HMG 3.4.3
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
Thanks!
Re: HMG 3.4.3
KDJ wrote: Sat Feb 18, 2017 10:20 pm Claudio
Thank you very much for the patch.
srvet_claudio wrote: Sat Feb 18, 2017 2:50 pm Hi all,
please test this patch:
   - Fixed leak memory in HMG_UPPER and HMG_LOWER functions (reported by KDJ)
This has been fixed at one-third, because in HMG_UPPER function are used three buffers allocated on the heap, and only one has been released:
1. "Text" buffer returned by HMG_parc(1) - not released,
2. "Buffer" buffer - this is released,
3. buffer returned by hb_osStrU16Decode(Buffer) in HMG_retc(Buffer) - not released.
My solutions are the following:
   HB_FUNC (HMG_UPPER1)
      TCHAR *Text   = (TCHAR*)  HMG_parc(1);
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      INT   nLen    = (INT)     lstrlen(Text) + 1;
      TCHAR *Buffer = (TCHAR *) hb_xgrab (nLen * sizeof(TCHAR));
      if (Buffer != NULL)
      {   lstrcpy (Buffer, Text);
          CharUpper (Buffer);
          LPSTR RetStr = hb_osStrU16Decode(Buffer);
          hb_retc (RetStr);
          hb_xfree (RetStr);
          hb_xfree (Buffer);
         HMG_retc (NULL);
      hb_xfree (Text);
or with two buffers only (works faster and involves less memory):
   HB_FUNC (HMG_UPPER2)
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      CharUpper (Text);
      LPSTR RetStr = hb_osStrU16Decode(Text);
      hb_retc (RetStr);
      hb_xfree (RetStr);
      hb_xfree (Text);
Program to test:
// Press 'Test: ...' and observe memory usage at status bar
#include 'hmg.ch'
FUNCTION Main()
  SET FONT TO 'MS Shell Dlg', 8
  DEFINE WINDOW MainWnd;
    COL    200;
    ROW    100;
    WIDTH  180;
    HEIGHT 210;
    TITLE  'Memory usage test';
    MAIN;
    MINBUTTON .F.;
    MAXBUTTON .F.;
    NOSIZE
    DEFINE BUTTON Test1_BU
      COL      10
      ROW      20
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper'
      ACTION  DoTest(@HMG_Upper())
    END BUTTON
    DEFINE BUTTON Test2_BU
      COL      10
      ROW      50
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper1'
      ACTION  DoTest(@HMG_Upper1())
    END BUTTON
    DEFINE BUTTON Test3_BU
      COL      10
      ROW      80
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper2'
      ACTION  DoTest(@HMG_Upper2())
    END BUTTON
    DEFINE BUTTON Test4_BU
      COL      10
      ROW     110
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: Upper'
      ACTION  DoTest(@Upper())
    END BUTTON
    DEFINE STATUSBAR
      STATUSITEM ''
    END STATUSBAR
    DEFINE TIMER MainWnd_TI;
      INTERVAL 1000;
      ACTION   UpdateStatus()
    ON KEY ESCAPE ACTION MainWnd.RELEASE
  UpdateStatus()
  MainWnd.ACTIVATE
FUNCTION DoTest(sFunc)
  LOCAL cLowerStr := 'abcdefghijklmnop'
  LOCAL cUpperStr
  LOCAL nSeconds
  LOCAL cTime
  LOCAL n
  nSeconds := Seconds()
  FOR n := 1 TO 100000
    cUpperStr := sFunc:exec(cLowerStr)
  cTime := Str((Seconds() - nSeconds) * 1000, 5)
  UpdateStatus()
  MsgBox('Lower: ' + cLowerStr + CRLF + 'Upper: ' + cUpperStr + CRLF + 'Time: ' + cTime + ' ms', sFunc:name + '()')
FUNCTION UpdateStatus()
  MainWnd.STATUSBAR.Item(1) := 'Memory usage: ' + LTrim(Str(GetProcessMemoryInfo()[3] / 1024, 10, 0) + ' KB')
#pragma BEGINDUMP
  #include "HMG_UNICODE.h"
  #include <windows.h>
  #include "hbapi.h"
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      if (Buffer != NULL)
          CharUpper (Buffer);
          hb_retc (RetStr);
          hb_xfree (RetStr);
          hb_xfree (Buffer);
         HMG_retc (NULL);
      hb_xfree (Text);
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      CharUpper (Text);
      hb_retc (RetStr);
      hb_xfree (RetStr);
      hb_xfree (Text);
#pragma ENDDUMP
PS:
Unresolved is the question of the HMG_parc, HMG_retc and HMG_storc, HMG_itemPutC macros in other functions and HMG_GetUnicodeCharacter, HMG_UNICODE_TO_ANSI, HMG_ANSI_TO_UNICODE.
I wrote about it here:
viewtopic.php?f=20&t=4884&p=48854#p48854
viewtopic.php?f=20&t=4884&p=49045#p49045
Yes you are right, to fix the buffet reserved by HMG_xx string functions is necessary to implement a native garbage collection in HMG (this is quite simple but requires a great work of modification in the source code), otherwise a not very elegant way is to call the garbage collection of Harbour. I wrote in my todo list.
Re: HMG 3.4.3
Thank you very much Doc.
Viva HMG :D
Re: HMG 3.4.3
srvet_claudio wrote: Sun Feb 19, 2017 12:51 am
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      if (Buffer != NULL)
          CharUpper (Buffer);
          hb_retc (RetStr);
          hb_xfree (RetStr);
          hb_xfree (Buffer);
         HMG_retc (NULL);
      hb_xfree (Text);
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      CharUpper (Text);
      hb_retc (RetStr);
      hb_xfree (RetStr);
      hb_xfree (Text);
Program to test:
#include 'hmg.ch'
FUNCTION Main()
    COL    200;
    ROW    100;
    WIDTH  180;
    HEIGHT 210;
    MAIN;
    MINBUTTON .F.;
    MAXBUTTON .F.;
    NOSIZE
      COL      10
      ROW      20
      WIDTH   150
      HEIGHT   25
    END BUTTON
      COL      10
      ROW      50
      WIDTH   150
      HEIGHT   25
    END BUTTON
      COL      10
      ROW      80
      WIDTH   150
      HEIGHT   25
    END BUTTON
      COL      10
      ROW     110
      WIDTH   150
      HEIGHT   25
    END BUTTON
    DEFINE STATUSBAR
      STATUSITEM ''
    END STATUSBAR
      INTERVAL 1000;
  UpdateStatus()
  MainWnd.ACTIVATE
  LOCAL cUpperStr
  LOCAL nSeconds
  LOCAL cTime
  LOCAL n
  UpdateStatus()
#pragma BEGINDUMP
  #include "hbapi.h"
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      if (Buffer != NULL)
          CharUpper (Buffer);
          hb_retc (RetStr);
          hb_xfree (RetStr);
          hb_xfree (Buffer);
         HMG_retc (NULL);
      hb_xfree (Text);
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      CharUpper (Text);
      hb_retc (RetStr);
      hb_xfree (RetStr);
      hb_xfree (Text);
#pragma ENDDUMP
PS:
The return functions is easy to fix, for example:
Change:
#define HMG_retc(c) hb_retc (HMG_WCHAR_TO_CHAR(c))
For:
#define HMG_retc(c) __p = HMG_WCHAR_TO_CHAR(c); hb_retc (__p); if(__p) hb_xfree(__p)
Where
__p is a global char pointer.
char * __p = NULL;
Or:
void HMG_retc( WCHAR * c )
char * __p = HMG_WCHAR_TO_CHAR(c);
hb_retc (__p);
if(__p) hb_xfree(__p);
KDJ
Re: HMG 3.4.3
Post by KDJ »
So remains only to solve the problem of HMG_parc.
Re: HMG 3.4.3
KDJ wrote: Sun Feb 19, 2017 3:33 pm So remains only to solve the problem of HMG_parc.
For example:
#define HMG_parc(n,var) __wc = HMG_CHAR_TO_WCHAR (hb_parc(n))
; WCHAR var [ lstrlen(__wc) + 1]; if(__wc) { lstrcpy(var, __wc); hb_xfree(__wc);} else var[0]=0
where __wc is a global WCHAR pointer, and instead of using:
WCHAR * str = HMG_parc(1) ;
use:
HMG_parc(1,str);
KDJ
Re: HMG 3.4.3
Post by KDJ »
srvet_claudio wrote: Sun Feb 19, 2017 5:01 pm
It seems to me that here is possible stack overflow:
Re: HMG 3.4.3
KDJ wrote: Sun Feb 19, 2017 9:56 pm
In practice it is rare, I never had problems in HMG with this type of code, in HMG rarely used huge strings. The default stack size is 1 MB.
KDJ
Re: HMG 3.4.3
Post by KDJ »
Claudio
For example in EditBox a string may be much larger than 1 MB.
And it is not a rare case.
When using SetWindowText() with such string, will occur runtime error.
Re: HMG 3.4.3
KDJ wrote: Mon Feb 20, 2017 9:43 pm Claudio
When you expect a huge string you can explicitly allocate and free the memory, but that is not the case for the vast majority of controls in HMG.
