HMG4: image icon resource file
Re: HMG4: image icon resource file
Yes please. Go ahead. :)
l3whmg
Post by l3whmg »
Ok, I've done. Could you please check if it's all ok?
I'm thinking about to write and add another simple demo to show how it's possible to have one or many resource file.
About documentation? How can we inform Esgici?
About Icon on Window title bar and statusbar, I've ready the update. Can I upload my solution or is there another ?
Cheers
Luigi from Italy
www.L3W.it
l3whmg wrote:...
Hi Luigi
Esgici is under-information ;)
But problem is that too many informations :shock:
If every developer could document adequately their own work, later it will be possible ( I hope ) combining parts :roll:
Carlos Britos
Post by Carlos Britos »
esgici wrote:
l3whmg wrote:...
Hi Esgici
And the format of the documents is ...?
Do you have any template to follow ?
l3whmg
Post by l3whmg »
Hi Esgici,
I am very :D to write to you again!
As I have a pretty short memory ;) I'm writing some notes, but they are in Italian. As soon as possible, I will translate and send you.
Cheers
Luigi from Italy
www.L3W.it
Nice modification Luigi. It made the code bug free.
New samples are fine. Thanks for them too.
Carlos Britos wrote:...
Hola Carlos
My duty isn't a full documentation; only "document in a simple way (a text file) which of documented HMG properties events and methods are available for each control we are working on (HMG-4)".
( Details are here. )
And sadly, I haven't any progress :(
So, if you have any idea for working on documentation of HMG4, please don't wait :arrow:
By the way, this document may be useful
l3whmg wrote:... I'm writing some notes, ... As soon as possible, I will translate and send you.
Hi Luigi
Please don't send me anything.
Plase simply embed your notes on your code (preferably on top of your source code file).
This will be sufficient for me and other friends.
Carlos Britos
esgici wrote: Hola Carlos
Hi
Just an idea to be discussed for all.
Build a template similar than harbour ( /harbour/doc/hdr_tpl.txt ) but with our owns hmg tags, something like :
/* $DOC$
$NAME$
Button
$CATEGORY$
Control
$SYNTAX STANDART$
$SYNTAX ALTERNATE$
$SYNTAX OOP$
$PROPERTIES$
$METHODS$
$EVENTS$
As we know, programmers don't like too much write help text.
Building help files in ascii mode is more easy to maintain by the team than htm files directly.
To keep HMG3.x style, we can create a simple (well maybe not so simple) tool to generate the htm files reading these templates.
Creating a Doc folder in SVN the team can update these files.
Of course the initial task is not simple we have to create each file with data from htm files of hgm3.
Team, what you think ?
It's a nice recommendation Carlos.
