Yes - we are laughing during this cool test!rathinagiri wrote:Super Alex.
Happy that you have enjoyed.
How to speak your PC./ como hacer hablar tu pc.
- Alex Gustow
Re: How to speak your PC./ como hacer hablar tu pc.
- mustafa
Hi Sudip applying is very good but
I ask that if you could slow down a bit
when reciting what was written in my order
is very fast and hardly understood and that this
Prehistory is a Pentium III XP Sp2
greeting friends
Hola la aplicación de Sudip es muy buena pero
quiero preguntar que si se podria relentizar un poco
cuando recita lo que se ha escrito , en mi ordenar
es muy rapido y casi no se entiende y esto que
es de la PreHistoria es un Pentium III XP Sp2
Saludo Amigos
greeting friends
Saludo Amigos
I didn't want to write it ....Alex Gustow wrote:Nomol wrote:Do you it's "soup" (something for eat?)It's a place where "modified" vegetables and meat of soup goes out from you
But, you should listen this one: doupa
Hi Mustafa,mustafa wrote:Hi Sudip applying is very good but
greeting friends
Saludo Amigos
We can change the speed, pitch and other settings using control panel -> Speech settings
- mustafa
Hola amigos:
Revisando la web he encontrando un antiguo sample
con el titulo de "How to speak your PC./ como hacer hablar tu pc."
en que Sudip presento un codigo de sample y yo aporté una antigua
aplicacion de Clipper con el nombre de Music_Tone.zip
He actualizado un poco la misma aplicación espero les pueda gustar
*--------------------------- Google -------------------------------*
Hello friends:
Checking the web I found an old sample
with the title How to speak your PC./ como hacer hablar tu pc."
Sudip that present a code sample and I brought an old
Clipper application under the name Music_Tone.zip
I updated a bit the same issue I hope you can like it
Hello friends:
- Music_Tone_New.zip
- (2.56 MiB) Downloaded 497 times
- screenshot.jpg (142.58 KiB) Viewed 5871 times
wow, nostalgia, cuando corria en una pc 8086 un programita con esas notas.
Gracias mustafa.
wow, nostalgia, when run a little program in pc 8086 with these notes.
Thanks mustafa
Gracias mustafa.
Thanks mustafa
Bonita aplicacion Mustafa, Felicidades!
