Print Preview in HMG, CatchysoftActiveX,PrintPreview Activex
- karweru
- DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Re: Print Preview in HMG, CatchysoftActiveX,PrintPreview Act
Thank you so much Rathi...this will be very usefull.
Kind regards,
Gilbert.
Gilbert.
- mustafa
Hola amigos
Haber si les puede servir este ejemplo que utiliza la libreria TPRINT
la libreria está en: http://www.embalajesterra.com/misdoc/pr ... ramas.html
Google Translate
Hello friends
Have if they can serve this example that uses the library TPRINT
The bookstore is in:
Google Translate
Hello friends
- Factura.zip
- (818.92 KiB) Downloaded 574 times
Hola Mustafa, my brother; welcome back !
What happiness hearing you
I hope that you are fine
and I wish more see you
I'll examine your participation, thanks.
Saludos cordiales
Saludos cordiales
Hi All
This program is bigger than seen
Mustafa, thanks again to share
A bit modified by courtesy of author:
Doneesgici wrote: ...I'll examine your participation...
Thank you form example etc. to esgici and mustafa
Thank Mustafa by example Factura.zip helped me in my system
mustafa wrote:Hola amigos
Google Translate
Hello friends
Thank Esgici by example GenFactura.zip helped me in my system
esgici wrote:Hi All
