Thanks a lot Ricci. I have applied your patch on 3.0.36 (Test) version and will upload the patch today.
Had you found out the solution to the problem you have mentioned?
Major bug in resource management
Re: Major bug in resource management
Please take a look at the attached file. Inside you found the 3 files from the source-directory of HMG.
Search with your editor for the word "Ricci" and you will find the fixed.
- 3.0.35a.ZIP
- (62.73 KiB) Downloaded 319 times
Ricci,Ricci wrote:Please take a look at the attached file. Inside you found the 3 files from the source-directory of HMG.
This I had already given effect by a patch today.
I wanted to know about the 'Modal' Window handle problem.
No, I didn´t found a solution. Sorry.rathinagiri wrote:I wanted to know about the 'Modal' Window handle problem.
