QUIT problem
Re: QUIT problem
Roberto Lopez wrote:
Steed wrote:Hi, Roberto
Something is happend with command QUIT i think is overlaped the commad oExcel:Quit(), attached please find a little example. the error that these show is: Test.prg(52) Error E0030 Syntax error "syntax error at 'WINDOW'"
Ed
Hola Roberto,
Algo esta pasando con el comando QUIT , creo que esta traslapando el comando oExcel:Quit(), adjunto un pequeño ejemplo, el error que muestras es:
Saludos,
Ed
I'll check it ASAP.
Thanks for reporting.
I've found the problem.
I've added the following directive:
#xtranslate QUIT  => RELEASE WINDOW ALL
But it should be:
#command QUIT  => RELEASE WINDOW ALL
This should solve the problem.
Re: QUIT problem
Nice Roberto. :) As simple as that.
