ÍNDICE o INDICE
Czarny_Pijar
Re: ÍNDICE o INDICE
Post by Czarny_Pijar »
Czarny_Pijar wrote:Me gustaría presentar la función inspirado en esgici, que cumpla con los objetivos de Algernon
I'd like to present the function inspired by esgici, that fulfills the goals of Algernon
#define cEspCharSet_1 "AÁaáBbCcDdEÉeéFfGgHhIíJjKkLlMmNnÑñOoPpQqRrSsTtUuVvWwXxYyZz"
#define cEspCharSet_2 "AAaaBbCcDdEEeeFfGgHhIíJjKkLlMmNnNnOoPpQqRrSsTtUuVvWwXxYyZz"
* EspAColSeq    : Español Alternate Collating Sequence
FUNC EspAColSeq(  cInStr  )                       // Español Alternate Collating Sequence
   LOCA cOutStr      := "",;
        cLetter_in   := "",;
        cLetter_out  := "",;
        nCounter     :=  0,;
        nChrPtr      :=  0
   FOR  nCounter := 1 TO LEN( cInStr )
      cLetter_in := SUBS( cInStr, nCounter, 1)
      nChrPtr    := AT( cLetter_in, cEspCharSet_1 )
      cLetter_out:= IIF( nChrPtr == 0, cLetter_in, SUBS(cEspCharSet_2, nChrPtr, 1 ))
      cOutStr     := cOutStr +  cLetter_out
RETU cOutStr
Beware! Not tested!
Mejor es mejor que bueno. Al cambiar estas líneas usted mejorará la velocidad con la misma funcionalidad.
Better is better than good. By changing these lines you'll improve the speed with the equal functionality.
#define cEspCharSet_1 "ÁáÉéÑñ"
#define cEspCharSet_2 "AaEeNn"
Beware! Also not tested!
Re: ÍNDICE o INDICE
Hi Czarny
Are you sure that this way is adequate ?
If two or more key are equal how will be its sequence ?
Re: ÍNDICE o INDICE / Upper or Lower ?
Hi All
SET LANGUAGE TO xxxx,
EXTERNAL HB_CODEPAGE_xxxx
REQUEST HB_SETCODEPAGE
HB_SETCODEPAGE('xxxx')
and others...
All are useful and adequate functions / commands, no doubt.
But sometime inefficient for me :(
And, I'm using my own case convert function :)
By changing two national character set layout, usable for all languages.
f.e. :
DEFINE TEXTBOX xxx
     ON CHANGE { || this.value := NatChCas( this.value ) }
END TEXTBOX
Enjoy !
NatChCas.zip
National case converter
(1008 Bytes) Downloaded 361 times
esgici wrote:...
Added : NatUpper() and NatLower() functions.
Enjoy !
NatChCas2.zip
National Case Convert - 2 ( 3 functions)
(1.31 KiB) Downloaded 429 times
