The original demo of the link that you post have a small bug.chrisjx2002 wrote:I think it works. I have probably found where there is a problem. Thanks Claudio for your help!
HMG.3.4.2
- srvet_claudio
Re: HMG.3.4.2
chrisjx2002
Re: HMG.3.4.2
Try to change Form_1.Button_1.Picture := "" by Setproperty("Form_1","Button_1","caption","") in your program. Then it does not work : the image is not suppress.
- srvet_claudio
Re: HMG.3.4.2
The property is PICTURE not is CAPTION:chrisjx2002 wrote:Try to change Form_1.Button_1.Picture := "" by Setproperty("Form_1","Button_1","caption","") in your program. Then it does not work : the image is not suppress.
SetProperty( "Form_1", "Button_1", "Picture", "" )
- srvet_claudio
Re: hmg unicode ide and timer control
Done !srvet_claudio wrote:I will check.nikko1960 wrote:Hi to all
configuration : win 10 home 64 bit, hmg 3.4.2 ide unicode patch 3, timer control.
i do not know if this is an issue but when you input the value property from Ide the maximum value is 10000 ( i think is equal to ten seconds )
but if you change it in the fmg file you can input more then 10000, it works as expected.
So i suggest to increase this value in HMG-Ide property value.
Domenico
chrisjx2002
Re: HMG.3.4.2
You are right...
I was definitively too tired yesterday evening....
- srvet_claudio
Re: HMG.3.4.2
Hi Friends,
Please test the new version of IDE (ver 1.1)
- now the IDE not convert to lowercase the name of the PRG files
- eliminated the maximum limit of 10000 milliseconds in the Timer control imposed for the IDE
- Zero in MAXLENGTH property of the controls RichEdit, TextBox and EditBox is equal a NIL value
- now double click on the Run or Debug buttons not abort the IDE
- IDE_ver 1.1.rar
- (2.97 MiB) Downloaded 564 times
Re: HMG.3.4.2
Thanks Claudiosrvet_claudio wrote:Hi Friends,
