HMG 3.1.2
Re: HMG 3.1.2 (Test)
mol wrote:I've found some problems with hmg 3.1.2 and context and main menu:
When you open one modal window from another, error occures:
Main Menu already defined in Window: OknoHistoriaKontrahenta. Program Terminated
Called from _DEFINEMAINMENU(61)
or
Error BASE/1070 Illegal argument: ==
Called from OBSLBLEDU(952)
Called from (b)MAIN(447)
Called from ISCONTEXTMENUDEFINED(638)
Called from _DEFINECONTEXTMENU(496)
Called from SZYBKATABELATOWAROW(33)
Besides - context menu is not defined in line 33:
but, in FMG file loaded by function SZYBKATABELATOWAROW()
(piece of FMG file below)
    DEFINE CONTEXT MENU
        MENUITEM "Popraw Towar" ACTION PoprawDodajTowar(.f.) NAME PoprawDodajTowar
        MENUITEM "Drukuj etykietę na regał" ACTION ZaznaczTowarDoDrukuEtykiety(0,towary->towar, cEtykietaNaRegal,1) NAME ZaznaczTowarDoDrukuEtykiety
        MENUITEM "Drukuj etykietę na towar" ACTION ZaznaczTowarDoDrukuEtykiety(1,towary->towar, cEtykietaNaTowar,-1,towary->Ilosc) NAME cEtykietaNaRegal
    END MENU
All this code works perfect with hmg 3.0.46
Please Marek, post a small example.
I've tried to reproduce these errors on small sample, but without success :-)
My application works good on hmg 3.0.46, but all errors appear when compiled with hmg3.1.2.
It's strange...
mol wrote:I've tried to reproduce these errors on small sample, but without success :-)
It's strange...
Hi Marek.
I also tried to play the bug in HMG.3.1.2, but I failed.
Maybe this is not a bug, in this version I added the function ISxxxMENUDEFINED() in the definition of the menus to prevent multiple definitions of the same menu.
The following code compiles fine in HMG.3.0.46 (and HMG.3.1.1) but not in HMG.3.1.2
Function main()
   DEFINE WINDOW Form_1 ;
      WIDTH 400 ;
      HEIGHT 200 ;
      TITLE 'Multiple definitions of the same menu' ;
      MAIN
      DEFINE MAIN MENU
         POPUP 'Test'
            ITEM 'Item 1'  ACTION MsgInfo ('Item 1')
            ITEM 'Item 2'  ACTION MsgInfo ('Item 2')
         END POPUP
      END MENU
      DEFINE CONTEXT MENU
      END MENU
      DEFINE MAIN MENU
         POPUP 'Test'
         END POPUP
      END MENU
      DEFINE CONTEXT MENU
      END MENU
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
Claudio.
This error occurs when I tried call one modal window from another modal window. When it was callad from main window, everything worked OK.
I do not define windows manually - they are loaded from fmg files.
Maybe here is the problem. I'll try tomorrow morning to test this path.
I've prepared simple sample. Try to compile it.
First, press button "Load Modal Window #1" on Main Form, then try to load or define Window #2.
Error occurs.
When you press "Load Modal Window #2" on Main Form - everything works OK.
When you remove ONCHANGE phrase from Browse control, everything works OK.
This problem is caused by evaluating code blocks while loading or defining windows, I think.
Regards, Marek
hmg312_error.zip
(39.07 KiB) Downloaded 368 times
mol wrote:I've prepared simple sample. Try to compile it.
Error occurs.
Regards, Marek
Thanks Marek, I will investigate the problem.
Dear Rathinagiri,
I am still without your return my questions of these:
Pablo César wrote:Dear Rathinagiri, thank you for this new release but basically in this version are applied modifications of UNICODE adjustments but regarding Build.bat in samples, Build.bat at HMG main folder, ComboSearchBox, AutoAdjust sample/library and QHTM library have It been included or not yet ?
Please also note to update in next release, version.txt file was not updated. In this last one version.txt should contains "3.1.2 (Test 2013-04-04)".
dhaine_adp
Post by dhaine_adp »
I rebuild HMG Lib 3.1.2 with ANSI only by putting a comment to SET_COMPILE_HMG_UNICODE.ch and execute buildalllib.bat
1. I created another folder and named it as c:\hmg-ansi
2. I copied the contents of HMG 3.1.2 folder and put them to c:\hmg-ansi
3. I edit hmg.ini and put c:\hmg-ansi
4. Put comment marker on //#define COMPILE_HMG_UNICODE
5. At the command prompt inside the c:\hmg-ansi I typed: buildalllib > result.txt
6. I modified my projects .hbc and point everything to c:\hmg-ansi
When I compile the application I've got errors as shown below:
Did I miss something? It seems like during the rebuilding process the compiler didn't pick-up the missing reference (undefined reference) from #else block of #ifdef...#else...#endif of <hmgdir>\source\unicode_string.prg
Please test if you can duplicate the problem on Windows XP Pro SP2.
Also the redirected result.zip (result.txt) file attached (from command line) generated looks like a unicode text file format. Looks funny on ASCII editor and in notepad++ reached about 8000+ lines.
hbmk2: Warning: Non-portable output filename: '-oppcmembers-ansi.exe'. Delete
'.exe' extension.
Harbour 3.2.0dev (r1303181903)
Copyright (c) 1999-2013, http://harbour-project.org/
C:/hmg-ansi/lib/libhmg.a(h_controlmisc.o):h_controlmisc.c:(.data+0x28): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_controlmisc.o):h_controlmisc.c:(.data+0x208): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_windows.o):h_windows.c:(.data+0x38): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_windows.o):h_windows.c:(.data+0x10e8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_status.o):h_status.c:(.data+0x48): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_status.o):h_status.c:(.data+0x58): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_toolbar.o):h_toolbar.c:(.data+0x128): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_menu.o):h_menu.c:(.data+0x2c8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_dialogs.o):h_dialogs.c:(.data+0xb8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_hotkey.o):h_hotkey.c:(.data+0x68): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_label.o):h_label.c:(.data+0x108): undefined reference to `HB_FUN_HMG_LOWER'
C:/hmg-ansi/lib/libhmg.a(h_button.o):h_button.c:(.data+0x158): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_textbox.o):h_textbox.c:(.data+0x148): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_textbox.o):h_textbox.c:(.data+0x228): undefined reference to `HB_FUN_HMG_LOWER'
C:/hmg-ansi/lib/libhmg.a(h_textbox.o):h_textbox.c:(.data+0x2b8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_combo.o):h_combo.c:(.data+0x78): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_checkbox.o):h_checkbox.c:(.data+0x148): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_browse.o):h_browse.c:(.data+0xa8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_browse.o):h_browse.c:(.data+0x948): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_tab.o):h_tab.c:(.data+0x58): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_tab.o):h_tab.c:(.data+0x128): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_radio.o):h_radio.c:(.data+0xe8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_tree.o):h_tree.c:(.data+0xd8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_grid.o):h_grid.c:(.data+0x68): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_grid.o):h_grid.c:(.data+0xb8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_font.o):h_font.c:(.data+0xb8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_timer.o):h_timer.c:(.data+0xa8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libgraph.a(h_graph.o):h_graph.c:(.data+0x118): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libini.a(h_ini.o):h_ini.c:(.data+0x1f8): undefined reference to `HB_FUN_HMG_LEN'
gcc.exe C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/ppcmembers.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/archive.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/auditdashboard.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/chkinifile.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/classprogressbar.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/codegen.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/datacollection.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/dbfmaketable.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/dialogue.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/exp2excel.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/filemain.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/genclassbrwobj.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/gregcivil.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/makefile.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/nsdlacommfunc.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/ppcmaster.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/recordpicker.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/reports.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/rptpersonalinfo.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/theviewport.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/treeclassview.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/usermgr.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/hbmk_xrfeqb.o F:/DAD/members/_temp.o -Wl,--nxcompat -Wl,--dynamicbase -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lhfcl -lini -lreport -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lvalleylibs -ldaleaidcommon -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -o"ppcmembers-ansi.exe" -L"C:/hmg-ansi/harbour/lib/win/mingw" -L"C:/hmg-ansi/lib" -L"c:/hmg-ansi/lib"
hbmk2: Error: Referenced, missing, but unknown function(s): HMG_UPPER(),
HMG_LEN(), HMG_LOWER()
TIA,
Danny
result.zip
(2 KiB) Downloaded 372 times
Danny
Manila, Philippines
Carlos Britos
Post by Carlos Britos »
dhaine_adp wrote:Hi,
Hi.
Maybe is missing in hmg.hbp the file
source/UNICODE_STRING.prg
I don't have3.12 but in 3.11 is missing
Error occurs.
Regards, Marek
Hi Marek.
I fixed the problem.
Please replace c:\hmg.3.1.2\source\h_menu.prg for the h_menu.prg attachment file, and rebuild the HMG.
Claudio.
h_menu.rar
(3.62 KiB) Downloaded 418 times
