HMG 3.4.3
huiyi_ch
Re: GRID CONTROL problem
Post by huiyi_ch »
Hello Dr. Claudio Soto
当我打开数据库(表),与之绑定的GRID 显示正常,但是当我对数据库进行过滤后,我发现符合条件的记录显示不正确.
When I open the database (table), with the binding of the GRID show normal, but when I filter the database, I found that the records are not displayed correctly.
I included my sources and database in attachment in a zip-file.
I use WindowsXp, and installed HMG.3.4.3.Setup.exe.
    MAKEDATA()
    DEFINE WINDOW MAIN AT 213 , 425;
		WIDTH 482 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil ;
		TITLE "Test grid control" ICON NIL MAIN CURSOR NIL
    DEFINE LABEL Label_1
        ROW    30
        COL    40
        WIDTH  120
        HEIGHT 24
        VALUE "Enter filter value"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
        RIGHTALIGN .T.
    END LABEL
    DEFINE TEXTBOX Text_1
        ROW    30
        COL    180
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        CASECONVERT NONE
        BACKCOLOR NIL
        FONTCOLOR NIL
        INPUTMASK "!!!!!"
        FORMAT Nil
        VALUE ""
    END TEXTBOX
    DEFINE BUTTON Button_1
        ROW    30
        COL    330
        WIDTH  100
        HEIGHT 28
        ACTION FILTER(MAIN.TEXT_1.VALUE)
        CAPTION "FILTER"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE GRID Grid_1
        ROW    80
        COL    30
        WIDTH  420
        HEIGHT 210
        ITEMS { {""} }
        VALUE Nil
        WIDTHS {200,200 }
        HEADERS {"field1","field2"}
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        BACKCOLOR NIL
        FONTCOLOR NIL
        HEADERIMAGES Nil
        ROWSOURCE "test"
        COLUMNFIELDS {"AA","BB"}
        ALLOWAPPEND .F.
        ALLOWDELETE .F.
        BUFFERED .F.
        DYNAMICDISPLAY Nil
        ONSAVE Nil
        LOCKCOLUMNS 0
    END GRID
        Main.Center
        Main.Activate
function makedata()
  local astru:={{"AA","C",3,0},{"BB","C",5,0}}
  dbcreate("test.dbf",astru)
  use test new
  dbAppend()
  TEST->AA:="11"
  TEST->BB:="AAAAA"
  dbAppend()
  TEST->AA:="12"
  TEST->BB:="BBBBB"
  dbAppend()
  TEST->AA:="13"
  TEST->BB:="AAAAA"
  dbAppend()
  TEST->AA:="14"
  TEST->BB:="CCCCC"
  dbAppend()
  TEST->AA:="15"
  TEST->BB:="AAAAA"
   dbAppend()
  TEST->AA:="16"
  TEST->BB:="AAAAA"
  FUNCTION FILTER(CVALUE)
  IF EMPTY(CVALUE)
    dbClearFilter()
    dbSETFilter({||TEST->BB==CVALUE})
  TEST->(DBGOTOP())
  MAIN.GRID_1.REFRESH()
test.rar
(1.09 KiB) Downloaded 325 times
Best regards, HUIYI
Re: HMG 3.4.3
Thanks for report
Re: HMG 3.4.3
Huiyi,
I use this, working, construction :
    SET FILTER TO ALLTRIM(CVALUE) $ ALLTRIM(TEST->BB)
Hope this helps!
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
serge_girard wrote:Huiyi,
Hope this helps!
I replaced my code with yours, I recompiled the program, and now the GRID still is incorrect!
Re: HMG 3.4.3
Hope this helps!
Thanks Serge for solver this problem !
Re: HMG 3.4.3
This what I get. Seems OK to me!
Please send you PRG.
huiyi_ch wrote:Hello Dr. Claudio Soto
    MAKEDATA()
        ROW    30
        COL    40
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
        RIGHTALIGN .T.
    END LABEL
        ROW    30
        COL    180
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        CASECONVERT NONE
        BACKCOLOR NIL
        FONTCOLOR NIL
        INPUTMASK "!!!!!"
        FORMAT Nil
        VALUE ""
    END TEXTBOX
        ROW    30
        COL    330
        WIDTH  100
        HEIGHT 28
        CAPTION "FILTER"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE GRID Grid_1
        ROW    80
        COL    30
        WIDTH  420
        HEIGHT 210
        ITEMS { {""} }
        VALUE Nil
        WIDTHS {200,200 }
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        BACKCOLOR NIL
        FONTCOLOR NIL
        HEADERIMAGES Nil
        ROWSOURCE "test"
        ALLOWAPPEND .F.
        ALLOWDELETE .F.
        BUFFERED .F.
        DYNAMICDISPLAY Nil
        ONSAVE Nil
        LOCKCOLUMNS 0
    END GRID
        Main.Center
        Main.Activate
function makedata()
  use test new
  dbAppend()
  TEST->AA:="11"
  TEST->BB:="AAAAA"
  dbAppend()
  TEST->AA:="12"
  TEST->BB:="BBBBB"
  dbAppend()
  TEST->AA:="13"
  TEST->BB:="AAAAA"
  dbAppend()
  TEST->AA:="14"
  TEST->BB:="CCCCC"
  dbAppend()
  TEST->AA:="15"
  TEST->BB:="AAAAA"
   dbAppend()
  TEST->AA:="16"
  TEST->BB:="AAAAA"
  IF EMPTY(CVALUE)
    dbClearFilter()
  TEST->(DBGOTOP())
test.rar
Best regards, HUIYI
IMHO, you should declare cValue as private variable of Main function or public variable.
In your code, cValue is local in Filter file - after returning to main form, filter on db is bad defined.
You can always change it to:
oFilter := "{|| alltrim(Test->BB)=='" +alltrim(cValue) + "'}"
dbSetFilter(&oFilter)
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
serge_girard wrote:This what I get. Seems OK to me!
Please enter "BBBBB", look at the output is correct?
huiyi_ch
Post by huiyi_ch »
    MAKEDATA()
        ROW    30
        COL    40
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        ACTION Nil
        AUTOSIZE .F.
        BACKCOLOR NIL
        FONTCOLOR NIL
        RIGHTALIGN .T.
    END LABEL
        ROW    30
        COL    180
        WIDTH  120
        HEIGHT 24
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        CASECONVERT NONE
        BACKCOLOR NIL
        FONTCOLOR NIL
        INPUTMASK "!!!!!"
        FORMAT Nil
        VALUE ""
    END TEXTBOX
        ROW    30
        COL    330
        WIDTH  100
        HEIGHT 28
        CAPTION "FILTER"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE GRID Grid_1
        ROW    80
        COL    30
        WIDTH  420
        HEIGHT 210
        ITEMS { {""} }
        VALUE Nil
        WIDTHS {200,200 }
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        BACKCOLOR NIL
        FONTCOLOR NIL
        HEADERIMAGES Nil
        ROWSOURCE "test"
        ALLOWAPPEND .F.
        ALLOWDELETE .F.
        BUFFERED .F.
        DYNAMICDISPLAY Nil
        ONSAVE Nil
        LOCKCOLUMNS 0
    END GRID
        Main.Center
        Main.Activate
function makedata()
  use test new
  dbAppend()
  TEST->AA:="11"
  TEST->BB:="AAAAA"
  dbAppend()
  TEST->AA:="12"
  TEST->BB:="BBBBB"
  dbAppend()
  TEST->AA:="13"
  TEST->BB:="AAAAA"
  dbAppend()
  TEST->AA:="14"
  TEST->BB:="CCCCC"
  dbAppend()
  TEST->AA:="15"
  TEST->BB:="AAAAA"
   dbAppend()
  TEST->AA:="16"
  TEST->BB:="AAAAA"
  IF EMPTY(CVALUE)
    dbClearFilter()
  TEST->(DBGOTOP())
test.rar
Best regards, HUIYI
在代码块中,可以使用局部变量的。GRID显示不正确的原因,可能是由于GRID CONTROL存在BUG!
In the code block, you can use local variables. GRID display is not the correct reason, may be due to the grid control has bug.
Re: HMG 3.4.3
Huiyi,
Enter "BBBBB" gives correct output for me! BUT... sometimes 2 lines with BBBBB are shown when clicking on empty lines.
Claudio, I think it is a bug. See att.
