HMG 3.0.20 Final Release
Alex Gustow
Re: HMG 3.0.20 Final Release
Post by Alex Gustow »
Many thanks to Roberto and all who helps to build this next floor in our common home - HMG! :)
Steed
Post by Steed »
Congratulations Roberto,
Vanguarda
Post by Vanguarda »
Hi friends,
Roberto, i want report that, i don´t be able to reproduce a sample with PLAYER component.
In bellow follow the message that i gotta in here. I think that some thing change in this new version, or not?
The sample that i try execute was "C:\hmg\Samples\PLAYER"
My best regards,
PS: Sorry my bad english
Vanguarda wrote:Hi friends,
I confirm the problem.
I'll TRY TO fix it ASAP.
Vanguarda
Post by Vanguarda »
Roberto Lopez wrote: I confirm the problem.
Thanks.
My best regards,
Thanks.
My best regards,
It's already fixed, please, delete the line #145 in c_media.c and rebuild the library:
Line#145:
hwnd=0;
Vanguarda
Post by Vanguarda »
Roberto Lopez wrote: It's already fixed, please, delete the line #145 in c_media.c and rebuild the library:
Line#145:
hwnd=0;
Thanks Master,
It´s working fine now.
Thanks for you fast support.
My best regards,
Thanks Roberto,
Luis Vasquez
mol wrote:I think, something is wrong with GRID control when used to browse database.
Try to add and delete some records.
Empty rows appear in grid.
Strange effects when clicking in the grid...
Ok.
I've not documented (I've forgot it) but, at the moment, data-bound grid DOES NOT SUPPORT the use of SET FILTER and SET DELETED commands.
Your sample uses SET DELETED, that is the problem.
I think that was real cause of these strange behaviors. When I started with empty database and added new records, everything worked OK.
Thanks for explanation, Roberto!
danielcrocciari
DBs Used: DBF, MySQL, SQLite
Post by danielcrocciari »
Basic Tests completed.
I got hit with the major components.
Thank you very much.
Daniel Crocciari
Brasil - Japan
Projetos HMGLights
HMGLights Site
Canal do YouTube
http://www.youtube.com/hmglights
Céu Azul Tecnologia & Software
http://www.ceuazul.net
