Page 3 of 4
Re: Useful UDF (User defined functions)
Posted: Sun Apr 11, 2010 6:38 am
by sudip
Hello All,
I just created a very simple function to get the selected item from a combobox of a grid. Here it is:
function GetGridEditComboItem ( cGridName, cWindowName, nColIndex, nComboVal )
local i := GetControlIndex ( cGridName, cWindowName )
local aEditcontrols := _HMG_SYSDATA [ 40 ] [ i ] [ 2 ]
if nComboVal >= 1 .and. nComboVal <= len(aEditControls[nColIndex][2])
return (aEditControls[nColIndex][2][nComboVal])
return ""
Usage is like:
... mitemnm := GetGridEditComboItem ( 'proddtl', 'prod', 1, prod.proddtl.cell(i, 1))
table := sql(mdb, "select rate, uom from item where itemnm = "+c2sql(mitemnm))...
I shall be very happy to receive any good suggestion from you
With best regards.
Posted: Sun Sep 18, 2011 5:47 am
by bpd2000
Dear All HMG Members
You all are talented persons to create UDF
But since long no new UDF
Please provide UDF used by you for users
Is ther function to retrive HD serial number and computer / Board ID / serial number
Thank you
Posted: Mon Sep 19, 2011 12:27 pm
by bpd2000
Roman number related function
Download link
http://ifile.it/2hkav8f/Roman.prg
Posted: Wed Dec 28, 2011 2:29 pm
Hi colleague ! Is there any way to put source-code because I can not dowload it.
Posted: Wed Dec 28, 2011 2:41 pm
Hi Pablo
You haven't
download ticket
- Roman.zip
- Roman.prg
- (2.14 KiB) Downloaded 922 times
Posted: Wed Dec 28, 2011 8:23 pm
Thank you, meritorious colleague Esgici !
Posted: Fri Mar 23, 2012 6:29 am
Here is a HMG function for exporting arrays to csv files. That will be very much helpful in exporting a report to another software (like Excel)
function array2csv( aInData )
local filename := ""
local lines := 0
local i := 0
local count1 := 0
local linedata := {}
local aData := {}
local cdata := ""
local aclinedata := {}
local fhandle := 0
local linebreak := chr(13)
local aline := {}
local cline := ''
filename := PutFile ( {{"Comma Separated Value Files (*.csv)","*.csv"}} , "Export to text file (CSV)" , , .f. )
if len(alltrim(filename)) == 0
return nil
if at(".csv",lower(filename)) > 0
if .not. right(lower(filename),4) == ".csv"
filename := filename + ".csv"
if file(filename)
if .not. msgyesno("Are you sure to overwrite?","Export to text file (CSV)")
return nil
fhandle := fcreate(filename)
if fhandle < 0
msgstop("File "+filename+" could not be created!")
return nil
for count1 := 1 to len( aInData )
asize( aclinedata, 0 )
lineData := aInData[ count1 ]
for count2 := 1 to len( linedata )
do case
case ValType(linedata[count2]) == "N"
cdata := LTrim( Str( linedata[count2] ) )
case ValType(linedata[count2]) == "D"
cdata := dtoc( linedata[count2])
case ValType(linedata[count2]) == "L"
cdata := iif(linedata[count2],"TRUE","FALSE")
otherwise
cdata := linedata[count2]
endcase
aadd(aclinedata,cdata)
next count2
aadd(adata,aclone(aclinedata))
next count1
for count1 := 1 to len(adata)
cline := ''
aline := adata[count1]
for count2 := 1 to len(aline)
cline := cline + '"' + _parsequote(aline[count2]) + '"'
if .not. count2 == len(aline)
cline := cline + ','
next count2
cline := cline + linebreak
fwrite(fhandle,cline)
next count1
if fclose(fhandle)
msginfo("Exported Successfully!")
msgstop("Error in saving!")
return nil
function _parsequote(cdata)
local i := 0
local cout := ""
for i := 1 to len(cdata)
if sub str(cdata,i,1) == '"'
cout := cout + sub str(cdata,i,1) + '"'
next i
return cout
Remove the space between sub and str.
Posted: Fri Mar 23, 2012 11:03 am
by mol
Very fine, Rathi!
I want to post my very little function for gisplay debugging info - when you are debugging program, sometime is easy to display only few variables, not run whole debugger.
There is a little function doing it:
function DebugMSG
local i, aTemp := {}
for i := 1 to pcount()
aadd( aTemp, hb_PValue(i))
next i
msgbox(hb_valtoexp(aTemp), "Helpful informations")
return
You can call
DebugMSG with many parameters without carrying about their types.
Regards, Marek
Posted: Fri Mar 23, 2012 11:34 am
Thanks Rathi
Useful utilty, nice sample, good work
Posted: Fri Mar 23, 2012 11:37 am
Thanks Mol
Good job
