Page 16 of 21
Re: HMG 3.1.5 (Test)
Posted: Sun Nov 03, 2013 11:52 pm
by andyglezl
Gracias Dr. Claudio, con lo que indicó, ya no despliega el "warning".
Thanks Dr. Claudio, which stated, no longer displays the "warning".
HB_FUNC( HDGETSERIAL)
hb_retnl( Get_SerialNumber((char *) hb_parc(1)) );
Esto es lo que tengo:
#pragma BEGINDUMP
#define _WIN32_IE 0x0500
#define HB_OS_WIN_32_USED
#define _WIN32_WINNT 0x0400 <-------------- Ya tengo un define
#define _WIN32_WINNT 0x0500 <-------------- si añado este otro, despliega lo siguiente
#include <windows.h>
#include <commctrl.h>
#include "hbapi.h"
#include "hbvm.h"
#include "hbstack.h"
#include "hbapiitm.h"
#include "winreg.h"
#include "tchar.h"
#include <shlobj.h>
#include <winuser.h>
#include <vfw.h>
#include <windowsx.h>
D:\RespaldosPCs\DiscoC\Trabajo\ConAd>C:\hmg.3.1.5\build conad
Harbour 3.2.0dev (r1307180024)
Copyright (c) 1999-2013, http ://harbour-project.org/
conad.prg:7980:0: warning: "_WIN32_WINNT" redefined [enabled by default]
conad.prg:7979:0: note: this is the location of the previous definition
conad.prg:8190:0: warning: "LWA_COLORKEY" redefined [enabled by default]
c:\hmg.3.1.5\mingw\bin\../lib/gcc/mingw32/4.6.2/../../../../include/winuser.h:2399:0: note: this is
conad.prg:8191:0: warning: "LWA_ALPHA" redefined [enabled by default]
c:\hmg.3.1.5\mingw\bin\../lib/gcc/mingw32/4.6.2/../../../../include/winuser.h:2400:0: note: this is
Si comento *#define _WIN32_WINNT 0x0400, me despliega muchos errores mas.
If I comment * # define _WIN32_WINNT 0x0400, displays many bugs more.
Posted: Mon Nov 04, 2013 1:18 am
by srvet_claudio
#pragma BEGINDUMP
#include "hbapi.h"
#include "hbvm.h"
#include "winreg.h"
#include "tchar.h"
#include <shlobj.h>
#include <vfw.h>
Comentar en C así:
o así:
Posted: Tue Nov 05, 2013 9:07 pm
by andyglezl
Hola, el siguiente ejemplo funciona en HMG 3.0.46, pero en HMG 3.1.5 no.
No cambia el tamaño del control IMAGE.
alguna idea ?, es BUG ?
Hi, the following example works in HMG 3.0.46 but not HMG 3.1.5.
No resizes the control IMAGE.
any ideas?, is BUG?
#include "HMG.CH"
FUNCTION MAIN( )
PRIVATE cFileName := "demo.jpg" // Pon cualquier imagen // Put any image
nAncImg := System.DesktopWidth
nAltImg := System.DesktopHeight
DEFINE WINDOW V_FotoGde AT 000,000 WIDTH 650 HEIGHT 466 VIRTUAL WIDTH nAncImg+10 VIRTUAL HEIGHT nAltImg+10 ;
TITLE "DOCUMENTO: "+cFileName MAIN NOSIZE
@ 000,000 IMAGE I_Imgpso PICTURE cFileName WIDTH nAncImg HEIGHT nAltImg
ON KEY ESCAPE OF V_FotoGde ACTION ( V_FotoGde.Release )
DEFINE CONTEXT MENU OF V_FotoGde
ITEM ' Reducir -' ACTION SumRest( "-", cFileName )
ITEM ' Restaurar ' ACTION SumRest( "R", cFileName )
SEPARATOR
END MENU
CENTER WINDOW V_FotoGde
ACTIVATE WINDOW V_FotoGde
RETURN( nil )
FUNCTION SumRest( cValx, cArch )
IF cValx=="-"
nAnpso:=V_FotoGde.I_Imgpso.Width-200
nAlpso:=( nAnpso * V_FotoGde.I_Imgpso.Height ) / V_FotoGde.I_Imgpso.Width
V_FotoGde.I_Imgpso.Width :=nAnpso
V_FotoGde.I_Imgpso.Height:=nAlpso
V_FotoGde.I_Imgpso.Width :=nAncImg
V_FotoGde.I_Imgpso.Height:=nAltImg
V_FotoGde.I_Imgpso.Picture:=cArch
V_FotoGde.I_Imgpso.Refresh
RETURN( Nil )
HMG 3.1.5 (Test)
Posted: Tue Nov 05, 2013 9:44 pm
Hola Andrés,
Bastaria comentar tu linea:
Pues aqui estaria volviendo a cargar el archivo con las medidas que fueron definidas originalmente.
Posted: Tue Nov 05, 2013 10:02 pm
by andyglezl
Hola Pablo Cesar, gracias.
Pero debió haber cambiado algo ya que si comento esa linea,
se invierte el problema, al compilarlo con 3.0.46 deja de funcionar.
Hi Pablo Cesar, thanks.
But he must have changed something because if I comment that line,
reverses the problem, to compile with 3.0.46 stops working.
HMG 3.1.5 (Test)
Posted: Tue Nov 05, 2013 10:18 pm
andyglezl wrote:debió haber cambiado algo
Ya lo creo ! Bastante nuevas propiedades fueron implementadas en la funcion _DefineImage. Justamente _HMG_SYSDATA [ 31 ] y _HMG_SYSDATA [ 32 ] que trata de las propiedades Width y Height que antes simplesmente cargaba con valor cero. En mi opinion, está mucho mejor gracias a las grandes contribuciones del Dr. Soto.
andyglezl wrote:al compilarlo con 3.0.46 deja de funcionar
Creo que es una cuestion de limpiar la área que la imagen ocupaba. Si quieres mantener compatibilidad, al compienzo de la function SumRest, esconda la imagen:
V_FotoGde.I_Imgpso.Hide
Y en lugar que tenia:
Subtituye por:
V_FotoGde.I_Imgpso.Show
Volviendo la imagen. Aqui me dió bien en la dos versiones.
Posted: Wed Nov 06, 2013 12:12 am
by andyglezl
Perfecto, problema resuelto, gracias Pablo César.
Posted: Fri Nov 08, 2013 2:56 pm
by srvet_claudio
Pablo César wrote:please accept improvement suggestions for IDE:
Hi Pablo, any idea is welcome.
At the moment I have no time to dedicate to the IDE.
Please, create a new topic only for post all the suggestions of the IDE for future updates.
HMG 3.1.5 (Test)
Posted: Fri Nov 08, 2013 10:13 pm
srvet_claudio wrote:Pablo César wrote:please accept improvement suggestions for IDE:
Thank you Claudio for the oportunitiy.
I have already move this suggestions messages in one of many existing topic about IDE suggestions and I compiled others suggestions from others colleagues just to keep
in this topic/message always updated for you solving the IDE pendings for future updates.
Posted: Sat Nov 09, 2013 12:11 am
by srvet_claudio
Pablo César wrote:I have already move this suggestions messages in one of many existing topic about IDE suggestions and I compiled others suggestions from others colleagues just to keep in this topic/message always updated for you solving the IDE pendings for future updates.
Thanks.
