HMG 3.0.33
Czarny_Pijar
Re: HMG 3.0.33
Post by Czarny_Pijar »
Roberto Lopez wrote:
Roberto Lopez wrote: Please, take a look at the following IDE GRID attached sample.
And please, let me know your experience. I want to solve any problem that arises and clarify any other question you have.
Happiness is short. Just turn this :
  sele 1
  Use b1emp
        Load Window Main
        Main.Center
        Main.Activate
into this:
  sele 1
	Use b1emp
	sele 2
	Use b2sal
        Load Window Main
        Main.Center
        Main.Activate
and we get this:
HMG Errorlog File
Date:05/12/10 Time: 15:34:29
Error BASE/1102 Argument error: UPPER
Called from UPPER(0)
Called from _DEFINEGRID(162)
Called from MAIN(54)
2bases.zip
(1.75 KiB) Downloaded 271 times
Re: HMG 3.0.33
  sele 1
  Use b1emp
        Load Window Main
        Main.Center
        Main.Activate
into this:
  sele 1
	Use b1emp
	sele 2
	Use b2sal
        Load Window Main
        Main.Center
        Main.Activate
and we get this:
HMG Errorlog File
I'll check it ASAP.
Thanks for the report.
Re: HMG 3.0.33
Roberto Lopez wrote:I'll check it ASAP.Thanks for the report.
I've fixed.
The happiness is here again ;)
Please, replace your libhmg.a with the one attached.
libhmgtest.rar
(195.06 KiB) Downloaded 264 times
Re: HMG 3.0.33
gfilatov wrote:Please try to edit the first line of Grid by <Enter> key since the first cell in the sample below.
When you press Enter for exit from editing you'll move to 4th numeric cell but you should move to 2nd character editable cell.
It seems that there is a problem with CellValue property into ColumnWhen block :?:
I'm working on it right now.
You are right in both of your assumptions.
1. The problem was introduced in 3.0.31
2. The problem is that This.CellValue property is incorrect (the corresponding to the first column is always returned).
I'll still working on it.
Thanks for the sample and explanation. That facilitate my work a lot.
Re: HMG 3.0.33
Gracias Roberto por esta nueva actualización.
Saludos,
Claudio Soto.
Re: HMG 3.0.33
And the 'guilty' code is:
- Modified: Exiting from grid cell edit, jumps to the next editable cell. Requested by Sudip.
Will be very difficult to keep this functionality and 'When' working... I'll try...
Re: HMG 3.0.33
gfilatov wrote:
Roberto Lopez wrote:- HMG 3.0.33 Changelog:
- Fixed: Grid 'ColumnWhen' property problems. Reported by Claudio.
Hello Roberto,
There is an other problem with Grid 'ColumnWhen' moving after HMG 3.0.31.
I've fixed. Please test with the attached library.
test3033c.rar
(195.37 KiB) Downloaded 282 times
Re: HMG 3.0.33
Thanks a lot Roberto. :)
Czarny_Pijar
Re: HMG 3.0.33
Let's say this is the 3.0.33d version :)
Re: HMG 3.0.33
Thanks a lot Roberto. It works smoothly now. 8-)
