PDF Viewer DLL?
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
PDFview version 2020-04-16
Fixed minor bug - lost focus in some cases.
PDFview_binary_x64.7z
(9.89 MiB) Downloaded 840 times
PDFview_binary_x86.7z
(9.42 MiB) Downloaded 813 times
PDFview_source.7z
(66.75 KiB) Downloaded 824 times
Re: PDF Viewer DLL?
Wielkie dzięki, Krzysztof 👍
Steed
Re: PDF Viewer DLL?
Post by Steed »
Thanks
ASESORMIX
Re: PDF Viewer DLL?
Post by ASESORMIX »
Buenísimo. Muchas Gracias.
mlnr
Re: PDF Viewer DLL?
Post by mlnr »
I have an application that uses Sumatra PDFView, which works fine with HMG versions 3.44 and 3.6 (64-bit). I would also like to use the WEBVIEW library in this application. https://www.hmgforum.com/viewtopic.php?t=7659 This requires using the -cpp flag.
call c:\hmg.3.6\build64.bat demo %* hbcurl.hbc hbmxml.hbc hbziparc.hbc -lhblibxlsxwriter -cpp -lshlwapi
When I use this flag, I get the following message in the build.log.
PdfView_C.prg: In function 'void HB_FUN_GETCOPYDATASTRING()':
PdfView_C.prg:178:19: error: invalid conversion from 'PVOID' {aka 'void*'} to 'const char*' [-fpermissive]
In file included from PdfView_C.prg:10:
c:/hmg.3.6/harbour64/include/hbapi.h:687:47: note: initializing argument 1 of 'void hb_retc(const char*)'
687 | extern HB_EXPORT void hb_retc( const char * szText ); /* returns a string */
In file included from PdfView_C.prg:4:
PdfView_C.prg:180:20: error: invalid conversion from 'PVOID' {aka 'void*'} to 'const HB_WCHAR*' {aka 'const wchar_t*'} [-fpermissive]
c:/hmg.3.6/include/HMG_UNICODE.h:77:56: note: in definition of macro 'HMG_WCHAR_TO_CHAR'
77 | #define HMG_WCHAR_TO_CHAR(c) hb_osStrU16Decode(c) // return CHAR
PdfView_C.prg:180:5: note: in expansion of macro 'HMG_retc'
c:/hmg.3.6/harbour64/include/hbapi.h:1236:67: note: initializing argument 1 of 'char* hb_osStrU16Decode(const HB_WCHAR*)'
1236 | extern HB_EXPORT char * hb_osStrU16Decode( const HB_WCHAR * pszNameW );
hbmk2[demo]: Error: Running C/C++ compiler. 1
PdfView_C.prg:
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include <windows.h>
#include <windowsx.h>
#include <commctrl.h>
#include <shlobj.h>
#include "hbapi.h"
#include "hbapierr.h"
       //SetCapture(nHWnd)
HB_FUNC( SETCAPTURE )
  HMG_retnl((LONG_PTR) SetCapture((HWND) HMG_parnl(1)));
HB_FUNC( RELEASECAPTURE )
  hb_retl(ReleaseCapture());
       //SetCursorShape(cCursor|nCursor)
HB_FUNC( SETCURSORSHAPE )
  HCURSOR hCursor;
  if (HB_ISCHAR(1))
    hCursor = LoadCursor(GetModuleHandle(NULL), HMG_parc(1));
    hCursor = LoadCursor(NULL, MAKEINTRESOURCE(hb_parni(1)));
  HMG_retnl((LONG_PTR) SetCursor(hCursor));
       //GetWindowNormalPos(hWnd)
HB_FUNC( GETWINDOWNORMALPOS )
  WINDOWPLACEMENT wp;
  wp.length = sizeof(WINDOWPLACEMENT);
  GetWindowPlacement((HWND) HMG_parnl(1), &wp);
  hb_reta(4);
  hb_storvni(wp.rcNormalPosition.left,   -1, 1);
  hb_storvni(wp.rcNormalPosition.top,    -1, 2);
  hb_storvni(wp.rcNormalPosition.right,  -1, 3);
  hb_storvni(wp.rcNormalPosition.bottom, -1, 4);
       //SetMinMaxTrackSize(lParam, nMinX, nMinY, nMaxX, nMaxY)
HB_FUNC( SETMINMAXTRACKSIZE )
  MINMAXINFO *MinMax = (MINMAXINFO *) HMG_parnl(1);
  if (hb_parni(2) > 0)
    MinMax->ptMinTrackSize.x = hb_parni(2);
  if (hb_parni(3) > 0)
    MinMax->ptMinTrackSize.y = hb_parni(3);
  if (hb_parni(4) > 0)
    MinMax->ptMaxTrackSize.x = hb_parni(4);
  if (hb_parni(5) > 0)
    MinMax->ptMaxTrackSize.y = hb_parni(5);
        //GetRectArray(pRect, aRect)
HB_FUNC ( GETRECTARRAY )
  RECT *rc = (RECT *) HMG_parnl(1);
  hb_storvni(rc->left,   2, 1);
  hb_storvni(rc->top,    2, 2);
  hb_storvni(rc->right,  2, 3);
  hb_storvni(rc->bottom, 2, 4);
        //SetRectArray(pRect, aRect)
HB_FUNC ( SETRECTARRAY )
  rc->left   = hb_parvni(2, 1);
  rc->top    = hb_parvni(2, 2);
  rc->right  = hb_parvni(2, 3);
  rc->bottom = hb_parvni(2, 4);
       //lParam form WM_LBUTTON*, WM_MBUTTON*, WM_RBUTTON* messages
       //Tab_HitTest(hWnd, lParam)
HB_FUNC( TAB_HITTEST )
  LPARAM lParam = HMG_parnl(2);
  TCHITTESTINFO tchti;
  tchti.pt.x  = (LONG) GET_X_LPARAM(lParam);
  tchti.pt.y  = (LONG) GET_Y_LPARAM(lParam);
  tchti.flags = TCHT_ONITEM;
  hb_retni(TabCtrl_HitTest((HWND) HMG_parnl(1), &tchti) + 1);
       //TrackPopupMenu2(nHMenu, nFlags, nRow, nCol, nHWnd)
HB_FUNC( TRACKPOPUPMENU2 )
  hb_retni(TrackPopupMenu((HMENU) HMG_parnl(1),
                          (UINT)  hb_parni (2),
                          (INT)   hb_parni (4),
                          (INT)   hb_parni (3),
                          0,
                          (HWND)  HMG_parnl(5),
                          NULL));
       //PaintSizeGrip(nHWnd)
HB_FUNC( PAINTSIZEGRIP )
  HWND        hWnd;
  PAINTSTRUCT ps;
  RECT        rc;
  HDC         hdc;
  hWnd = (HWND) HMG_parnl(1);
  hdc  = BeginPaint(hWnd, &ps);
  if (hdc)
    GetClientRect(hWnd, &rc);
    rc.left = rc.right  - GetSystemMetrics(SM_CXVSCROLL);
    rc.top  = rc.bottom - GetSystemMetrics(SM_CYVSCROLL);
    DrawFrameControl(hdc, &rc, DFC_SCROLL, DFCS_SCROLLSIZEGRIP);
    EndPaint(hWnd, &ps);
       //Send_WM_COPYDATA(nHWnd, nAction, cText)
HB_FUNC( SEND_WM_COPYDATA )
  LPTSTR         Text = (LPTSTR) HMG_parc(3);
  COPYDATASTRUCT cds;
  cds.dwData = HMG_parnl(2);
  cds.cbData = (_tcslen(Text) + 1) * sizeof(TCHAR);
  cds.lpData = Text;
  SendMessageTimeout((HWND) HMG_parnl(1), WM_COPYDATA, (WPARAM) NULL, (LPARAM) &cds, 0, 5000, NULL);
       //GetCopyDataAction(pCDS)
HB_FUNC( GETCOPYDATAACTION )
  PCOPYDATASTRUCT pCDS = (PCOPYDATASTRUCT) HMG_parnl(1);
  HMG_retnl(pCDS->dwData);
       //GetCopyDataString(pCDS, [lIsUTF8])
HB_FUNC( GETCOPYDATASTRING )
  if (hb_parl(2))
    hb_retc(pCDS->lpData);
    HMG_retc(pCDS->lpData);
  Based on code of Dr.Claudio Soto (c_dialogs.c):
    C_GetFolder()
    BrowseCallbackProc()
  Added ability to set dialog position
typedef struct
  TCHAR *cInitPath;
  TCHAR *cInvalidDataMsg;
  BOOL  bSetPos;
  INT   nX;
  INT   nY;
} BFFDATA;
INT CALLBACK BrowseForFolderCallback(HWND hWnd, UINT uMsg, LPARAM lParam, LPARAM lpData)
  // Msg :
  // BFFM_INITIALIZED   : The dialog box has finished initializing.
  // BFFM_IUNKNOWN      : An IUnknown interface is available to the dialog box.
  // BFFM_SELCHANGED    : The selection has changed in the dialog box.
  // BFFM_VALIDATEFAILED: The user typed an invalid name into the dialog's edit box. A nonexistent folder is considered an invalid name.
  // SendMessage ()
  // BFFM_SETSELECTION  : Specifies the path of a folder to select. The path can be specified as a string or a PIDL.
  // BFFM_ENABLEOK      : Enables or disables the dialog box's OK button.
  // BFFM_SETOKTEXT     : Sets the text that is displayed on the dialog box's OK button.
  // BFFM_SETEXPANDED   : Specifies the path of a folder to expand in the Browse dialog box. The path can be specified as a Unicode string or a PIDL.
  // BFFM_SETSTATUSTEXT : Sets the status text. Set the BrowseForFolderCallback lpData parameter to point to a null-terminated string with the desired text.
  TCHAR cTitle[GetWindowTextLength(hWnd) + 1];
  GetWindowText(hWnd, cTitle, sizeof(cTitle) / sizeof(TCHAR));
  UNREFERENCED_PARAMETER(lParam); //avoid warning message: "lParam defined but not used"
  BFFDATA *BrowseForFolderData = (BFFDATA *) lpData;
  HWND hWndNS;
  HWND hWndTV;
  switch (uMsg)
    case BFFM_INITIALIZED:
      if (BrowseForFolderData->cInitPath)
        SendMessage(hWnd, BFFM_SETSELECTION, (WPARAM) TRUE, (LPARAM) BrowseForFolderData->cInitPath);
      if (BrowseForFolderData->bSetPos)
        SetWindowPos(hWnd, NULL, BrowseForFolderData->nX, BrowseForFolderData->nY, 0, 0, SWP_NOZORDER | SWP_NOACTIVATE | SWP_NOSIZE);
      //set focus to TreeView (Win-XP)
      //set ENSUREVISIBLE (Win-7)
      hWndNS = FindWindowEx(hWnd, NULL, _TEXT("SHBrowseForFolder ShellNameSpace Control"), NULL);
      if (hWndNS)
        hWndTV = FindWindowEx(hWndNS, NULL, _TEXT("SysTreeView32"), NULL);
        if (hWndTV)
          PostMessage(hWnd, WM_NEXTDLGCTL, (WPARAM) hWndTV, TRUE);
          PostMessage(hWndTV, TVM_ENSUREVISIBLE, 0, SendMessage(hWndTV, TVM_GETNEXTITEM, TVGN_CARET, 0));
      break;
    case BFFM_VALIDATEFAILED:
      if (BrowseForFolderData->cInvalidDataMsg)
        MessageBox(hWnd, BrowseForFolderData->cInvalidDataMsg, cTitle, MB_ICONHAND | MB_OK | MB_SYSTEMMODAL); //(TCHAR *)lParam ---> cFolderName
        MessageBeep(MB_ICONHAND);
      return 1;
  return 0;
       //                 1         2         3                    4                    5            6       7
       //BrowseForFolder([cTitle], [nFlags], [nCSIDL_FolderType], [cInvalidDataTitle], [cInitPath], [nRow], [nCol])
HB_FUNC( BROWSEFORFOLDER )
  HWND         hWnd = GetActiveWindow();
  BROWSEINFO   BrowseInfo;
  TCHAR        cBuffer[MAX_PATH];
  LPITEMIDLIST ItemIDList;
  SHGetSpecialFolderLocation(hWnd, HB_ISNIL(3) ? CSIDL_DRIVES : hb_parnl(3), &ItemIDList);
  // BrowseInfo.ulFlags
  // BIF_RETURNONLYFSDIRS   : Only return file system directories.
  // BIF_DONTGOBELOWDOMAIN  : Do not include network folders below the domain level in the dialog box's tree view control.
  // BIF_STATUSTEXT         : Include a status area in the dialog box ( not supported when BIF_NEWDIALOGSTYLE )
  // BIF_RETURNFSANCESTORS  : Only return file system ancestors. An ancestor is a subfolder that is beneath the root folder in the namespace hierarchy.
  // BIF_EDITBOX            : Include an edit control in the browse dialog box that allows the user to type the name of an item.
  // BIF_VALIDATE           : If the user types an invalid name into the edit box, the browse dialog box calls the application's BrowseForFolderCallback
  //                          with the BFFM_VALIDATEFAILED message ( ignored if BIF_EDITBOX is not specified)
  // BIF_NEWDIALOGSTYLE     : Use the new user interface. Setting this flag provides the user with a larger dialog box that can be resized.
  //                          The dialog box has several new capabilities, including: drag-and-drop capability within the dialog box,
  //                          reordering, shortcut menus, new folders, delete, and other shortcut menu commands.
  // BIF_BROWSEINCLUDEURLS  : The browse dialog box can display URLs. The BIF_USENEWUI and BIF_BROWSEINCLUDEFILES flags must also be set.
  // BIF_USENEWUI           : equivalent to BIF_EDITBOX + BIF_NEWDIALOGSTYLE.
  // BIF_UAHINT             : When combined with BIF_NEWDIALOGSTYLE, adds a usage hint to the dialog box, in place of the edit box (BIF_EDITBOX overrides this flag)
  // BIF_NONEWFOLDERBUTTON  : Do not include the New Folder button in the browse dialog box.
  // BIF_NOTRANSLATETARGETS : When the selected item is a shortcut, return the PIDL of the shortcut itself rather than its target.
  // BIF_BROWSEFORCOMPUTER  : Only return computers
  // BIF_BROWSEFORPRINTER   : Only allow the selection of printers. In Windows XP and later systems, the best practice is to use a Windows XP-style dialog,
  //                          setting the root of the dialog to the Printers and Faxes folder (CSIDL_PRINTERS).
  // BIF_BROWSEINCLUDEFILES : The browse dialog box displays files as well as folders.
  // BIF_SHAREABLE          : The browse dialog box can display sharable resources on remote systems. The BIF_NEWDIALOGSTYLE flag must also be set.
  // BIF_BROWSEFILEJUNCTIONS: Windows 7 and later. Allow folder junctions such as a library or a compressed file with a .zip file name extension to be browsed.
  BFFDATA BrowseForFolderData;
  BrowseForFolderData.cInvalidDataMsg = (TCHAR *) HMG_parc(4);
  BrowseForFolderData.cInitPath       = (TCHAR *) HMG_parc(5);
  if (HB_ISNUM(6) && HB_ISNUM(7))
    BrowseForFolderData.bSetPos = TRUE;
    BrowseForFolderData.nX      = hb_parni(7);
    BrowseForFolderData.nY      = hb_parni(6);
    BrowseForFolderData.bSetPos = FALSE;
  BrowseInfo.hwndOwner      = hWnd;
  BrowseInfo.pidlRoot       = ItemIDList;
  BrowseInfo.pszDisplayName = cBuffer;
  BrowseInfo.lpszTitle      = HMG_parc(1);
  BrowseInfo.ulFlags        = hb_parnl(2);
  BrowseInfo.lpfn           = BrowseForFolderCallback;
  BrowseInfo.lParam         = (LPARAM) &BrowseForFolderData;
  BrowseInfo.iImage         = 0;
  ItemIDList = SHBrowseForFolder(&BrowseInfo);
  if (ItemIDList)
    SHGetPathFromIDList(ItemIDList, cBuffer);
    HMG_retc(cBuffer);
    HMG_retc(_TEXT(""));
  CoTaskMemFree((LPVOID) ItemIDList); // It is the responsibility of the calling application to call CoTaskMemFree to free the IDList returned
                                      // by SHBrowseForFolder when it is no longer needed.
  adapted from tip_URLEncode()
       //EncodeURIComponent(cText)
HB_FUNC( ENCODEURICOMPONENT )
  const char * pszData = hb_parc(1);
  if (pszData)
    HB_ISIZ nLen = hb_parclen(1);
    if (nLen)
      HB_ISIZ nPos = 0, nPosRet = 0;
      /*Giving maximum final length possible*/
      char * pszRet = (char *) hb_xgrab(nLen * 3 + 1);
      char cElem;
      HB_UINT uiVal;
      while (nPos < nLen)
        cElem = pszData[nPos];
        if ((cElem >= 'A' && cElem <= 'Z') ||
            (cElem >= 'a' && cElem <= 'z') ||
            (cElem >= '0' && cElem <= '9') ||
            cElem == '-' || cElem == '_' || cElem == '.' || cElem == '!' || cElem == '~' || cElem == '*' || cElem == '\'' || cElem == '(' || cElem == ')')
          pszRet[nPosRet] = cElem;
        else /*encode*/
          pszRet[nPosRet++] = '%';
          uiVal = ((HB_UCHAR) cElem) >> 4;
          pszRet[nPosRet++] = (char) ((uiVal < 10 ? '0' : 'A' - 10) + uiVal);
          uiVal = ((HB_UCHAR) cElem) & 0x0F;
          pszRet[nPosRet] = (char) ((uiVal < 10 ? '0' : 'A' - 10) + uiVal);
        nPosRet++;
        nPos++;
      hb_retclen_buffer(pszRet, nPosRet);
      hb_retc_null();
    hb_errRT_BASE(EG_ARG, 3012, NULL, HB_ERR_FUNCNAME, 1, hb_paramError(1));
#pragma ENDDUMP
Does anyone have any suggestions for this problem?
mlnr
Re: PDF Viewer DLL?
Post by mlnr »
Maybe I have solved the problem with AI. Modified the PdfView_C.prg.
Locate the function
  if (hb_parl(2))
Modify as follows
  if (hb_parl(2))
    hb_retc((const char *) pCDS->lpData);
    HMG_retc((const HB_WCHAR *) pCDS->lpData);
It seems to work with this.
