Adaptation of FiveWin class TsBrowse to HMG
- HMG Founder
Re: Adaptation of FiveWin class TsBrowse to HMG
Grigory,
Issues 1,2,3,4,6 and 7 arises in minigui ext. too, so these problems are not related with your port to HMG.
- HMG Founder
Grigory,
I've found another problem:
If you try to drag 'January' column on super columns sample, you will lost ability to move, maximize, minimize or close the window.
This problem arises on minigui ext. and the HMG port.
- MigSoft
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Hay una película llamada "A mí quién me manda meterme en esto"
Tranquilo Grigory, puede ser que en la versión Tsbrowse 9.0 de Manuel Mercado
encuentres la solución.
Envío todo mi apoyo para lograr el objetivo.
Saludos,
Miguel Angel Juárez A.
Google..
There is a movie called "A who's telling me to get into this"
Grigory Still, maybe in version 9.0 Tsbrowse Manuel Mercado
find the solution.
Sending all my support to achieve the objective.
Miguel Angel Juarez A.
Saludos,
Google..
find the solution.
Dear Grigory:
I do not know a word of MiniGUI (this is my first day by here) but gladly help you in regards to TSBrowse.
Please send me an email to send you TSBrowse V.9.0 Beta.
Manuel Mercado Gómez.
manuelmercado @ prodigy. net. mx
Hello Manuel Mercado,mmercado wrote:Dear Grigory:
Thanks a lot for your suggestion
I'm glad to see you on the HMG forum very much.
My e-mail is gfilatov@freemail.ru
Hello Grigory,
I missed this topic
Thanks a lot
I just found it and downloaded your code.
For my first try I faced some problem during compilation.
May be I need to change some batch files (as I installed HMG in e:\hmg)
I shall send my feedback later.
After some time:
I ran it. Excellent!!! Great!!! Thanks a lot
I really need it.
I tested Tbrowse.1. For window 7 sample, I found some problem when double clicking any cell around middle of the window, it shows a rectangle in another place. But, this is a very small problem
There are some mionr rough edges also.
I haven't tested Tbrowse.2 sample yet.
Thank you again
I missed this topic
Thanks a lot
After some time:
I really need it.
Thank you again
After more or less one year is over, is there any improvement possible?
Hi!
I'm interested on fast tbrowse, isn't it?
What about new version?
My client is unhappy for speed of browse, in network environment, too. I've tested GRID, but I met some problems.
I'm looking for fast browsing of dbf file.
What can I use?
Best regards, Marek
What can I use?
Best regards, Marek
Hi!
Can anybody help me, how to update this tbrowse for hmg.3.0.39?
Regards, Marek
Regards, Marek
Hi Marek,mol wrote:Hi!
Thanks for your request!
I have an updated version this tbrowse 7.0 for hmg.3.0.39 (look for attachment).
The archive contains the all changed sources and precompiled hmg and tbrowse libraries.
You should to start build.bat with the command line 'demo.prg demo.hbc' for proper compiling the tbrowse samples.
BTW There are a known bugs reported on this forum in this updated version
This distribution is provided AS IS, without any warranty.
- TBrowse Demo 2 screenshot
- tsb-demo.jpg (110.28 KiB) Viewed 7934 times
- hmg-tbrowse-7.zip
- TBrowse update
- (598.74 KiB) Downloaded 558 times
