HMG 3.4.1
Re: HMG 3.4.1
Clip2Mania wrote: Maybe Dr. Soto can help - if he reads this?
Hopefully yes :) ( Don't forget time zone difference ;) )
I only started working with version 3.4.0 last year, so I have no experience with older versions of HMG - and I really want to use 3.4.1 for the bug-fixes and new functions... :(
OK. My opinion is behavior of 3.4.1 is correct.
Anyway I will try with older versions and inform the result.
Re: HMG 3.4.1 - Order of Controls
Clip2Mania wrote:Hi,
when I compile following code in 3.4.0 everything works fine.
function main()
local aHeaders:={'Column1','Column2','Column3'}
public aList:={}
SET MULTIPLE OFF WARNING
SET DATE ITALIAN
DEFINE WINDOW MainForm;
	AT 90,90;
	WIDTH 1025;
	HEIGHT 550;
       TITLE 'Resize Error';
	MAIN;
	ON SIZE Resize();
	ON MAXIMIZE Resize()
DEFINE MAIN Menu of MainForm
   DEFINE POPUP "File"
	MENUITEM "About" ACTION MsgInfo("Action")
   END POPUP
	END MENU
	@ 005,005 GRID Grid_1    ;
                 WIDTH 1000 HEIGHT 490 ;
		 HEADERS aHeaders;
	         WIDTHS {300,300,300}  ;
		 ITEMS aList  	;
		 VALUE 1;
		 FONT "Courier New" SIZE 10 ;
		 FONTCOLOR {000,000,255};
                 EDIT;
		 CELLNAVIGATION;
		 LOCKCOLUMNS 1
MainForm.Center
MainForm.Activate
return NIL
function Resize()
MainForm.Grid_1.Width:=MainForm.Width-25
MainForm.Grid_1.Height:=MainForm.Height-60
rturn NIL
When I compile this code in 3.4.1 (+ patch 3), I get a runtime-error that the "form is not defined"?
When I change the order of the Controls, i.e. I put the grid as first Control, followed by the menu, I get no error.
When I add a status-bar control, I have to put it below the grid also, otherwise: error again.
This has changed in comparison with 3.4.0. ??? Is there an order in which you have to place the controls ? :o
Erik
I will review the code
Re: HMG 3.4.1
esgici wrote: I will try with older versions and inform the result.
Tried ( with HMG 3.0.46, 3.1.5, 3.2, 3.3.0, and 3.3.1 ) all results are same as 3.4.0 :arrow:
I gave up that idea :oops:
function main()
public aList:={}
SET DATE ITALIAN
	AT 90,90;
	WIDTH 1025;
	HEIGHT 550;
	MAIN;
	ON SIZE Resize();
   DEFINE POPUP "File"
   END POPUP
	END MENU
		 HEADERS aHeaders;
		 ITEMS aList  	;
		 VALUE 1;
                 EDIT;
		 CELLNAVIGATION;
		 LOCKCOLUMNS 1
MainForm.Center
MainForm.Activate
return NIL
function Resize()
rturn NIL
Erik
You're right, this bug I introduced in a previous patch.
This a new patch with fixed bug.
hmg.3.4.1_patch4.rar
(821.93 KiB) Downloaded 634 times
srvet_claudio wrote:...
Thanks Doc, problem solved :arrow:
Viva HMG :D
Re: HMG 3.4.1
Thank you Claudio. The patch file is updated in the download page also. :)
Re: HMG 3.4.1
Rathinagiri wrote:Thank you Claudio. The patch file is updated in the download page also. :)
Re: HMG 3.4.1
I can see a lot of news here.
I'll have a lot of work after return from vacation :-)
Regards, Marek
Clip2Mania
Re: HMG 3.4.1
Post by Clip2Mania »
Thanks Claudio!
Erik
Re: HMG 3.4.1
Post by EduardoLuis »
Thanks Claudio
Eduardo
