height, in pixels, of a button in a window's caption or title bar. "},;
{SM_CXSIZEFRAME, "SM_CXSIZEFRAME", ""},;
{SM_CYSIZEFRAME, "SM_CYSIZEFRAME", "Thickness, in pixels, of the sizing border around the perimeter of a window that can be resized. SM_CXSIZEFRAME is the width of the horizontal border, and SM_CYSIZEFRAME is the height of the vertical border. Same as SM_CXFRAME and SM_CYFRAME."},;
{SM_CXSMICON, "SM_CXSMICON", ""},;
{SM_CYSMICON, "SM_CYSMICON", "Recommended dimensions, in pixels, of a small icon. Small icons typically appear in window captions and in small icon view. "},;
{SM_CXSMSIZE, "SM_CXSMSIZE", ""},;
{SM_CYSMSIZE, "SM_CYSMSIZE", "Dimensions, in pixels, of small caption buttons. "},;
{SM_CXVIRTUALSCREEN,"SM_CXVIRTUALSCREEN", ""},;
{SM_CYVIRTUALSCREEN,"SM_CYVIRTUALSCREEN", "Windows 2000 and later; Windows 98: Width and height, in pixels, of the virtual screen. The virtual screen is the bounding rectangle of all display monitors. The SM_XVIRTUALSCREEN, SM_YVIRTUALSCREEN metrics are the coordinates of the top-left corner of the virtual screen. "},;
{SM_CXVSCROLL, "SM_CXVSCROLL", ""},;
{SM_CYVSCROLL, "SM_CYVSCROLL", "Width, in pixels, of a vertical scroll bar; and height, in pixels, of the arrow bitmap on a vertical scroll bar. "},;
{SM_CYCAPTION, "SM_CYCAPTION", "Height, in pixels, of a normal caption area. "},;
{SM_CYKANJIWINDOW, "SM_CYKANJIWINDOW", "For double byte character set versions of the system, this is the height, in pixels, of the Kanji window at the bottom of the screen. "},;
{SM_CYMENU, "SM_CYMENU", "Height, in pixels, of a single-line menu bar. "},;
{SM_CYSMCAPTION, "SM_CYSMCAPTION", "Height, in pixels, of a small caption. "},;
{SM_CYVTHUMB, "SM_CYVTHUMB", "Height, in pixels, of the thumb box in a vertical scroll bar. "},;
{SM_DBCSENABLED, "SM_DBCSENABLED", "TRUE or nonzero if the double-byte character-set (DBCS) version of User.exe is installed; FALSE or zero otherwise. "},;
{SM_DEBUG, "SM_DEBUG", "TRUE or nonzero if the debugging version of User.exe is installed; FALSE or zero otherwise. "},;
;// {SM_IMMENABLED, "SM_IMMENABLED", "Windows 2000: TRUE or nonzero if Input Method Manager/Input Method Editor features are enabled; FALSE or zero otherwise. Can determine if the system handles Unicode IME. However, if the IME is language dependent you should also check that the target language has been installed. Otherwise some components, like fonts or registry settings, may not be present. "},;
{SM_MENUDROPALIGNMENT,"SM_MENUDROPALIGNMENT", "TRUE or nonzero if drop-down menus are right-aligned with the corresponding menu-bar item; FALSE or zero if the menus are left-aligned. "},;
{SM_MIDEASTENABLED, "SM_MIDEASTENABLED", "TRUE if the system is enabled for Hebrew and Arabic languages. "},;
{SM_MOUSEPRESENT, "SM_MOUSEPRESENT", "TRUE or nonzero if a mouse is installed; FALSE or zero otherwise. "},;
{SM_MOUSEWHEELPRESENT,"SM_MOUSEWHEELPRESENT", "Windows NT 4.0 and later, Windows 98: TRUE or nonzero if a mouse with a wheel is installed; FALSE or zero otherwise. "},;
{SM_NETWORK, "SM_NETWORK", "The least significant bit is set if a network is present; otherwise, it is cleared. The other bits are reserved for future use. "},;
{SM_PENWINDOWS, "SM_PENWINDOWS", "TRUE or nonzero if the Microsoft Windows for Pen computing extensions are installed; FALSE or zero otherwise. "},;
;// {SM_REMOTESESSION, "SM_REMOTESESSION", "Terminal Server Edition 4.0 SP4 or Windows 2000 or later: This system metric is used in a Terminal Services environment. If the calling process is associated with a Terminal Services client session, the return value is TRUE or nonzero. If the calling process is associated with the Terminal Server console session, the return value is zero. "},;
{SM_SECURE, "SM_SECURE", "TRUE if security is present; FALSE otherwise. "},;
{SM_SAMEDISPLAYFORMAT,"SM_SAMEDISPLAYFORMAT", "Windows 2000 and later; Windows 98: TRUE if all the display monitors have the same color format, FALSE otherwise. Note that two displays can have the same bit depth, but different color formats. For example, the red, green, and blue pixels can be encoded with different numbers of bits, or those bits can be located in different places in a pixel's color value. "},;
{SM_SHOWSOUNDS, "SM_SHOWSOUNDS", "TRUE or nonzero if the user requires an application to present information visually in situations where it would otherwise present the information only in audible form; FALSE, or zero, otherwise. "},;
{SM_SLOWMACHINE, "SM_SLOWMACHINE", "TRUE if the computer has a low-end (slow) processor; FALSE otherwise. "},;
{SM_SWAPBUTTON, "SM_SWAPBUTTON", "TRUE or nonzero if the meanings of the left and right mouse buttons are swapped; FALSE or zero otherwise. "},;
{SM_XVIRTUALSCREEN, "SM_XVIRTUALSCREEN", ""},;
{SM_YVIRTUALSCREEN, "SM_YVIRTUALSCREEN", "Windows 2000 and later; Windows 98: Coordinates for the left side and the top of the virtual screen. The virtual screen is the bounding rectangle of all display monitors. The SM_CXVIRTUALSCREEN, SM_CYVIRTUALSCREEN metrics are the width and height of the virtual screen. "};
FOR i := 1 TO Len( sm )
m := GetSystemMetrics ( sm [i] [1] )
Aadd( aItems, { sm [i] [2], NTRIM( m ), sm [i] [3] } )
WIDTH 606 ;
HEIGHT 275 ;
TITLE PROGRAM ;
MAIN ;
NOMAXIMIZE NOSIZE ;
ON MOUSECLICK MsgAbout() ;
FONT 'MS Sans Serif' ;
SIZE 9
m := Form_1.Width - 2 * GetBorderWidth() - 10
@ 6,6 GRID Grid_1 ;
WIDTH m ;
HEIGHT Form_1.Height - GetTitleHeight() - 2 * GetBorderHeight() - 10 ;
HEADERS { 'Name', 'Value', 'Description' } ;
WIDTHS { 162, 42, m - GetSystemMetrics ( SM_CXVSCROLL ) - 208 } ;
ITEMS aItems ;
NOLINES ;
ON DBLCLICK ( System.Clipboard := GetColValue( "Grid_1", "Form_1", 1 ), ;
MsgInfo( "The name have been copied to clipboard", PROGRAM ) ) ;
JUSTIFY { BROWSE_JTFY_LEFT,BROWSE_JTFY_RIGHT, BROWSE_JTFY_LEFT }
ON KEY ESCAPE ACTION ReleaseAllWindows()
CENTER WINDOW Form_1
Function GetColValue( xObj, xForm, nCol )
Local nPos:= GetProperty(xForm, xObj, 'Value')
Local aRet:= GetProperty(xForm, xObj, 'Item', nPos)
Return aRet[nCol]
Function MsgAbout()
return MsgInfo( PROGRAM + VERSION + CRLF + ;
"Copyright " + Chr(169) + COPYRIGHT + CRLF + CRLF + ;
"eMail: gfilatov@freemail.ru" + CRLF + CRLF + ;
"This program is Freeware!" + CRLF + ;
padc("Copying is allowed!", 30), "About..." )
#pragma BEGINDUMP
#define HB_OS_WIN_32_USED
#define _WIN32_WINNT 0x0400
#include <windows.h>
#include "hbapi.h"
#include "hbapiitm.h"
HB_FUNC ( GETSYSTEMMETRICS )
hb_retni( GetSystemMetrics( hb_parni( 1 ) ) );
#pragma ENDDUMPThanks Grigorygfilatov wrote: No problem![]()
There is LOTS of things that can be added. I'm testing new ones right now!esgici wrote: I am experimenting more deeply on new features.
Addition this 'System' object isn't a good thing![]()
Best Regards.
