SQL Database + Array RDD
Re: SQL Database + Array RDD
Hello Kana,
Have you tried with hb_dbcreatetemp(tablename, table_structure_array). This is a Harbour function to create temporary disk table.
Kana wrote: Is it possible to modify the connection to other SQL database?
AFAIK, no. It even needs libmysql.dll to work.
But, you could try with \samples\rdd.sql\mdb with any sql server having an ODBC client. I've not tested, but it could work.
Of course, you should change connection data (line 15).
