Page 3 of 3
Re: About HMG docs
Posted: Mon May 16, 2011 5:13 pm
by Carlos Britos
Hi I'm asking in Firefox forum.
BTW I'll commit some changes in htm headers, please if your are so kind to rebuild doc and test it, while I'm waiting for some explanation from Firefox.
Re: About HMG docs
Posted: Sat May 21, 2011 4:41 pm
by Carlos Britos
Hi
Below is the version 20110521 of hmgdoc.exe.
Fixed the problem with FireFox 4.01.
Current version was tested on browsers:
IE 7.x and higher
FireFox 3.5.x / 4.01
Opera 10.x / 11.x
QT Browser (sample)
If someone else can test it in another browser, please let me know.
Sorry for the inconvenient and delay to fixit.
Re: About HMG docs
Posted: Sun May 22, 2011 2:36 am
Thanks a lot Carlos Britos! Nice fix.
Re: About HMG docs
Posted: Sun Jun 19, 2011 3:21 am
by gvaronas
gvaronas wrote:Hola Carlos, despues de generar la ayuda, en firefox no se visualiza bien, pero con el IE funciona bien.
Salu2,
GVS
Hola Carlos, Muchas gracias por mantener actualizada la documentación.
Resulta que ahora se me actualizó el FireFox a 5.0 y se ha vuelto a presentar el mismo problema.
Nuevamente, muchas gracias por tu trabajo.
Hi Carlos, Thanks for keeping the documentation.
It turns out that now I upgraded to 5.0 and FireFox has resubmitted the same problem.
Again, thank you very much for your work.
BestRegards
GVS
Re: About HMG docs
Posted: Sun Jun 19, 2011 12:54 pm
by Carlos Britos
BestRegards
GVS
I'll check it as soon as possible. Thanks for report.
Re: About HMG docs
Posted: Sun Jun 19, 2011 2:37 pm
by Carlos Britos
BestRegards
GVS
I've installed Firefox 5.0b7 and hmgdoc works as expected, maybe you are using the old version please check it from command line . hmgdoc -version
Should be 20110521
Re: About HMG docs
Posted: Sun Jun 19, 2011 4:07 pm
by Carlos Britos
Hi rathinagiri
For the next release of hmg4 binary package. Can you do this ?:
- Del subdir Data: C:\hmg.4\svn\doc\data
- Add hmgdoc.exe to: C:\hmg.4\harbour\bin
- Add images docs to those that are already in: C:\hmg.4\svn\doc\res
Get it from:
viewtopic.php?p=16370#p16370
In this way the user can get fresh htm help docs.
and ( but not related to hmg docs )
- Add Images QT dll files. C:\hmg.4\qt\plugins\imageformats
- Del subdir hmg: C:\hmg.4\svn\hmg
IMHO two folders with different sources and samples could be a problem.
Re: About HMG docs
Posted: Sun Jun 19, 2011 5:04 pm
Ok. Noted.
Re: About HMG docs
Posted: Sat Jun 25, 2011 5:54 pm
by Carlos Britos
HI
Below is the version 20110627 of hmgdoc.exe.
Fixed to build a better FAQ section and other minor stuff.
