DBF To Excel
Re: DBF To Excel
it really works, when I use
oSheet:Cells:Font:Size := 12
oSheet:Cells:Font:Bold := .t.
but if I add coordinates to CELLS:
oSheet:Cells( 1, 1 ):Font:Size := 12
oSheet:Cells( 1, 1 ):Font:Bold := .t.
It doesn't work!
The difference is, that 1st example makes whole sheet bolded and blue, but I wanna bold only one cell...
Marek
Re: DBF To Excel
Sorry, for my quick post... Now it works! I don't know what I've changed...
Time for pause and coffee
Re: DBF To Excel
One problem left...
How to use SaveAs function.
Do you have any working wxample?
Re: DBF To Excel
I still use the same export to excel routine, which copy data to clipboard first (many thanks for Alex Gustow idea - it really speed up exporting process), but now, I reach error:
Error 2606804/3 DISP_E_MEMBERNOTFOUND: PASTE</p><BR>
Called from TOLEAUTO:PASTE(0)
Do you know what does it mean?
From where it is - I didn't change anything...
I'm angry when I must use something from M$...
Re: DBF To Excel
mol wrote:...
Hi Marek
You aren't alone !
Re: DBF To Excel
I think, that may be problem with linker - one change in program in different place causes this error. It's very strange...
fchirico
Re: DBF To Excel
Post by fchirico »
sudip wrote:Hi,
I was looking for an application which can transfer data from grid to excel. MOL showed me an example (very well written) directly copied from his application. Thank you MOL. :)
I already used excel in my xHarbour apps. I modified slightly to make it HMG compatible. I got CopyToClipboard() function from this forum. Finally I made this application to share with you. :)
There is a file "excel.ch". Yes, I uploaded it for you in ShowExcel.zip. :)
Español:
Sudip, muchas gracias por tu trabajo!
Solo un pequeño comentario:
a la línea "cMemo += ExcelDt(mTemp)"
yo la reemplacé por "cMemo += dtoc(mTemp)"
ya que de esta forma exporta corretamente las fechas. Por ejemplo cuando están vacías u otros casos. Previamente to hice el seteo de la fecha:
SET DATE TO.... o como lo desee cada uno.
Saludos y muchas gracias.
Inglés power by Google.
Sudip, thank you very much for your work!
Just a small comment:
the line "cMemo + = ExcelDt (mTemp)
I replaced it with "cMemo + = dtoc (mTemp)
since this correctly exported date. For example, when they are empty or otherwise. Before I did the settings to the date:
SET DATE TO .... or as you like each.
Greetings and thank you very much.
Fernando Chirico.
Saludos, Fernando Chirico.
Re: DBF To Excel
Hi Fernando,
Thank you very much for your input. :)
It is first time I meet you :)
Previously I used dtoc(). But dtoc() depends on _SET_DATEFORMAT. If it is British (dd/mm/yy) (as it is generally used in India), then Excel has problem for dates like 25th Dec 2008. Because dtoc() will return "25/12/08" and some times it shows error and some times it think it is a Character or Numeric field!!! :) So I created ExcelDt() function to use in every country.
Please advise me like this :)
fchirico
Re: DBF To Excel
Post by fchirico »
sudip wrote:Hi Fernando,
Sudip Thanks!
Are points of view. If you define a year with 4 digits 25/12/2008 exported to date field correctly. It also exports the correct blank fields.
The theme of the SET DATE can be solved in many ways.
Nice to meet you, and a pleasure to have you on the forum.
Regards, Fernando Chirico.
Re: DBF To Excel
Finally,
I have found solution to the problem of SAVEAS function...
simply, it must look:
oSheet:SaveAs(cNameOfTheFile)
Whole time I was trying this:
oExcel:SaveAs(cNameOfTheFile)
So simply mistake and so hard to find this...
Best regards, Marek
PS.
It still generates error:
Error 2608724/3 DISP_E_MEMBERNOTFOUND: SAVEAS
Called from TOLEAUTO:SAVEAS(0)
Called from ZAPISZRAPORTXLS(3142)
Only first compilation run well, next generates error... :x
