HMG 3.4.3
rakesh1201
Re: GRID CONTROL problem
Post by rakesh1201 »
Huiyi,
I think there is a solution to your problem. Your code has been modified as follows:
PRIVATE n // declare a private variable
MAKEDATA()
DEFINE WINDOW MAIN AT 213 , 425;
WIDTH 482 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil ;
TITLE "Test grid control" ICON NIL MAIN CURSOR NIL
DEFINE LABEL Label_1
ROW 30
COL 40
WIDTH 120
HEIGHT 24
VALUE "Enter filter value"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
RIGHTALIGN .T.
END LABEL
DEFINE TEXTBOX Text_1
ROW 30
COL 180
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
CASECONVERT NONE
BACKCOLOR NIL
FONTCOLOR NIL
INPUTMASK "!!!!!"
FORMAT Nil
VALUE ""
END TEXTBOX
DEFINE BUTTON Button_1
ROW 30
COL 330
WIDTH 100
HEIGHT 28
ACTION FILTER(MAIN.TEXT_1.VALUE)
CAPTION "FILTER"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
PICTURE Nil
PICTALIGNMENT TOP
END BUTTON
DEFINE GRID Grid_1
ROW 80
COL 30
WIDTH 420
HEIGHT 210
ITEMS { {""} }
VALUE Nil
WIDTHS {200,200 }
HEADERS {"field1","field2"}
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
BACKCOLOR NIL
FONTCOLOR NIL
HEADERIMAGES Nil
ROWSOURCE "test"
COLUMNFIELDS {"AA","BB"}
ALLOWAPPEND .F.
ALLOWDELETE .F.
BUFFERED .F.
DYNAMICDISPLAY Nil
ONSAVE Nil
LOCKCOLUMNS 0
ONCHANGE GridRefresh() // call a function when this event is fired
END GRID
Main.Center
Main.Activate
function makedata()
local astru:={{"AA","C",3,0},{"BB","C",5,0}}
dbcreate("test.dbf",astru)
use test new
dbAppend()
TEST->AA:="11"
TEST->BB:="AAAAA"
dbAppend()
TEST->AA:="12"
TEST->BB:="BBBBB"
dbAppend()
TEST->AA:="13"
TEST->BB:="AAAAA"
dbAppend()
TEST->AA:="14"
TEST->BB:="CCCCC"
dbAppend()
TEST->AA:="15"
TEST->BB:="AAAAA"
dbAppend()
TEST->AA:="16"
TEST->BB:="AAAAA"
count to n // store number of records
FUNCTION FILTER(CVALUE)
IF EMPTY(CVALUE)
dbClearFilter()
dbSETFilter({||TEST->BB==CVALUE})
count to n // store number of filtered records
TEST->(DBGOTOP())
MAIN.GRID_1.REFRESH()
MAIN.GRID_1.SetFocus() // set focus on to the grid
keybd_event ( VK_DOWN ) //simulate key down and key up
keybd_event ( VK_UP )
Function GridRefresh()
MAIN.GRID_1.ItemCount := n // set grid itemcount to number of records
return NIL
It is working with HMG 3.4.3
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
Thanks rakesh1201 for your solution.
huiyi
Re: HMG 3.4.3
Hi all,
please test this patch:
   - Fixed bug in BrowseUpdate function of Browse control(contrib by Marek)
   - Fixed bug in _ActivateWindow when use debug with modal window
   - Fixed bug in grid onquery event
   - Fixed bug in grid when load NIL values(hb_ValToStr)
   - Fixed bug in grid inplace column (contrib by ASESORMIX)
   - Implemented GetProperty ReadOnly EditBox and TextBox
   - Fixed bug in BT_BitmapSaveFile() function (reported by Roberto Lopez)
   - Fixed problem in Navigator.htm file of documentation (contrib by Roberto Lopez)
   - Fixed bug in GetLastActiveFormIndex() and GetLastActiveControlIndex() functions (contrib by Pablo Cesar)
   - Fixed bug in GetMainFormName() and GetMainFormHandle() functions (contrib by KDJ)
   - Fixed leak memory in HMG_UPPER and HMG_LOWER functions (reported by KDJ)
   - Fixed bug in HMG_EditControlGetSel() function (contrib by KDJ)
   - Fixed bug in HMG_ISALPHA, HMG_ISDIGIT, HMG_ISLOWER, HMG_ISUPPER, HMG_ISALPHANUMERIC functions (reported by Esgici)
   - Fixed functions BT_DrawTextXXX, BT_DrawTextEx ( see SaveDC in the code )
   - New: BT_DrawEMF ( [ hDC ] , cFileNameOld , cFileNameNew , cFuncNameCallBack )  ---> Return nError, e.g. Zero is OK
   - New: BT_BitmapIsValidFileImage( cFileName )
HMG.3.4.3_patch_1.rar
(3.68 MiB) Downloaded 499 times
Re: HMG 3.4.3
Thanks a lot Claudio!
Re: HMG 3.4.3
Claudio, thank you very much for all the work involved !!
Re: HMG 3.4.3
serge_girard wrote: Sat Feb 18, 2017 3:40 pm Claudio, thank you very much for all the work involved !!
tonton2
Re: HMG 3.4.3
Post by tonton2 »
merci beaucoup Dr Claudio
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
KDJ
Re: HMG 3.4.3
Post by KDJ »
Claudio
Thank you very much for the patch.
srvet_claudio wrote: Sat Feb 18, 2017 2:50 pm Hi all,
This has been fixed at one-third, because in HMG_UPPER function are used three buffers allocated on the heap, and only one has been released:
1. "Text" buffer returned by HMG_parc(1) - not released,
2. "Buffer" buffer - this is released,
3. buffer returned by hb_osStrU16Decode(Buffer) in HMG_retc(Buffer) - not released.
My solutions are the following:
   HB_FUNC (HMG_UPPER1)
      TCHAR *Text   = (TCHAR*)  HMG_parc(1);
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      INT   nLen    = (INT)     lstrlen(Text) + 1;
      TCHAR *Buffer = (TCHAR *) hb_xgrab (nLen * sizeof(TCHAR));
      if (Buffer != NULL)
      {   lstrcpy (Buffer, Text);
          CharUpper (Buffer);
          LPSTR RetStr = hb_osStrU16Decode(Buffer);
          hb_retc (RetStr);
          hb_xfree (RetStr);
          hb_xfree (Buffer);
         HMG_retc (NULL);
      hb_xfree (Text);
or with two buffers only (works faster and involves less memory):
   HB_FUNC (HMG_UPPER2)
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      CharUpper (Text);
      LPSTR RetStr = hb_osStrU16Decode(Text);
      hb_retc (RetStr);
      hb_xfree (RetStr);
      hb_xfree (Text);
Program to test:
// Press 'Test: ...' and observe memory usage at status bar
#include 'hmg.ch'
FUNCTION Main()
  SET FONT TO 'MS Shell Dlg', 8
  DEFINE WINDOW MainWnd;
    COL    200;
    ROW    100;
    WIDTH  180;
    HEIGHT 210;
    TITLE  'Memory usage test';
    MAIN;
    MINBUTTON .F.;
    MAXBUTTON .F.;
    NOSIZE
    DEFINE BUTTON Test1_BU
      COL      10
      ROW      20
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper'
      ACTION  DoTest(@HMG_Upper())
    END BUTTON
    DEFINE BUTTON Test2_BU
      COL      10
      ROW      50
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper1'
      ACTION  DoTest(@HMG_Upper1())
    END BUTTON
    DEFINE BUTTON Test3_BU
      COL      10
      ROW      80
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper2'
      ACTION  DoTest(@HMG_Upper2())
    END BUTTON
    DEFINE BUTTON Test4_BU
      COL      10
      ROW     110
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: Upper'
      ACTION  DoTest(@Upper())
    END BUTTON
    DEFINE STATUSBAR
      STATUSITEM ''
    END STATUSBAR
    DEFINE TIMER MainWnd_TI;
      INTERVAL 1000;
      ACTION   UpdateStatus()
    ON KEY ESCAPE ACTION MainWnd.RELEASE
  UpdateStatus()
  MainWnd.ACTIVATE
FUNCTION DoTest(sFunc)
  LOCAL cLowerStr := 'abcdefghijklmnop'
  LOCAL cUpperStr
  LOCAL nSeconds
  LOCAL cTime
  LOCAL n
  nSeconds := Seconds()
  FOR n := 1 TO 100000
    cUpperStr := sFunc:exec(cLowerStr)
  cTime := Str((Seconds() - nSeconds) * 1000, 5)
  UpdateStatus()
  MsgBox('Lower: ' + cLowerStr + CRLF + 'Upper: ' + cUpperStr + CRLF + 'Time: ' + cTime + ' ms', sFunc:name + '()')
FUNCTION UpdateStatus()
  MainWnd.STATUSBAR.Item(1) := 'Memory usage: ' + LTrim(Str(GetProcessMemoryInfo()[3] / 1024, 10, 0) + ' KB')
#pragma BEGINDUMP
  #include "HMG_UNICODE.h"
  #include <windows.h>
  #include "hbapi.h"
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      if (Buffer != NULL)
          CharUpper (Buffer);
          hb_retc (RetStr);
          hb_xfree (RetStr);
          hb_xfree (Buffer);
         HMG_retc (NULL);
      hb_xfree (Text);
      if (Text == NULL)
      {   HMG_retc (NULL);
          return;
      CharUpper (Text);
      hb_retc (RetStr);
      hb_xfree (RetStr);
      hb_xfree (Text);
#pragma ENDDUMP
PS:
Unresolved is the question of the HMG_parc, HMG_retc and HMG_storc, HMG_itemPutC macros in other functions and HMG_GetUnicodeCharacter, HMG_UNICODE_TO_ANSI, HMG_ANSI_TO_UNICODE.
I wrote about it here:
viewtopic.php?f=20&t=4884&p=48854#p48854
viewtopic.php?f=20&t=4884&p=49045#p49045
Re: HMG 3.4.3
Gracias Dr. Claudio !
